95 K2500 Burb - Leave 4L80 or install NV4500? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-12-2009, 12:33 PM   #1 (permalink)
Member # 81908
I'm surprised that I couldn't find any info on here about this! Hopefully this thread will be used in the future for others.
I've got a 1995 K2500 7.4L Burb, that I bought with a bad 4L80e transmission. I pulled the tranny and t-case out, and rebuilt them both. They are ready to be installed this weekend.
Today, I find that I have an opportunity to install a NV4500. The guy has a 1995 K3500 7.4L CrewCab, and is using the motor/tranny/t-case to put in a crawler build. He would rather have an automatic for his build, and we are considering a trade. He has a brand new clutch/pressure plate to go with the tranny, and will give me all of the parts that I will need to switch my Burb over to a manual.
Things like: Pedals, Master Cyl, Lines - What else will I need from him?
Since both vehicles are 1995 models, and both have the 7.4L V8, and both have the same Hydraboost brake setup, that it should be pretty straight forward to convert mine over for the NV4500.
Now, correct me if I'm wrong, but the T-case should be the same right? NP241 in both vehicles, and I believe that the NV shares the same spline count as the 4L80 (32 spline).
Do you see and obvious problems with this? Also, would you do the trade if it were you? Or just keep the 4L80e?
Primary use of the burb will be tow rig/expedition vehicle. I personally like the automatic for daily driving, but I really like the fact that the NV4500 is simple and reliable for expedition use. NV should allow for a little bit more fuel mileage, right?
I'd like to hear what you think about this situation!
-Tim
tim_zr2 is offline   Reply With Quote
Old 05-12-2009, 01:17 PM   #2 (permalink)
jays68yak's Avatar
Member # 19015
Send a message via AIM to jays68yak Send a message via Yahoo to jays68yak
If I was in your shoes Id trade. Im tempted to do a nv swap to get rid of my 80e now.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and fox coilovers, 8.1 liter 496 bbc/4l80e/BWtcase. DD/towrig
jays68yak is offline   Reply With Quote
Old 05-12-2009, 01:27 PM   #3 (permalink)
Member # 81908
Anyone know if the Cruise Control could be retained by doing this swap?
Also, what would you do with the column shifter? Leave it, or remove it?
-Tim
Old 05-12-2009, 01:55 PM   #4 (permalink)
Member # 9835
Why trade a freshly rebuilt trans for a used one The 4l80E is very proven and if kept cool should last another 100k. I am guessing that if the other guy is parting out the truck he bought it to do so, and the histroy of the NV4500 is somewhat unknown. Do you think you will get 100K from the used NV4500? I read a thread recently on the board regarding replacing a NV4500 during a trip and it sounded very expensive. 4l80E's seem to be plentiful and cheap used these days if you were caught in a bad situation far from home.
ChiScouter is offline   Reply With Quote
Old 05-12-2009, 02:05 PM   #5 (permalink)
Member # 81908
Great point!
I should clarify that the original vehicle had less than 80k on before it was rolled over.
You're right though, the 4L80 is a proven transmission, especially for what I will be using it for.
What is really making me consider this, is because with the NV, even if something DOES fail, there is a good chance that I can drive it somewhere, if not back home.
I've had a few manual transmissions break on me, and i've been able to make it home every time. One time the slave cylinder went out, another time the clutch fork pivot broke.
I've only had 1 auto tranny go out, but it did leave me stranded.
The fuel mileage gain is also a plus. On a 3500 mile trip (planned for next month), 1-2mpg gain is pretty good.
The auto will be the easiest to install though....
Hmmm....
-Tim
Old 05-12-2009, 04:00 PM   #6 (permalink)
Joey D's Avatar
Member # 20053
The 3500's used a borg warner t case vs your NP
98 K2500 SAS dynatrac pro rock 60, ORD high steer, RCV CV's, arb's front and rear, 4.56 gears
06 D Max Express
Joey D is offline   Reply With Quote
Old 05-12-2009, 06:26 PM   #7 (permalink)
Member # 81908
Good info!
Will that NV4500 bolt up to my 32 spline NP241c?
Also, will the t-case crossmember have to be modified? How about drivelines?
-Tim
Old 05-12-2009, 10:31 PM   #8 (permalink)
Banned
trkklr77's Avatar
Member # 29016
i always prefer manual trans.......
Old 05-13-2009, 03:02 PM   #9 (permalink)
Member # 128417
Ive always prefered the standard for towing. Had a NV4500 in a 3/4 ton and thrashed it, never a problem other than typical clutch replacement after 120,000 miles. Now the 4L80 in my burb is a different story, burnt up after 30,000 miles and dont ask what it cost to have it replaced it still hurts. But Ive heard good stuff on the 4L80 maybe mine was just s fluke.
scottjkj1 is offline   Reply With Quote
Old 05-13-2009, 05:16 PM   #10 (permalink)
Newbie
Member # 84158
The 241C with the 32 spline input is what the NV4500 uses. I swapped my NV3500 to the NV4500 in my tahoe and the 241C 32 spline input is what was in there.
-Alex
wrench-head is offline   Reply With Quote
Old 05-14-2009, 06:51 AM   #11 (permalink)
Member # 81908
-Alex
Awesome, good to know.
Anyone have the overall length of the NV4500 with the bellhousing?
I've found some info that says a bare (minus bellhousing) 4x4 NV4500 is 18.5" long.
I know that the overall length of my 4L80e is 26.5", which includes the bellhousing of course.
Thanks for your help!
-Tim
Old 05-14-2009, 08:20 AM   #12 (permalink)
Banned
trkklr77's Avatar
Member # 29016
one thing that i have always liked about chevy is that 9/10 the crossmebers are deisgned to ba left in the same spot and reguardless of trany and tcase.
Old 05-14-2009, 10:31 AM   #13 (permalink)
Member # 80208
TRUE. I just swaped from a 700r4 to 4500 in my 89 blazer, Just cut a hole in the floorfor the shifter and everything else bolted right up, even drive shafts.
76 fj-40, 400sb, 465, 35's.
89 blazer, tbi 350, nv 4500, 241, 60, eaton, 5.13's, 38.5 SX's.
J-Ohlin is offline   Reply With Quote
Old 05-14-2009, 01:43 PM   #14 (permalink)
Member # 81908
That's good to hear! I think i've made my decision, and will soon have one very rare 1995 Burb!
I'll make sure and take some pics of the swap.
Thanks for the help!
-Tim
Old 05-14-2009, 03:18 PM   #15 (permalink)
Member # 102194
Good luck, a 4500 burb is worth the buildup... I'm no pro, but i'd say that the 4500 could probably be rebuilt at home much easier than a 4l80. Just my $.02.
rickjames is offline   Reply With Quote
