d70 + 14 bolt hub question. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-25-2009, 11:41 PM   #1 (permalink)
Member # 111241
I got a d70 hd rear I'm stuffing in the k10 and had a question on swapping hubs. I read that the bearings are all interchangeable and spindles are the same so you can swap 14 bolt hubs on to a d70. Is this right? The whole reason I even ask this question is because I want to run discs on the 70 but dont want to have to have the rotors milled everytime I replace them. With dually 14 bolt hubs on the back I could run the 75+ rotors and not have to have them clearanced. It would basically save me time/effort/money to swap hubs.
Does this sound right or am I just high? Ill have them clearanced if I have too but whats the point if I can just swap my dually hubs onto it.
BTW I plan on using ruffstuff brackets if that matters.
74 Chevy K10 on schwantons
96 ZJ Weekend Trail rig
Kali-K10 is offline   Reply With Quote Quick reply to this message
Old 06-26-2009, 12:31 PM   #2 (permalink)
trkklr77's Avatar
Member # 29016
yes, the bearing and spindle are the same. yes you can install 14b hubs on the d70.
trkklr77 is offline   Reply With Quote Quick reply to this message
Old 06-26-2009, 01:42 PM   #3 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
I thought drw 14 bolt hubs and the D70HD dually hubs were the same therefore what wont fit one will not fit the other.
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
happy..happy..happy....
nvrenuf is offline   Reply With Quote Quick reply to this message
Old 06-26-2009, 01:45 PM   #4 (permalink)
trkklr77's Avatar
Member # 29016
afaik the drums are the same for a drw and a srw 14bff. if they are the rotor will fit the drw hub, cant say 100% because i have never tried to install a rotor on a drw hub.
Old 06-26-2009, 01:54 PM   #5 (permalink)
Member # 93989
nope
Lucky_Thirteen is offline   Reply With Quote Quick reply to this message
Old 06-26-2009, 02:23 PM   #6 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
Nope the hubs are different or...?
John
Old 06-26-2009, 02:50 PM   #7 (permalink)
Member # 111241
from what i understand the bearings and spindle are the compatable but the actual hub on a d70 is around 3/16"s larger in diameter. meaning the rotor itself would have to milled out to fit over it. Ill bust out the tape and see if they have the same offset in order to make the ruff stuff brackets work with the 14 b hub.
Old 06-26-2009, 04:22 PM   #8 (permalink)
Member # 93989
Correct. No machining of the rotor required for any 14 bolt hubs
Old 06-26-2009, 04:24 PM   #9 (permalink)
Member # 93989
Worse comes to worse just order the weld on brackets and stick them where you need them
Old 06-26-2009, 04:38 PM   #10 (permalink)
Member # 111241
yeah, I might just upen up the rotors cause my welder isnt top notch. Skills are there, just dont have the cash to buy a new machine cause I bought the bender and the 1 tons.
Old 06-26-2009, 05:43 PM   #11 (permalink)
Member # 12455
Fyi
Not all D70's share the same bolt circle at the axle flange. Chevy D70 and 14 bolt are on a 3.562 circle. Other D70's are on a 3.97 circle. 14 bolt hubs may not have the same offset at the flange. If your only option is a bolt on caliper bracket you will need to do your homework. I put my 75 Chevy rotors to the inside of the flange on the hub. I used a weld on caliper mount as they do not make a bolt on caliper mount for a dually 14 bolt with single wheel hubs. I'm also running unmodified H1's.
The devil doesn't live here. He's nextdoor.
dogbender is offline   Reply With Quote Quick reply to this message
Old 06-26-2009, 11:19 PM   #12 (permalink)
Member # 111241
I have a 70hd. I know that ruffstuff makes the brackets specific for this axle setup (d70hd GM dually). My concern was having to go get the rotors milled every time I replace them. I know they last a while but most of the machine shops around here are full of dicks who would charge good money to open them up 3/16".
I think I'm going to contact kurt at diy since he has the opened rotors on the shelf already. That way it just goes on. Simple enough and If need be I can always remove the brackets. I like kurts kit but I already have everything but the brackets. I do have the rotors off my other swap, but I figure I'll start fresh with milled ones from him.
Thanks for all the help though guys.
Old 06-27-2009, 10:42 AM   #13 (permalink)
Big91RustyBucket's Avatar
Member # 87635
Send a message via AIM to Big91RustyBucket
I have a 70HD I had Rear Disk's on the 70Hubs , and Currently Have Rear Disk's on the 14 Bolt Hubs.
Mine was a Dually 70HD. I am currently Running 14Bolt SRW Hubs , and GLO Weld on Disk Brackets.
Also I never Used any special rotors , just normal D44/10 Bolt 8 Lug Rotors.
~Philip
Midwestern 4x4 Parts
You've inspired me to start a build thread of my own.......... all the pictures will be upside down to reflect my driving style!
89 S10 Truggy
Big91RustyBucket is offline   Reply With Quote Quick reply to this message
Old 06-27-2009, 10:59 AM   #14 (permalink)
Member # 111241
I have the rotors layin around so after I clear out some junk Ill get around to test fitting the rotors on the hubs. The worst that could happen is I have to order new rotors from kurt, BFD. However, from what I can tell so far the hubs/drums/backing plates look identical.
This is probably similar to the differences that everyone runs into with the studs on a 14b swap. I have heard of people having trouble but my studs went in without grinding or modding them in anyway.
Old 06-27-2009, 11:02 PM   #15 (permalink)
REDDMANIAC's Avatar
Member # 5733
just grind the back of the hubs, I used a cutoff disc to basically cut slots(diceing) of metal out and ground the rest.
REDDMANIAC is offline   Reply With Quote Quick reply to this message
