Flattened Splines on 14b - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-29-2009, 06:55 AM   #1 (permalink)
brian052484's Avatar
Member # 96967
Send a message via AIM to brian052484 Send a message via Yahoo to brian052484 Send a message via Skype™ to brian052484
So I didn't exactly break an axle shaft in the way that you'd think... but it's broken nonetheless. What caused this?
82 K20 350/465/208/14/60 Welded 5.13s 4 wheel discs
52s/56s 42" Iroks Bobbed/Dovetailed F/R
brian052484 is offline   Reply With Quote
Old 05-29-2009, 07:01 AM   #2 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
bent housing.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 05-29-2009, 07:45 AM   #3 (permalink)
Member # 46216
Send a message via AIM to shortsub
are you running a welded diff? I am thinking possible bent tubes .
My 14 bolt is all kinds of bent , ill have to check and see if my splines are flat .... we could be the flat splined 14 bolt friends .
396 forged and rollerd' [U]small block[/U], propane, 60 /14 with chromos ,th400, ord doubler , HAD 1410s f/r , full hydro, lockd 42 sxs .... all wrapped up in a glittery package
07 d max LBZ with a fatgirl on the back
shortsub is offline   Reply With Quote
Old 05-29-2009, 07:48 AM   #4 (permalink)
Member # 96967
lol. maybe we could start an exclusive club?
Yes sir it's welded up.
Old 05-29-2009, 08:39 AM   #5 (permalink)
Member # 46216
yea , you have to be pretty special to be in this club ...
Is anything visibly bent? do you have a traction bar? tubes welded? im just trying to think of anything that could do some tweaking
Old 05-29-2009, 08:44 AM   #6 (permalink)
Member # 96967
I haven't looked at it closely to see if it's bent yet. It's not blatantly obvious, but it's still possible. I don't have a traction bar... just some shock tabs welded on top. Does a traction bar often lead to bent axle tubes? This was going to be one of my up-coming projects!
Old 05-29-2009, 10:05 AM   #7 (permalink)
Member # 46216
the only thing with a traction bar is you must weld the tubes up ... a 14 bolt will spin the tubes once you make one side stationary .
no necessarily bend stuff ... just spin
so what made you think you broke? is everything functioning properly? do those shafts go in and out the carrier ok?
Old 05-29-2009, 10:41 AM   #8 (permalink)
Member # 96967
Gotcha. That makes sense.
I was climbing this wall, and as soon as I started to climb there was a pop (I thought it was a front U-Joint, as always). But when I rolled backwards the left rear axle "popped" as it rolled and looked like it was sorta ratcheting. I figured I broke a shaft. I kept wheeling the rest of the day in 3 wheel drive, had no problems following our group of smaller vehicles.
I'll probly put it back together and wheel our next trip to krocks in 3 wheel drive. I doubt I'll be able to find another van axle, and i might as well replace the whole axle if the tube is bent.
Old 05-29-2009, 10:53 AM   #9 (permalink)
cegusman's Avatar
Member # 5738
Bent tube, had the same thing happen on one of my bent 14 bolts
1982 Chevy K5 Blazer 6.2 Diesel\SM465\NP205
Front: Dana 60 4.88 Detroit 1410. 52" Spring swap and a 4 degree tapered Zero Rate
Rear: 14 Bolt 4.88 Detroit 1410. Disk Brakes. Stock 56" springs DIY4x Shackle flip and a 1" Zero Rate
38.5x14.50-15 SX's - 15x9 bead locked wheels
[URL="http://www.pirate4x4.com/forum/showthread.php?p=6018956&posted=1#post6018956"]My Build Tread[/URL]
cegusman is offline   Reply With Quote
Old 05-29-2009, 12:34 PM   #10 (permalink)
'Merica. Fuck Yeah!
86k30's Avatar
Member # 25703
x10 bent housing. Got a buddy that lost a front 60 to the bends just a couple weeks ago. took us awhile to figure out why the lockright didn't act right.
The facelift:/forum/chevy/1083762-old-busted-new-busted.html
86k30 is offline   Reply With Quote
Old 05-29-2009, 02:22 PM   #11 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
Hey Brian, theres a chevy van with a 14bff out at the waco pnp. Saw it out there today. Let me know if you need some help, I have all day next friday off if you need an extra hand or two.-Will
76 CJ-7... mostly chevy parts
www.centexoffroad.com
mudskipper4x4 is offline   Reply With Quote
Old 05-29-2009, 02:57 PM   #12 (permalink)
Member # 96967
Cool... thanks Will! If I'm gonna go pull a new axle, I think I might just get one out of a truck that way the spring perches are already at the right width. Remember seeing any out there under a truck?
Old 05-29-2009, 02:58 PM   #13 (permalink)
Member # 96967
Originally Posted by Grumpy_old_fart View Post
bent housing.
Dang grumpy you are always the first to answer my questions, and correct every time. You are the man!
Old 05-29-2009, 03:04 PM   #14 (permalink)
GMCTruxrule's Avatar
Member # 51243
Can I kiss your ass some more Grumpy????? ^^^^^^
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 05-29-2009, 03:11 PM   #15 (permalink)
Bazinga!
nvrenuf's Avatar
Member # 10903
mancrush
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
Build Pics & Build Thread
happy..happy..happy....
nvrenuf is offline   Reply With Quote
Old 05-30-2009, 12:00 AM   #16 (permalink)
Member # 46216
im confused ... why did the wheel stop pulling ? what actually broke ??
i tore my 14bolt apart after a boom to find this ... both shafts and a busted side gear from the carrier ..
Old 05-31-2009, 03:48 PM   #17 (permalink)
AllUpInYourFace
Member # 72951
Yep, there are a couple of full floaters under trucks out there.
Old 06-05-2009, 05:54 AM   #18 (permalink)
Member # 96967
A buddy of mine has a 14FF out of a 94' truck that I can buy from him and save myself a trip to the junkyard. Of course I'll have to weld on some new perches at the right width... but that's no big deal. MY problem is that my axle is out of a 1978-79 1 ton van. I have 5.13 gears setup in it as well as disk brakes.
My question is... according to the 14B Bible:
"Different years - The year split is '72-88 and 89+. I shall refer to these as "first design" and "second design". Of course, there may be variations. Differences between these years are noted below. Where the difference is known only to apply to certain "types", I shall indicate this. Otherwsie, it is not known whether the differences noted between the years apply to all types or not.
Second design axles have more fins on the center sectionFirst design axles 1984 and earlier use a different pinion straddle bearing than 1985 and later
Second design SRW axles in 1-ton pickup trucks and 3/4 ton Suburbans changed to allow for a slide-off drum (drum can be removed without pressing out the wheel studs). The backside of these hubs is not machined flat to accept a rotor, for example. The hub flange is also further inboard to allow for the thickness of the drum."
I was PLANNING on swapping out the complete pinion setup, disk brake brackets and hubs with rotors attached... but will this really work? Or do I need to find a first gen 14FF?
Old 06-05-2009, 12:42 PM   #19 (permalink)
Devout Newbie Hater
Member # 20147
ewwwww.... no lips please... just tongue.
Old 06-05-2009, 01:07 PM   #20 (permalink)
CDA 455's Avatar
Member # 95025
bent housing.
In what direction would said housing bend?
What kind of force would cause said bending?
Custom Front Dana 70 Axle For Sale:
http://www.pirate4x4.com/forum/axles...er-shafts.html
CDA 455 is offline   Reply With Quote
Old 06-05-2009, 01:11 PM   #21 (permalink)
Member # 96967
I couldn't answer you... I took mine all apart last night and looked down each side and I can't see anything visibly "bent".
Old 06-06-2009, 06:48 AM   #22 (permalink)
Member # 94838
seen this before, a buddy welded his 14 and it stripped the splines the same way, pulled it apart everything looked fine, but we found a crack in the spiders that let it expand just enough to strip the splines on the axle.
austin25 is offline   Reply With Quote
Old 06-06-2009, 07:47 AM   #23 (permalink)
Member # 15404
Looks like she is making a smiley face if those axle shafts are bolted up That's the way most axles bend....
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote
Old 06-06-2009, 07:51 AM   #24 (permalink)
Member # 15404
Oh and put a jack under the center like that and lift up. You might be able to get it to move far enough up that you can weld the tubes tight and a truss on the top without ever taking it out from under the truck...
Old 06-06-2009, 07:58 AM   #25 (permalink)
Devout Newbie Hater
Member # 20147
a bent housing can be caused from overloading, jumping, or severe impact.
if bent by load, the housing would bend into a smiley if you look at it from the front or rear.
if bent by impact on movement, the housing may bend differently, with the tires actually pointing out in the front, and may not be readily apparent. on some 14 bolts, the tubes look straight, but the area where the spindle joins the tube buckles.
The 9 inch housing was worse for this as it is steel, and not more than 1/4 inch thick. it has no cast center, its just stamped steel. Thats why we have to truss the 9 inch to make it work. spaghetti is fun...just not durable.
