'94 suburban 1500- which tcase? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-25-2009, 06:59 AM   #1 (permalink)
roastbeef's Avatar
Member # 86553
my bud needs a new tcase. its a '94 suburban 1500. before we go hunt one down, i did a little research and found that there were two different types- the 4L60E and the 4L80E.
what is the difference?
thanks a bunch.
02 frontier, dynatrac pro rock 60, 3 link f/r, 14" kings f/r, arb lockers
thats right... a NISSAN!
DON'T JUST STARE AT IT- EAT IT!
Originally Posted by TexasBlake View Post
You should have licked her asshole.
roastbeef is offline   Reply With Quote
Old 05-25-2009, 07:38 AM   #2 (permalink)
Member # 111469
Well the 4L60E is 16 bolt pan and the 4L80E is a 17 bolt pan if that helps. The 4L60 pan is more rectangular than the square 4L80.
4L80E
4L60E
Search brought the good info..
http://www.pirate4x4.com/forum/archi...p/t-63584.html
1997 GMC 1500 blocks & IFS - DD
1981 Toyota - dcg9381's old rig - Rebuild in progress
AusTex is offline   Reply With Quote
Old 05-25-2009, 11:13 AM   #3 (permalink)
just4cuz's Avatar
Member # 98655
A K1500 will probably have the 4L60E in it with a NP 241 drivers drop t-case. Look on the back of the old t-case, it has a round metal tag screwed into it that has the model number and low range ratio stamped on the tag.
Should have NP-241 and 2.72-1 stamped on the tag.
just4cuz is online now   Reply With Quote
Old 05-25-2009, 03:12 PM   #4 (permalink)
roastbeef's Avatar
Member # 86553
thanks a bunch guys. if we were to swap out cases, would it matter which one we got? does either one have a lower 4lo or anything?
i don't know which one he has yet, but i guess what i'm asking is can they be interchanged, and is one better than the other?
edit- nevermind, i found the info. looks like we are going to want to do a direct swap. thanks again!
Old 05-27-2009, 09:27 AM   #5 (permalink)
Member # 111469
Just keep in mind you don't want to run a 4L60 computer on a 4L80 transmission so keep that in mind if you swap them.
