np205 6x6 questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-02-2009, 12:32 AM   #1 (permalink)
Member # 40937
Send a message via AIM to damageinc2785
np205 6x6 questions
i just got a 1983 3500 4x4 DRW with a 6.2/turbo 400/np205
i want to make it 6x6
can i run a divorced NP205 backwards? the rear output would be the input and the front output and front input would face the rear and drive the rear axles. i know that i could only use 1 to 1 (high range).
also how much can i clock it without leaking problems?
thanks
frankie
p.s. i included this sweet artist rendering of what im building.
damageinc2785 is offline   Reply With Quote
Old 08-02-2009, 02:05 AM   #2 (permalink)
blazerboy85's Avatar
Member # 112787
so you want two rear driveshafts that overlap? how in hells bells did this even register in your mind? save yourself the headache an buy rockwells.....
WHEELING: THE MOST FUN YOU CAN HAVE WITH YOUR CLOTHES ON........1985 blazer 1980/82 trazer 02 LB7 2500HD 85 3500 crew cab
blazerboy85 is offline   Reply With Quote
Old 08-02-2009, 12:18 PM   #3 (permalink)
Member # 107883
Yep go with rocks...
[URL=http://www.pirate4x4.com/forum/showthread.php?t=871614]Plasma Table Build / Torchmate 2x2[/URL]
Chevy Build with 5TonRocks......Coming Soon.....:flipoff2:
JeepsRcool is offline   Reply With Quote
Old 08-02-2009, 12:23 PM   #4 (permalink)
Karnage
spidr's Avatar
Member # 55444
Search backwards 205, there's a few chevy's I can think of that did it.
Also search 6x6, as this has been covered many times lately, and pics and how-tos are all over the place.
I've read them all, but I'm way to lazy to search it for you.
Thanks to BAILEIGH INDUSTRIAL
Krush RT IFS/IRS
Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color]
https://www.facebook.com/KrushRacing
spidr is offline   Reply With Quote
Old 08-02-2009, 12:52 PM   #5 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
if youre too cheap to go with rocks, you can use a divorced NP200.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 08-02-2009, 03:19 PM   #6 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
you can but its not good for them.
Old 08-02-2009, 05:11 PM   #7 (permalink)
Heat Wrench Hero
ffp00ch214's Avatar
Member # 84582
is this gonna be street legal if so you might want to check on some DOT numbers i belive you need em if your running a live tandem
Four wheel peel!!
http://www.facebook.com/p00ch
http://www.facebook.com/HBDOR
ffp00ch214 is offline   Reply With Quote
Old 08-03-2009, 03:36 PM   #8 (permalink)
Member # 29210
Send a message via AIM to Davethorik
find one of these:
http://www.pirate4x4.com/forum/showt...865&highlight=
:laughing:
Davethorik is offline   Reply With Quote
Old 08-03-2009, 04:51 PM   #9 (permalink)
Member # 125848
yeah good luck. After reading that thread the guy came up with the conclusion that its not a production axle, its custom made by someone.
98ZJ is offline   Reply With Quote
Old 08-04-2009, 01:10 PM   #10 (permalink)
Member # 59100
You can find some NP??? tc's with 3 outputs. i have a couple in my old dodges. 1 in the center the other offset to the rear.
08 6.4 F250
73 Blazer 33's locked front Rear 56's 350/350/203
desertwheeler is offline   Reply With Quote
Old 08-04-2009, 01:43 PM   #11 (permalink)
Devout Newbie Hater
Member # 20147
That would be an np200 or np201
Old 08-04-2009, 03:23 PM   #12 (permalink)
cumminchevy's Avatar
Member # 112607
there is a guy back home i know... He took an 80's suburban and did what u want to do. Specs stock 350 he built a custom blow through turbo setup on/ SM465/ "2" np208's/ "2" SF14
he ran both NP208s output to output and a single U joint inbetween the two. then ran a two piece drive shaft to get over the first dif.
probably the most fucked ass shit Ive seen and drive he drives it on the street but he has never broke it.
looks something like this -------you know road grader style rear suspension
(Oh the power of paint)
77 K10 body, K20 frame, K30 axles cummins 12v getrag 5spd div.NP205 4.10 42" michelin X's
84 K30 quad cab,350,350,203,dueces,hemmt beadlocks,14.00 R20 XLs
cumminchevy is offline   Reply With Quote
Old 08-04-2009, 03:26 PM   #13 (permalink)
Member # 112607
sorry i forgot the Turbo setup and the hood stack
Old 08-12-2009, 02:48 PM   #14 (permalink)
Member # 59100
Thanks grumpy i thought that was it was but its been a while since i looked it up.
08 6.4 F250
Old 08-12-2009, 04:44 PM   #15 (permalink)
roy jones's Avatar
Member # 50585
check this out pics on last page
http://67-72chevytrucks.com/vboard/s...d.php?t=273722
while you are tempting to help re-establish ballistic this just proves more to the fact they flat out don't fucking care and should be shit upon at every turn.
roy jones is offline   Reply With Quote
Old 08-13-2009, 04:44 PM   #16 (permalink)
Member # 125756
You can make a NP205 have dual rear outputs using NP200 parts:
/forum/general-4x4-discussion/34892-np205-2-rear-outputs-done.html
marschmc is offline   Reply With Quote
Old 08-13-2009, 07:11 PM   #17 (permalink)
Member # 83976
I met a guy years ago that made a 6x6 ford using a 205 what he did was had a custom lower shaft made. On a 205 the rear covers have the same bolt pattern . So he had the lower shaft made to duplicate both the lower and upper shaft so he could run the standard upper housing on the lower witch gave him 3 yokes didn't say what it cost just said was not cheap.
the1208 is offline   Reply With Quote
Old 12-28-2009, 06:19 PM   #18 (permalink)
Member # 124076
hopefully this isn't bringing anything too painful back from the dead...but...I've got some questions...well...more so comments....
Dejomo is offline   Reply With Quote
Old 12-28-2009, 06:41 PM   #19 (permalink)
Member # 124076
Just plain craziness...6x4 style....
so has anyone mounted a divorced NP205 in the rear, high and to the center(on a pretty stout crossmember)? You could take a twin of the solid axle already living in the rear of your vehicle, turn it around and install some reverse cut, or front, gears in it. Next push the rear axle back, if possible. Run the front(or would that be the middle?) axle off the front out of the 205 and the rear most, or last, axle off of the rear out of the 205.
With this set-up you could have some pretty good choices as far as which drive axle(s) and what ratios.
any info/ideas reguarding this?
Thanks in advance.
Old 12-28-2009, 07:34 PM   #20 (permalink)
Member # 25964
Maybe you want to do something similiar to this:
http://www.olive-drab.com/idphoto/id_photos_wc62.php
If you can get a hold of the this manual, it has drivetrain schematics in it of the suspension and tc/driveshaft setup;
TM 9-1808B Powertrain, Chassis & Body
Maybe the manual is available online here: http://www.emilitarymanuals.com/3qtrtontruck.htm and here http://www.military-manuals.com/mili...ity_truck.html
lebowski is offline   Reply With Quote
Old 12-30-2009, 12:47 PM   #21 (permalink)
joshgammill's Avatar
Member # 123460
You must be from Wichita Falls. I just saw that OD suburban the other day and made my wife take a picture of it as we drove by. Didn't get to stop and check it out though. I will have to make here send that pic to me and I will post it up.
joshgammill is offline   Reply With Quote
Old 12-30-2009, 02:54 PM   #22 (permalink)
Member # 25964
I'd liket to see that OD Burb - sounds unique-ish.
Old 08-05-2010, 09:20 AM   #23 (permalink)
Member # 124076
post it!!!
Old 08-05-2010, 10:23 AM   #24 (permalink)
jeepcj's Avatar
Member # 20502
GMC M211 case
I have a M211 divorced case you could have cheap
jeepcj is offline   Reply With Quote
