Engine swap (into Toy)/carb questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-17-2001, 12:06 AM   #1 (permalink)
Member # 4201
Post Engine swap (into Toy)/carb questions
I have access to a free 1979 Chevrolet 3.3L (i think) V6 and turbo 350 out of my father's Malibu Classic. He swapped in a 350 5 speed, so he no longer needs the engine. The car was bought of the orginal owner last year with only 50,000kms on the odometer (~30,000 miles) and the engine and tranny run like a top. I know the eninges mounts are similar to other Chev swaps, but my questions are:
(1) What do I have to do to the output shaft of the TH350 to make it work with a transfer case, and what case should I use? ( If the output shaft can be swapped.
(2) I have some reservations about carb'd trucks. Is there stuff that can be done to the existing carb to make it work better at angles? Is there a replacement carb out there that is specifically made for angles/offroading.
(3) He also has a mid 80's T5 tranny from a V6 Camaro, can this be used as well. Need output shaft changes?
Any help would be appreciated. <IMG SRC="smilies/biggrin.gif" border="0">
1987 4-runner, 4500lbs, auto tranny 4cyl, very slow on hills, flats and downhills...
BigRedToy is offline   Reply With Quote
Old 08-18-2001, 11:57 PM   #2 (permalink)
Member # 4201
Post
Hey, where's the help. What chevy t-cases are good and will mate with the tranny's listed?
Old 02-24-2005, 08:49 PM   #3 (permalink)
Member # 29957
got to ott and get an adapter for your bulet proof toyota t-case. I see your a BC boy ... try bc4x4.com and blackflag4x4.com for some local input
http://www.ottindustries.com/gearing.htm
[COLOR=Blue][SIZE=5]Extreme[/SIZE] ... Life's to Short Not Too Be[/COLOR]
02' Tundra Limited Access Cab - 2.5" fabtech dirt logics, 3" body lift, 285/75R16's, Heated Seat
dkirkup is offline   Reply With Quote
