4l60e - np231c seal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-24-2009, 02:12 PM   #1 (permalink)
Sticks and Stones
gmcxt's Avatar
Member # 115122
4l60e - np231c seal
is there a fluid seal between the two? or are they connected.
Piss on everything I'm going four wheelin!
gmcxt is offline   Reply With Quote
Old 04-24-2009, 10:03 PM   #2 (permalink)
Member # 105334
there is a seal in the front of the t-case so no they are not connected but the seals in those always get hard and leak through if thats what youre looking for. if youre low on trans fluid and you cant see a leak then check the t-case fluid and if a lot of atf pours out then the seal is bad and it is leaking through.
88 ChevyK1500 SAS with D60's,35spl,spool rear,ARB front,5.86 gears,350ci,700r4,NP203/205,42TSL, H1's
Big Red 88 is offline   Reply With Quote
