Member # 65523
quick question on 07 5.3 fuel line routing
The fuel pressure side is pretty self explainitory, but the return is my question the only other fuel hook up I see is labeled canister purge sylinoid on the wire harness. Do I treat this as a fuel return, and if not were do I route it and is there a fuel return? There is no smog this is in a buggy. Thankyou.
Conrad |
Beaver Pleaser
Member # 13645
There might not be a return but I can't say for sure.. The cannister purge goes to the charcoal cannister and can be blocked off if you're not using it. I say run it if you got it but then you have to duplicate the factory fuel system ventilation to get it to do it's job properly.
1972 GMC Submarine 383 / TH350 / 203D-NP205 / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez Inclined to brute force attack a 70* incline with a Quadrajet 1997 GMC K3500 Suburban TC76 L33 / 4L80E / HP60 SAS / PROJECT TOWHOE Last edited by florida4x4; 04-24-2009 at 02:28 PM. |
Member # 130483
07's are return less,get the correct fuel pump or a regulator with a return
92 S10,sm465/np208/np241,d44,9inch,spools,exo 99 Silverado,35's,locked 14b,4.8L,nv4500 |
