14 bolt 6 lug - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-14-2001, 08:35 PM   #1 (permalink)
Member # 456
Post 14 bolt 6 lug
Here you go. I finally finished my buddys 14 bolt and I converted it to 6 lug and I am still using the stock 14 bolt brakes. Tell me what you all think. http://www.rustbucket.rockcrawler.com/photo.html
[ 08-14-2001: Message edited by: Donovan ]
Donovan
Flat Leafs=No travel???
Donovan is offline   Reply With Quote Quick reply to this message
Old 08-14-2001, 09:55 PM   #2 (permalink)
Blazerman1's Avatar
Member # 3574
Post
Hey, that looks good. How did you go about it? I have one sitting in the garage that I wanted to try that setup on, I just havn't had time to get that project stated yet. Wok seems to keep getting in the way of any of my blazer projects. Do you have any more photos of that setup with out the wheel and or the brake drum mounted? Any more info on that project would be great!
Blazerman1 is offline   Reply With Quote Quick reply to this message
Old 08-14-2001, 10:50 PM   #3 (permalink)
Member # 2340
Post
Looks good... how did you do it? Lets see some pics without the wheel. Did you have to open up the center hole in the wheel to get it to fit around the hub?
Rod
85 1 TON K5 14BOLT LOCKED/ DANA 60 5.13's WTO Hydro Assist 42's
94 FJ80 CRUZAH
SAVAGE1 is offline   Reply With Quote Quick reply to this message
Old 08-15-2001, 09:28 AM   #4 (permalink)
Member # 4243
Post
Looks to me like the hub-barrel and axle flange has been shaved down, and the hex bolts have been replaced with cap-bolts.
An important feature at play here is that Toyota and most aftermarket wheels have a larger center-bore, so factory GM wheels will not fit without mods.
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 08-15-2001, 10:46 AM   #5 (permalink)
Member # 5318
Send a message via AIM to lv2whl
Post
looks sweet, good job
-AMERICAN PRIDE-
71 2wd K5 Blazer -under construction-
lv2whl is offline   Reply With Quote Quick reply to this message
Old 08-15-2001, 11:21 AM   #6 (permalink)
Member # 456
Post
Yes I turn the hub down to 4.170 which is Factory Toyota size. So you can't use factory chevy wheels but you can use any aftermarket wheel on them. I used allen bolts to hold the axle in. I would show you how I did the brakes but that is a ancient Chinese secret. <IMG SRC="smilies/biggrin.gif" border="0"> I will think about.
Donovan
Old 08-15-2001, 11:25 AM   #7 (permalink)
Grandpa Jeep's Avatar
Member # 1868
Send a message via MSN to Grandpa Jeep
Post
Hey Donovan, that looks sweet. Is that a 15" wheel or do you have to use 16"? What would you charge to do that to mine? I'm getting ready to upgrade my truck. I was going to buy new wheels, but this looks like a better solution.
'50 CJ-3A, SVO Turbo 2.3L, T-98, D18, Warn OD, PTO Winch, D30, FFD44, lockrites in both
Jeeps, they're not just a hobby, they're a freakin adventure :D
:usa:
Grandpa Jeep is offline   Reply With Quote Quick reply to this message
Old 08-15-2001, 12:14 PM   #8 (permalink)
Member # 6291
Post
What all did you do to the hub to change it from 8 lug to 6 lug ?
[list][*]
[/list]
morpheus is offline   Reply With Quote Quick reply to this message
Old 08-15-2001, 02:19 PM   #9 (permalink)
Member # 2340
Post
I would show you how I did the brakes but that is a ancient Chinese secret. I will think about.
C'mon... you secret is safe with us <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/wink.gif" border="0"> At least describe how you did it.
Rod
94 FJ80 CRUZAH
Old 08-15-2001, 09:42 PM   #10 (permalink)
Member # 456
Post
Grandpa Jeep thoughs are 15" rims on there and you can use any after market or toyota rim because the hub hole is bigger than a stock chevy. I figure a price and it would be $600 for the hole thing. Now that is to convert yours to 6 lug. All I would need is the hubs minus the drums and the axle shafts. When you get them back you would just have to bolt the drum on and install them. Also if you are installing it on a chevy truck or blazer look for a 3/4 ton rearend because they will bolt right up. The lockers are a lot cheaper for a 14 bolt FF. My buddy got his for Randy's and I think he said it was $308 for it. Just something to think about. BTW the rear axle is 67" wide so that makes it only 1/2" narrower than the front axle. I did use 1/2" studs in the rear and, I am trying to find the matching 1/2" for the front axle but I am not having any luck. The best that I could do is use a 1/2" stud and drill the hub and rotor for the bigger knurle. Let me know what you think
Donovan
Old 08-16-2001, 06:24 PM   #11 (permalink)
Member # 6124
Send a message via AIM to fjcruiser
Post
Is that possible with a dana 60?
73 FJ40, 350, sm465, dana 300, dana 44/ARB dana 60/ARB PS 4 wheel discs 37 12.50 SSRs
fjcruiser is offline   Reply With Quote Quick reply to this message
Old 08-16-2001, 06:31 PM   #12 (permalink)
Member # 6291
Post
Originally posted by Brody Baker:
<STRONG>Is that possible with a dana 60?</STRONG>
a D60 wouldn't have to the hub and axle turned down just the bolt pattern changed I believe. Sure wish the guy would share what he did, modify a D60 is what i want to do also.
[list][*]
[/list]
Old 08-16-2001, 08:01 PM   #13 (permalink)
Member # 456
Post
If you are talking about the Dana 60 rear axle, it will not work by turning it down because the center hub is to large to start with. If you are talking about a Dana 60 Front yes you can make it into a 6 lug. I have not done it but I think I could do it if that is what you want.
I will show you guys how I did it probably next week. I will give you the weekend to think about. <IMG SRC="smilies/biggrin.gif" border="0">
Donovan
Old 08-17-2001, 01:12 PM   #14 (permalink)
NoBrainR's Avatar
Member # 250
Post
I was in the process of doing this myself, but turning the center down to 4.170" seams like the wall would be too thin over the bolt threads. Plus I was using disc's off a 10 bolt front for brakes. And don't the heads of the cap screws stick out past the OD of the axle flange?
Making good decisions comes from experience .......
...... experience comes from making bad decisions
NoBrainR is offline   Reply With Quote Quick reply to this message
