14 bolt rebuild need wheel studs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-22-2009, 04:53 PM   #1 (permalink)
Member # 115642
Hi.
I'm rebuilding a 14bolt FF out of a 1973 chevy 4x4 to go with my dana60
front SAS on my 1992 chevy 4x4.
I'm planning on swapping to disk brakes on the 14bolt.
I'm having trouble finding new wheel studs. some of the older ones are
BEAT UP!!!
Anyone know where I can get them, or a suitable replacement??
thanks.
Chevywhite is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 05:01 PM   #2 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
pitiful... any parts house can get them thru "Help!", "Dorman", etc.. You need to get on the phone.
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
happy..happy..happy....
nvrenuf is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 05:04 PM   #3 (permalink)
Member # 115642
Thank You.
Old 04-22-2009, 05:47 PM   #4 (permalink)
redtruck's Avatar
Member # 21493
Make sure you get the Dually studs as they are longer and work better with the disc conversion
92 chevy sfa
89 S-10 sfa
redtruck is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 07:05 PM   #5 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Jesus-titty-fuckin-christ. $1.99 at auto zone. 610-301 (f250 stud smaller head) or 610-194 (dually stud, you might have to grind the head a bit)
http://www.pirate4x4.com/forum/showt...light=14B+stud
guidolyons is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 07:39 PM   #6 (permalink)
GMCTruxrule's Avatar
Member # 51243
Checkers did not have them, they can't even order them so don't waste your time there.
I found mine at Napa.
Edit: The Napa I went to does not list by axle or ring gear size, it goes by brake drum size, and for the 14FF its 13 inches.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 08:45 PM   #7 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Napa (Balkamp) #BK6412794 drw stud
HAPPYJOHN is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 09:55 PM   #8 (permalink)
Member # 34987
Dually Stud Dorman# 610-194. Order em' from RockAuto.com. You do not have to grind the heads.
axisT6 is offline   Reply With Quote Quick reply to this message
Old 03-22-2010, 09:09 AM   #9 (permalink)
Member # 112511
ok so these 610-194 studs are basically perfect for my 14bolt as you say, but what about my dana 60 up front? can i order the same studs for it?
toyotanick is offline   Reply With Quote Quick reply to this message
