my 98 blazer aka hunkojunk - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-07-2009, 08:36 PM   #1 (permalink)
chrissybf86's Avatar
Member # 68634
so my wife bought this 1998 blazer 4x4 4 door with intent to drive it but did not know that is was a peice of junk lol... i am a chevy fan and but man.. i am not shy to the crawling world or the wheelin word but this is my first s10 build
so right now i have the motor out of the blazer because it spun a rod bearing and took out the crank. i am in the process of rebuilding it. now that i look at the ifs it is crap the bushings are gone the balljoints are beat and the welds on the ifs are cracked. its weird because the blazer was driven buy some old guy and the thing is very clean.
My ideas are get rid of the ifs and sas it, ive built toys jeeps zuks you name it
now i have a hp 30 and 35 sitting in my yard is it worth it to put them in?? or run the 30/10bolt?? i know you have to redrill the rotors if you do that?? but are most of the gears ratios close to eachother? i can get my hands on a 44/9inc for cheap but what is diffrent in the swap.
ill build my own spring set up in the front and run a spring over f/r stick with the 4l06e and the 233/4.3
questions
how do you get rid of the abs?? do you just delete the abs box and plum in a valve? or jsut pull the fuse??
can you swap in a d30/35 and run it??
how do you adapt a diffrent front drive line?
i am building it for my wife so you can rag on me all you want
Adrenaline motorsports 08 evox 500+awhp 2.3 fp-red fully built clean sas runner build
chrissybf86 is offline   Reply With Quote
Old 10-07-2009, 08:43 PM   #2 (permalink)
Member # 103331
I vote D44/9"
Do not waste any time with a D35
Other than that, we need to know your style of wheeling, terrain, and tire size
pcampTJ is offline   Reply With Quote
Old 10-07-2009, 08:56 PM   #3 (permalink)
dfl701's Avatar
Member # 126764
you should just pull the fuse for the ABS.
83 k5 with typical rust
dfl701 is offline   Reply With Quote
Old 10-07-2009, 10:00 PM   #4 (permalink)
Member # 68634
i am a all around wheeler and i use to be hard on the skinny pedal but that has change. i am thinking 33-35's its mostly for the wife
Old 10-08-2009, 04:28 AM   #5 (permalink)
Banned
Member # 142724
How did you manage to spin a rod bearing??
Yes just pull the fuse for the ABS by federal law if it malfunctions (pulling the fuse lol) it has to revert to normal brakes.
I agree dont waste your time with the 30, or 35, if your gonna do it, do it right lol.
Also should swap in a manual in place of the juice box, but thats just me lol
You adapt a different front drive line by cutting off the IFS crap and attaching some leaf spring hangers and run a damn drive shaft to the transfercase, steering, brakes, I thoughe you built crap before, or maybe I mis understood your question lol
Gaslessyota is offline   Reply With Quote
Old 10-08-2009, 08:24 AM   #6 (permalink)
Member # 68634
i dont know on the bearing it jsut started knocking at a idle so i tore it down and sure enough it spun the bearing.
no it has that weird cv style drive shaft and no fixed yoke on the transfercase side. just splines is there a place to get a fixed yoke or adapter
i was thinking of using the 30/35 to set it up and get a rolling chassie that i like then going and finding a hp60/14bolt
Old 10-08-2009, 11:07 AM   #7 (permalink)
dfl701's Avatar
Member # 126764
using the axles you have would be a good idea. but if your only going to run 35s then why spend the money on a 60??
i would step up tire size since you know your going to want to when your done
Old 10-08-2009, 08:42 PM   #8 (permalink)
Member # 68634
yea the biggest i really want is a 37
what is a good spring for the front
i have a set of 52" rears i was thinkin of using or maybe some xj rears
Old 10-08-2009, 08:44 PM   #9 (permalink)
Member # 68634
is the older vortech v6 the same as the newer version?? i mean the bottom end i found a 92 or 93 blazer with the tpi style vortech v6 and the version i have is the cpi version
Old 10-09-2009, 10:21 AM   #10 (permalink)
Sticks and Stones
gmcxt's Avatar
Member # 115122
I would look into a diverside drop D44 and an NP231c w/ SYE.
Im debating hacking up my daily driver, a 95 s10 2door. Thinking about slider shackles up front and 52" all around.
Piss on everything I'm going four wheelin!
gmcxt is offline   Reply With Quote
