Dear Penis
Member # 123551
budget for a 383?
im picking up an eagle 383 kit off a friend, has steel crank, i-beam rods, forged pistons, rings, piston pins, the only thing i will need is the bearings.
$400 for that kit ~$100 for bearings $200 bore/hone ~$100 gaskets/seals possibly some head/valve work that i will do myself, but ~$75 parts i consider this a pretty good deal and will probly be doing is this winter any other costs i am forgetting? and any other thoughts on it are appriciated
90 Jimmy 350/465/205/60/14/44's 04 Sierra Duramax ZF6 on 37's I work hard for a living, millions on welfare depend on me... Looking for 1 44" TSL for 15" rim, pm me if ya have one |
Member # 6704
Double your budget to account for all the little things that you haven't considered that will pop up during the build.
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. |
#5 (permalink) | |
Dear Penis
Member # 123551
fluids are readily available at work, no intake and carb, im runnin TBI, and i have a set of long tubes. the only thing i need is plug wires, one burnt to my manifold
Member # 122805
[QUOTE=brooks294x4;9924096]i think you only have to do that using a 400 crank, not using an actual crank for the 383 kit
You still have to clearance the block with the kit. At least I did on the ones I built.
Wheeler: 87 K5, 454TBI , 465, 208, d60, 14bff, a few cuts on the body, rolling on 39.5'sTowrig/DD: 05 Dodge 2500 Cummins, with a few mods/forum/chevy/769919-foolsized-blazer-build.html Last edited by MTblazer87; 06-08-2009 at 04:22 PM. |
