Member # 120434
Sas
Anyone seen a solid axle swap on a newer silverado? I have a 2007 Silverado 1500. I have the 3 year 36k warranty and when its up (7000 miles) I am probably gonna do a conversion on it. Anyone seen this done before any direction?
Mr Mom
Member # 94897
I would try searching around here. I know there are some sas threads around. Not sure about that new but it should be the same.
89 jimmy D60/ff14bolt/400/203/205. Detroit rear, open front for now. |
Member # 42023
here ya go...only thing is its a 2500hd. dont know that there is a kit for your application. I ordered my front brackets from ORU and the rest i did myself.
![]() ![]() I have more but that gives you an idea. If the rear tires seem froward to you, its just the angle....i checked and double checked it and it has a zero rate to offset the rear shackle flip. Its just the pic. good luck |
#6 (permalink) | |
Member # 103814
lol... man, really. |
Member # 106696
I don't know of any companies that offer a SAS for 1/2 ton NBS Chevrolets... With time, they will appear and trickle down from the 3/4 ton side. I think what's holding things up is the fact that the 1/2 tons now have struts, so the front end frame is no longer the same as the 3/4 ton+ trucks.
Member # 130963
I looked into doing this for a buddy of mine. Talked to a couple of companies and they told me the frames were to thin to support the weight of a D60 on the 1500's. They all told me the same thing... way too much welding/plating involved to make a reliable/safe kit. Good luck!!!
skullfuckery
Member # 29016
uhh, the axle supports the frame not the other way around chief.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
KILL 'EM ALL
Member # 61919
You will also have to change steering setups. Stock the use rack and pinion.
I'm guessing it is a new body style, not a classic.
2006 Dodge Cummins 4x4 G56 3 Link long arms, 40" Kevlar MT/R's and engine stuff 1984 K10, 305 that won't die, 700, 208, Rockwells and 46's Last edited by Satan's Chariot; 05-27-2009 at 10:12 AM. |
#12 (permalink) | |
Member # 103621
This is Alex by the way.
--Alex-- 1982 Toyota 4x4 - The Dirt Squirrel: Phase II underway: 4.3L CPI, TH350, Marlin 4.7s/D300 doubler, D60/14B/5.13s, f150 leafs up front, artec 4-linked rear, Coilovers, blah, blah blah. |
#13 (permalink) | |
Member # 130963
![]() Quote:
![]() Yep you are correct. Then the first time you max out the suspension, twist it up, or lets say send the truck sky high you land on nothing but your bumper and oil pan, how much of the frame will your axle be supporting then? This is in ref to kits. Not to say it cant be done.
#14 (permalink) |
skullfuckery
Member # 29016
any one who jumps a straigh axle is a fucking moron.
ok, lets say you do swap in solid axle, so are saying that you cant do a d60 and flex twist up but its ok with a d44?
#15 (permalink) | |
skullfuckery
Member # 29016
i dont know about you but i prefer not busting my frame and spindles and i like to keep my straight axles straight not \_/
#16 (permalink) |
Member # 136410
Offroad Direct lists a kit for the HD and the 1500 up to 2006. They have one kit that says 2001-2007, but I think it's a typo.
http://www.offroaddirect.com/products.htm |
