chevy 6.0 temperature range - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-04-2009, 11:45 AM   #1 (permalink)
bluecrawler's Avatar
Member # 88448
What is a good temperature range for the 6.0 to run at? I think mine is running hot. At idle it is running 210-220 range. Is this to high?
bluecrawler is offline   Reply With Quote Quick reply to this message
Old 07-04-2009, 11:54 AM   #2 (permalink)
Member # 21453
seems a touch high, but keep in mind your gauge may be off as well. If you have access to a heat gun try that and look for any discrepancy between it and your gauge. You could throw a slightly lower thermostat in it and even add an auxiallary pusher fan.
that said, most automatics i see tend to run around 200-210 while standards run from 190ish-200/210. 220 isnt bad but its a little higher then i would like to see on my personal vehicle. I'd maybe do a coolant flush and while i was at it throw a slightly lower tstat in and go from there.
Kilborg is offline   Reply With Quote Quick reply to this message
Old 07-04-2009, 11:57 AM   #3 (permalink)
Bo185's Avatar
Member # 48545
That's normal they run that high for emmisons. You can get a lower stat but the temp. your seeing is OK 220 is getting hot though.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 07-04-2009, 12:40 PM   #4 (permalink)
lxh0318's Avatar
Member # 82770
X2, mine runs at 220 all summer long.
lxh0318 is offline   Reply With Quote Quick reply to this message
