4.3 high perf build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-22-2009, 03:34 AM   #1 (permalink)
redneckryder84's Avatar
Member # 57010
4.3 high perf build
i am getting ready to tear into a 4.3 for my sammy and have a few questions. I know i can use alot of parts for a small block for my build because i want to lighten up the bottom end. I am not looking to get gobs of power but i do want alot more RPM out of it.( 8,000-8700 redline) I know that this will suffer in the bottom end but im not lookin to creep around anywhere. My main concern is about fueling it, I would like to run a throttle body but im not sure about the computer and sensors on a built motor. Who would i contact for computor remapping etc? Would i be better off to build a carbed motor with a truck avaenger?
redneckryder84 is offline   Reply With Quote
Old 04-22-2009, 09:13 AM   #2 (permalink)
Member # 34987
Start with a 454 TBI unit. I also HIGHLY recommend the 16197427 ECM as it is the latest TBI ECM and is the easiest to program. Also, your truck will run best if you program it, or have someone else program it with the truck in person. IMO mail order tunes leave a lot on the table.
axisT6 is offline   Reply With Quote
Old 04-22-2009, 03:52 PM   #3 (permalink)
Member # 128665
lots of this info over on s10forum.com...
Good luck getting the stock "split profile" type crankshaft to zing 8k repeatedly...and an aftermarket will set you back THRICE what it should.
bscman is offline   Reply With Quote
Old 04-23-2009, 08:03 AM   #4 (permalink)
metalmatt47's Avatar
Member # 131753
Edelbrock has a performer intake for a 4.3 for around $250 thats supposed to be fairly good. The only problem is thats its not a fuel injection manifold. But if your willing to convert to cauburated(sp) its the best way to go for the money. They also have complete top end kits, but they're a little more expensive.
'96 Sierra..Rebuilt 266..35's
metalmatt47 is offline   Reply With Quote
Old 04-23-2009, 08:11 AM   #5 (permalink)
Member # 80052
Send a message via MSN to the_experience3006 Send a message via Yahoo to the_experience3006
That really isn't a problem if he uses a 454 throttle body since the early ones came factory with a heated adapter to a quadrajet intake. Even if he can't find one of those there are adapter plates all over the place from the TBI pattern to both square and spreadbore intakes.
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE]
[QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit.
[/QUOTE]
the_experience3006 is offline   Reply With Quote
Old 05-28-2009, 12:57 PM   #6 (permalink)
Member # 57010
what if i went with a 4.3 vortec motor instead? It is going in a sammy that has virtually no wiring( push button start etc, cause i hate wiring.) Where would be the best place to get the stand alone harness, computor etc? What year motor would be the best(most power)? I am gonna use it with a toyota 5 speed and dual cases.
Old 05-29-2009, 01:19 PM   #7 (permalink)
Member # 98330
Send a message via AIM to DisturbedS10 Send a message via Yahoo to DisturbedS10
Stay away from the CPI vortecs. Injector nightmares, and no real gain in hp over the tbi setup. The highest rating ever was 190(195 if you got a zr2 some years) hp in the S10. Silverados got 200hp towards the end of their life. Easiest wiring would have to be TBI, anything from 88-91. Just grab whatever computer is in the donor vehicle and get a chip burned for it. Good luck on the performance part. I tried to copy the Hotrod mag 300+hp build and it would have cost over $5000 with machine work + parts. Alot of parts might interchange with a sbc, but whatever ones don't be prepared with some KY cause you'll get raped If you're using a yota trans and really care about top end....Why not go with a 20r or 22r & add turbo + propane? Check out syty.net if you want to get an idea of high dollar 4.3 builds.
DisturbedS10 is offline   Reply With Quote
Old 05-29-2009, 07:47 PM   #8 (permalink)
Member # 80727
Carb it as use propane. Have you had any thoughts on that?
1994 Isuzu Trooper: OM617/W56/toybox
4.56 Dana 44 w/ lockright/6 lug Ford 8.8 4.56 Ox locker
r0nin89 is offline   Reply With Quote
Old 06-03-2009, 01:45 AM   #9 (permalink)
Member # 106274
8000-8500? buy every 4.3 you can find.....I guarantee you will be replacing them often
My 2006 4.3 vortec falls flat on it's face at 4500....with the stock rev limiter removed
Black06 is offline   Reply With Quote
