Member # 122116
TBI question
IM getting a 92 chevy 3/4ton with a 454 and 5 speed! Im just curious if I was to put the throttle body injection off of it on my 396 if it would support the 380-400 horse power that the 396 makes? and is it worth the swap to put this in a older non fuel injected truck?
and yes I searched just didnt find any definite yes or no |
the 454 throttle body should be able to handle it... you will more than likely need to increase the fuel pressure however.
I am offended by reality all the time. My 1 ton fj60 build: /forum/toyota-land-cruiser/708363-fj60-build.html |
Member # 122116
hey kwtmech got any suggestions or pointers on doing this swap any pictures? and thats all i have been able to get so far is it should or I dont think so I want someone to chime in and say they have done it and their motor is similar hp. thats what Im hoping for anyway
Member # 70148
1) Go here and read the faqs. http://www.binderplanet.com/forums/f...splay.php?f=75
2) Install TBI 3) Build a cable for your laptop to data log, and buy the moates chip burner and some eeproms. modify the chips like you find on the BP so you don't have to spend a dime on adapters. 4) Learn how much nicer fuel injection is to drive than a carb.
I don't pay nothing for anything. [url]http://pirate4x4.com/forum/showthread.php?t=598612[/url] Last edited by larboc@hotmail.com; 10-21-2009 at 02:33 PM. |
there's no quick explanation... There is a ton of info on the web and in books available. JTR (jags that run) has a pretty good book help you start to get your brain wrapped around the process. http://www.jagsthatrun.com/OrderingBooks.html .
Third gen (kinda like a pirate forum) is also an excellent resource for info: http://www.thirdgen.org/techboard/
I am offended by reality all the time. My 1 ton fj60 build: http://www.pirate4x4.com/forum/showthread.php?t=708363 |
Member # 122805
I did some research on www.tbichips.com, and ended up using one of his chips for my build. I also looked at these guys for a better flowing tbi http://marine-performance-parts.com/...rgmtbi74l.aspx
In retrospect I would probably try to burn my own chip if I was to do it again so I could get the tune perfected for my motor.
Wheeler: 87 K5, 454TBI , 465, 208, d60, 14bff, a few cuts on the body, rolling on 39.5'sTowrig/DD: 05 Dodge 2500 Cummins, with a few mods/forum/chevy/769919-foolsized-blazer-build.html |
#9 (permalink) | |
Member # 70148
I don't pay nothing for anything. [url]http://pirate4x4.com/forum/showthread.php?t=598612[/url] |
Member # 130361
YES.
I have a carb to tbi swapped 468 in my buggy, not much to it really. You said you were just under 400hp, you will need for sure a bigger tbi unit and more fuel(pressure). Extreme efi, in texas and on ebay, does it pretty cheap. I would get the 850 cfm, that should support upwards of 500hp if you ever want a little more. From my own experience I would stay on the smaller side of the cams out there for BBCs. Don't bother buying the edelbrock intake, it's really only good for the stock head tbi motors, they have peanut ports. One more thing, 454s did not come factory with knock sensors until multi port. So if you run anything but a stock spec tbi 454, I would reccomend an isntall of a knock sensor. Actually pretty easy, just have to run one wire from ecm to esc(electronic spark control) module, the rest of the wires go from esc to negative ,switched hot, and knock sensor(I used newer delphi style), pretty easy. Fuel pressure, well if you can use an external pump, I would. Last longer and generally have higher than stock pressure. Also either homebrew adj regulator or aftermarket, you'll need 18-20lbs maybe. This is all assuming your making that much HP. In stock trim a TBI set-up will work on your motor without mods but, it will piss you of more than it will make you happy. Is your 396 square or oval port? Do you know cam specs? One more thing, 454s did not come factory with knock sensors until multi port. So if you run anything but a stock spec tbi 454, I would reccomend an isntall of a knock sensor. Actually pretty easy, just have to run one wire from ecm to esc(electronic spark control) module, the rest of the wires go from esc to negative ,switched hot, and knock sensor(I used newer delphi style knock sensor), pretty easy.
07' buggy, 468tbi, 44"boggers, lotsa tubing, 3-link, 89 C3500 ext. cab, 76 K20 4w disc crappy 33"s Last edited by mikenholly07; 10-26-2009 at 07:17 AM. |
#12 (permalink) | |
Member # 13786
#13 (permalink) | ||
Tactical Turtleneck
An alternative to chip burning is the EBL flash version. http://www.dynamicefi.com/EBL_Flash.php
#14 (permalink) | |
Member # 130361
07' buggy, 468tbi, 44"boggers, lotsa tubing, 3-link, 89 C3500 ext. cab, 76 K20 4w disc crappy 33"s Last edited by mikenholly07; 10-26-2009 at 10:16 AM. |
#15 (permalink) |
Member # 1684
No you can also increase pulse width. If you can increase pulse width enough to get where you want without the injectors going static you're better off than upping pressure too much. If you try to raise the FP too much and tune down the idle pulse with to compensate then you may run into idle quality issues.....
S.N.O.R.T. |
#16 (permalink) |
Member # 122116
the truck is a 79 I dont know cam specs! my dad built the motor and he past away about 3 years ago. I will find out when i do this swap I think i will have to to get this to run properly wont I ? I do remember that it was a crane grind and they quit doing this grind cause they were having issues with exhaust lobes going flat this was in the 80's and the oval port cylinders and intake manifold have been ported he built this motor to pull the cabover camper and our boat and he said he never had to downshift even going through the oregon mountains wich some are 6% for 7 or 8 miles
#17 (permalink) |
Member # 122805
I would suggest that if that cam has been discontinued for wear problems get a new one now so you have the cam specs and hopefully a cam that won't wear flat. Be a good time to do it while the motor is out and your swapping the intake.
Wheeler: 87 K5, 454TBI , 465, 208, d60, 14bff, a few cuts on the body, rolling on 39.5'sTowrig/DD: 05 Dodge 2500 Cummins, with a few modshttp://www.pirate4x4.com/forum/showthread.php?t=769919 |
#18 (permalink) |
Member # 122116
well the motor has been in there and running great for 25 plus years so i think the cam is not gonna go flat the #1 killer for camshafts is letting them sit for years and then not dumping oil to the motor through the valve cover before running it preferrably doing an oil change but my dad also told me he went through a whole shit ton of valve springs to find some good and soft ones for the exhaust side cause thats the side that was going flat this is what he did for a living was build engines so im pretty trust worthy of his work and love the way this truck pulls so f-ing hard in any terrain so changing the cam is not an option unless i nut up and go hyd/roller wich is gonna happen just not any time this year
#19 (permalink) |
Member # 122116
well the deal fell through so I didnt get the truck with the t.b.i. unit so any other suggestions on a fuel injection unit whats the best bang for the buck for a easy install as well as easy tuningand capable of say 500 hp
#20 (permalink) |
Member # 130361
TBI is the best bang for the buck set-up and very easy to install. I wouldn't worry too much about it, all you need is a BBC w/3spd auto wire harness with sensors and ecm plus, tbi unit, fuel pump and tbi distributor. Only four sensors to manage and one IAC. If you are wanting iit to support 500hp, you will like I said before, need more fuel and air. Which means larger tbi unit and more fuel pressure or custom chip.......I have run my injectors at over 24 psi for over 2 years with 0 issues. There are plenty of folks(like myself) runnnig Healthy big blocks @ 500hp with stock style tbi and have done it for less than 500-600 bucks in most cases, it can and has been done. If you want to spend lots of money and plug and play, go buy a kit with instructions and enjoy efi.
07' buggy, 468tbi, 44"boggers, lotsa tubing, 3-link, 89 C3500 ext. cab, 76 K20 4w disc crappy 33"s |
#21 (permalink) |
Member # 122116
well I got a throttle body set up minus half
of the wiring harnes and ecm but I have a complete wiring harness off of a small block here and the ecm off the small block i pulled myself off of a truck i recently parted out so all the sensors should work off of the small block and what about the ecm and harness if i replace the chip in the ecm it should work right ?
#22 (permalink) |
Member # 122116
well i been doing some research and it looks like the ecm that is most desirable due to the aftermarket availability is the 1227747 and mine is 312320232 so it looks like i need a new one but they arent to expensive just kind of nervous about buying that kind of shit after i hear about that jeff roberts guy in the other threads and can someone verify for me about the wiring harness's being the same for the big and small block and i need to know if the pinouts are gonna be the same for the two different ecms so i can use the wiring harness i have with the 1227747 ecm i am gonna get
#23 (permalink) |
Member # 130361
I think the ecm you have is a newer one for electronic controlled trans and they are wired differently in the harness. There are a couple places on web you can view harness corrections for diff ecm configs. I don't think they are too bad to do, or you could print off a pinout and do it yourself. Sensors vary year to year, you may have to splice. Hope that helps.
Try some periods and comma's.
#24 (permalink) |
Member # 130361
Go to thirdgen.org, there is way more tech on tbi stuff there.
