Chevy front axle ID and a couple questions. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-24-2009, 09:52 AM   #1 (permalink)
Member # 52851
Send a message via AIM to SwampWalker3
This is a 10 bolt, right?
I bought the axle as a 44, but I was a tad bit tired from working 12 hours, then driving two hours to get the axles, and it being dark didn't help. Also, my lack of axle knowledge doesn't help either. After inspecting it the next day, I'm thinking it's a 10 bolt. The two set of numbers I have are GM10 and 14030376.
The front axle does have an auburn locker, 4.88s, cross over steering and I'm told it has cromoly shafts, but I'm not sure how to find that out. Ideas?
Also, what size ubolt do I need to use for the cast side perch? Gotta get some ubolts today.
I wasn't really too mad about it since it was my fault and it's going under a YJ and if my stock d30 with 38.5"x15" boggers and a detroit can handle it, I'm sure this axle could.
The thing that really pisses me off is that the FF14 bolt was suppose to have a locker. I started tearing it down, cleaning it up and put disks on it, and I find out that the spiders are welded. Kinda pisses me off since this will be on my DD. And of course I can't get the guy to pick up his phone. So I gotta figure out how bad this is going to suck on the road. Lucky me I have trial boggers for such a test until I can find a detroit.
And.. What are the ubolt side for this axle? I'm finding two different sizes.
Thanks in advance
SwampWalker3 is offline   Reply With Quote
Old 04-24-2009, 10:07 AM   #2 (permalink)
Member # 78331
Yes that's a 10 bolt and no it won't hold up to 38.5 Boggers. This shit belongs in the newbie forum.
dirtchicken is offline   Reply With Quote
Old 04-24-2009, 10:41 AM   #3 (permalink)
Member # 15404
Better than your D30... but neather a D44 or a 10 bolt is going to hold up.
The 10 bolt gets a bad wrap from many people. It's just as good and some say a bit better than a D44.
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote
Old 04-24-2009, 10:45 AM   #4 (permalink)
Member # 78331
I was trying to figure out how he made a Dana 30 survive with 38.5s and I finally saw his screen name. Hard to break shit driving through mud puddles.
Old 04-24-2009, 11:07 AM   #5 (permalink)
Member # 52851
Figured chevy people would know a chevy axle a bit better than people who probably couldn't care less for the name/make/model. And the name is just a name.
Thanks for the heads up Currier.
Old 04-24-2009, 12:44 PM   #6 (permalink)
Mr Mom
glenns89's Avatar
Member # 94897
thats the thng about the newbie forum. Knowkedgable people go through there to help people who put their newbie questions in the right place.
89 jimmy D60/ff14bolt/400/203/205. Detroit rear, open front for now.
glenns89 is offline   Reply With Quote
Old 04-24-2009, 12:55 PM   #7 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
^ftw
76 CJ-7... mostly chevy parts
www.centexoffroad.com
mudskipper4x4 is offline   Reply With Quote
Old 04-24-2009, 01:22 PM   #8 (permalink)
Member # 36385
funny thing is this guy has been on the board longer than all but 1 of you that responded.
Big4x4Rides is offline   Reply With Quote
Old 04-24-2009, 01:34 PM   #9 (permalink)
AllUpInYourFace
Member # 72951
Touche'
Old 04-24-2009, 01:37 PM   #10 (permalink)
Member # 15404
You calling me old
Old 04-24-2009, 06:55 PM   #11 (permalink)
Member # 52851
Newbs.
Never deal with chevy stuff except for the last 14bolt I had. And Can't remember measurments to save my life. Next time I'll stick it in the newb forum.
Thanks again for the ID
Old 04-24-2009, 07:04 PM   #12 (permalink)
GMCTruxrule's Avatar
Member # 51243
Every moke has his own idea and opinion on what will work and what won't work and how.
I say, if you got it, run it. Or if you have the time and money to upgrade, then do that. Just have to be careful of how heavy you are on the throttle.
One friend with a Jeep breaks Dana 44s with 35s.
Another friend runs 35s on a front 30, a welded front 30, and still has yet to break anything.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 04-24-2009, 08:00 PM   #13 (permalink)
fairlane_68's Avatar
Member # 77346
That's FTMFW!
Exactly. You can't say "this axle sucks" just because you've broken 20 of them. I've seen Rockwells break...does that make them junk? It's all about the driver.
The good thing about GM 10-bolts is that everything at least from the knuckles out swaps between a Dana 44. And I'd mail that redneck locker back to that dude along with a canine tootsie roll.
'94 Bronco, 5.8L/E4OD, custom bumper and winch
"I left paint behind at the Coppermines"
fairlane_68 is offline   Reply With Quote
Old 04-24-2009, 08:33 PM   #14 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
i never buy anything now without looking into it. unless its like a 50$ piece of crap then who cares what you get.
i like the 10 bolt better then 44 for the simple fact that parts are everywhere for the. i have so many extra axle shafts and bearings lying around i collected over the years. few spare axles on the side of the garage people just give them away.
but if your just running it for mud they could possibly be fine. my ten bolts i have lasted 3 years under a k5 with 38s, 2 years under a suburban with 38s, another year under a k5 with 38s now they are under a s10 with 33inch boggers. and still kicking. broke one front shaft under the burb. running a 400ci in all those trucks too
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 04-24-2009, 09:18 PM   #15 (permalink)
AllUpInYourFace
Member # 72951
I'm pretty sure these are the correct sizes for the u bolts on the 10 bolt seeing as it has 3" tubes. One is bigger due to the perch being cast into the diff. (going off of memory here so)
3- 5/8"x3.25"x9.5" u bolts
1- 5/8"x3.75"x10.5" u bolt
14bolt uses 5/8"x3.625"x9.5"
Old 04-24-2009, 10:25 PM   #16 (permalink)
Member # 36385
Dana 44 and 10 bolt are pretty equal IMO, the dana 44 has smaller diameter tubes, but they are both the same wall size. Little more aftermarket support for the D44 i do believe, but 10 bolt parts are everywhere. Fix it up and run that bitch! 6 in 1 hand, half dozen in the other there.
Old 04-24-2009, 11:48 PM   #17 (permalink)
Member # 52851
Thanks for those measurements about to go get a few made. I actually found a buddy who is giving me spare shafts, inner and outers so I should be ok on that should one break without spending any cash for a bit.
I did read the tubes were the weak point of this axle because of the thin wall, so I kinda figure I'd truss the long end from the diff down to the driver side perch. (still using leafs) That should give me a bit more rigidity. See how that works.
The guy actually got back to me after I said I was going to swing by tomorrow to tell me he was sorry and that he's out of town. He also said all sales final, which I'd be fine with the 10 bolt, but telling me theres an auburn in the rear is kinda messed. Next time I won't be so dumb, I hope.
Thanks again guys.
Old 04-25-2009, 06:54 AM   #18 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
the weak spot on a 10 bolt is the passengers side of the housing where the leaf springs bolt on. most of them break in the cast webbing at this point. trussing the drivers side might just accentuate the weak point. There isnt really a good fix for it.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 04-26-2009, 08:45 PM   #19 (permalink)
Member # 36385
Thanks again guys.
saying all sales are final, and misleading info on the rear, sounds like some crooked BS to me.
On the other hand, you need to know what you are buying and check shit over before hand
Old 04-29-2009, 11:54 AM   #20 (permalink)
Member # 104783
38in or better?
Thanks to the nice people of this board, I just found out I have a 8.5 gm bolt up in front of my Samaria.
I'm not debating whether the 10 bolt is better than the Danna 44.
I do know that i have a welded front carrier and that causes a lot of axle stress. And I'm running an over sized tire for most axles.
I've been wheeling this sami for 3 years and just broke the passenger side knuckle. It was my fault, i jammed up the tire and forced the issue.....and well boom. I finished the trip in 3 wheel. I do go through a rear u-joint once a season it seems.
I guess I'm lucky or have a lighter foot than some.
08 resolutions: work less, screw wife longer
tommbstone is offline   Reply With Quote
Old 04-29-2009, 04:45 PM   #21 (permalink)
______________
Corey Young's Avatar
Member # 21622
Need better pictures of your wife.
Corey Young is offline   Reply With Quote
Old 04-29-2009, 08:36 PM   #22 (permalink)
Member # 104783
hahah did that small on purpose. I know how you lecher's are. ~ Just like me.
Old 04-29-2009, 09:29 PM   #23 (permalink)
Member # 78331
Those axles will last with the tires on it. Your rig weighs like 800 pounds.
Old 04-30-2009, 09:59 PM   #24 (permalink)
Member # 104783
Pretty close to 800 i'm sure
Old 05-02-2009, 10:34 AM   #25 (permalink)
Member # 52851
Nice Zuk.
My 10 bolt is going under a Yj with a 6cyl, so hopefully I'll have some luck. If not I'll move up. No big deal Since I have it, I'll run it until breakage actually becomes an annoying problem or until I find someone to buy the set.
Big, I'm with you on that. First time I actually delt with someone I. or a buddy, did not know. My fault.
I have another newb question.
I'm needing to replace the spindle bearings/seals and I'm throwing the axles under the jeep. My problem is that all the "big bearing sets" are talking about 6 lug hubs. Does anyone happen to have part numbers at hand for 8 lug hubs? I have all the other seals and bearings, just need to find the set for the spindles.
(Note: I am still searching after I write this.)
Edit:
I think I found the bearings. #550759
