Eaton Rear End question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-31-2001, 02:06 PM   #1 (permalink)
Member # 7090
Send a message via AIM to orangezuk
Post Eaton Rear End question
I have a buddy who has an eaton rear end out of a 60s suburban. He wants to know where to get a locker (I think detroit makes a no-spin for it). It has an inspection plate and a drop out third member. Any info is much apprciated.
<IMG SRC="smilies/trooper.gif" border="0">
88 Zuk - Dana 44s, 35" Boggers, no straight panels
2001 Tundra - 2" Cam Tech lift, 265s on 16x8" Weld Outbacks
orangezuk is offline   Reply With Quote
Old 10-31-2001, 02:13 PM   #2 (permalink)
Member # 3694
Post
Weld it up and save the $$$$ <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/smokin.gif" border="0">
Need Steering? www.shakerbuilt.com
Too Many Projects not enough Time...
Shaker is offline   Reply With Quote
Old 10-31-2001, 02:21 PM   #3 (permalink)
Aggro's Avatar
Member # 2587
Location: 38*45.859N 120*34.534W (N. Ca) Future location of beachfront property.
Post
welcome <IMG SRC="smilies/thefinger.gif" border="0"> newby!! <IMG SRC="smilies/thefinger.gif" border="0">
Aggro is offline   Reply With Quote
Old 10-31-2001, 02:30 PM   #4 (permalink)
Member # 7090
Post
Originally posted by Shaker:
<STRONG>Weld it up and save the $$$$ <IMG SRC="smilies/biggrin.gif" border="0"> <IMG SRC="smilies/beer.gif" border="0"> <IMG SRC="smilies/smokin.gif" border="0"></STRONG>
Thats the plan if the search doesn't turn up anything.
Old 10-31-2001, 02:51 PM   #5 (permalink)
Member # 7668
Send a message via AIM to Hypoid Drive
Post
Unfortunaltly detroit no longer makes the locker for the eaton you may find a used one from randys ring and pinion I know that they had two <IMG SRC="smilies/biggrin.gif" border="0">
In search of portals
Hypoid Drive is offline   Reply With Quote
Old 10-31-2001, 04:00 PM   #6 (permalink)
Member # 382
Post
they are out there unfortunatly they are getting harder to find.I normally can find them when needed,with the supply and demand going up it seems so is the price(go figure)
72 SUBURBAN, 72 blazer, straight axled 02 duramax crewcab and 90 shortwide
bigblaze is offline   Reply With Quote
Old 11-01-2001, 07:01 AM   #7 (permalink)
brector's Avatar
Member # 192
Send a message via AIM to brector Send a message via Yahoo to brector
Thumbs up
You can also swap 14bolt shit inside the Eaton (so you can get the cheap 14bolt detroit). I just welded mine up.
[ 11-01-2001: Message edited by: brector ]
-Brian
1 ton yoda
I make nerd sexy
brector is offline   Reply With Quote
Old 11-01-2001, 03:38 PM   #8 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
Post
Originally posted by brector:
<STRONG>You can also swap 14bolt shit inside the Eaton (so you can get the cheap 14bolt detroit). </STRONG>
What kind of adapter do you need to go from the 12.25" ring gear of the Eaton down to the 10.5" of the 14 Bolt? <IMG SRC="smilies/rolleyes.gif" border="0">
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote
Old 11-01-2001, 05:39 PM   #9 (permalink)
Member # 4243
Post
You can look for a No-Spin in other 60's trucks - that's about it. They no longer make one for that rear-end. My buddy's '62 had a nifty little "Detroit No-Spin" dash plaque to boot!
I've heard you can use the 14-bolt Detroit in the Eaton. You also need newer fine-spline axles to go with it. They often aren't the correct length for the housing, but they can be "masssaged" a 1/4" or so with a grinder or cut-off wheel.
BTW: The Eaton in question here is the GM Corporate H-054 and H-072 (5400lb & 7200lb respectively) axle with a 10-1/8" ring gear. There was a minor revision mid-60's where they switched to a longer pinion. This affects the third member, gearset, and some bearings. Differentials (i.e. No-Spin), housings, and axles are generally interchangable - as is a complete third member assembly.
90-93 CTD jalopies
u2slow is offline   Reply With Quote
Old 11-02-2001, 05:55 AM   #10 (permalink)
brector's Avatar
Member # 192
Thumbs up
Originally posted by Reddwarf:
<STRONG>What kind of adapter do you need to go from the 12.25" ring gear of the Eaton down to the 10.5" of the 14 Bolt? <IMG SRC="smilies/rolleyes.gif" border="0"></STRONG>
You don't need an adapter. I'm pretty sure you just cut down the 14 bolt axles and slide them in.
-Brian
1 ton yoda
I make nerd sexy
