Gm alt question (voltage regulator) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-10-2009, 09:52 PM   #1 (permalink)
Member # 63309
so i have the 80s gm alt (10si 12si) one of those kind with the white 2 port plug on it.
Its wired up correct (not converted to "1 wire")
lug to battery, the one plug to idiot light, and other to 12v source for excite
for the last few days everything has been fine, but today i saw the gauges start to jiggle a bit. Then a little bit later it got worse.
The volt gauge would peg, then all the gauges would go crazy for a sec, then speedo would die, radio turns off, and the digital read out in the truck goes berzerk. then 10 seconds later everything will be back to normal.
does this sound like a voltage regulator intermittently being an asshole?
battery is good, and of course when i tested the alt it passed....damnit
Strange is offline   Reply With Quote
Old 10-10-2009, 10:23 PM   #2 (permalink)
Member # 80052
Send a message via MSN to the_experience3006 Send a message via Yahoo to the_experience3006
More information on the truck would help identify what kind of dash arrangement you're dealing with. If it's a completely digital dash I'd be far less inclined to believe it is an alternator problem than if you have an old mechanical dash.
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE]
[QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit.
[/QUOTE]
the_experience3006 is offline   Reply With Quote
Old 10-10-2009, 11:23 PM   #3 (permalink)
Banned
Member # 27003
Send a message via Yahoo to acprokeith
Charge the battery up and disconnect the Alt. If it continues its not the Alt.
acprokeith is offline   Reply With Quote
Old 10-11-2009, 11:51 AM   #4 (permalink)
Member # 80052
Disconnecting the alternator is fine if he doesn't have any electronic modules in the truck. The description of the truck doesn't really tell us that for sure. TBI era electronics are pretty robust, but the digital dashes are not and voltage spikes could really wreck his day. How about a simple test with a mechanical voltage gauge? You can probably get one for $5 at harbor freight and wire it up quick to keep an eye on system voltage when it happens.
[/QUOTE]
