SAS question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-10-2009, 09:51 AM   #1 (permalink)
Member # 43563
SAS question
I am doing a SAS on my 2003 GMC 2500HD with a Dana 60 and leaf springs it is a DD/ tow rig.
I noticed alot of the high dollar kits talk about using Dodge axles and alot of people on pirate talk about using old 78/79 ford axles.
What are the pro's and cons?
I found a 1995 Ford dana 60 DWR with springs maybe I could use for $600
( I see very little Doge dana 60's for sale)
I also noticed nobody sells new or after market Hubs for a Ford Dana 60 Why?
( so I can convert to SRW)
I already own 2 trucks with Chevy Dana 60's I don't know much about Ford & Dodge
Thanks Rick
1978 Chevy Pickup 454cid 46" turf & fields Showtruck
2003 GMC crewcab Pickup Banks 6 Gun 6" lift 35" Tires
1984 Blazer cut up and welded back together..he..he
[URL="http://www.myspace.com/biorick"][COLOR="Blue"]http://www.myspace.com/biorick[/COLOR][/URL]
Biorick78 is offline   Reply With Quote
Old 11-10-2009, 11:06 AM   #2 (permalink)
Sticks and Stones
gmcxt's Avatar
Member # 115122
Buy the ball joint 60 for $600 Or take your rear axle and make a steering AAM 11.5 hybrid. Youllspend twice as much and have 3 times the brag factor.
post pics too
Piss on everything I'm going four wheelin!
gmcxt is offline   Reply With Quote
Old 11-10-2009, 11:13 AM   #3 (permalink)
Member # 40312
The kits you see that use the Dodge axle, use the 2003+ Dodge AAM front.
Once the aftermaket catches up, the Ford HP60 will have its first real competition in years.
The AAM front is also high pinion, 9.25" ring gear, 33 spline axle hub to hub. The reason they use this axle in the high end kits, is because the brakes/ABS sensors are all 100% plug and play with GM OE stuff.
2003/Ram1350/5.7L/545RF/D60/Spartan/S10.5/Detroit/5.13
2006/F250/6.8L/ZFS6-650/D60/S10.5/LSD/4.10
CowboyKyle is offline   Reply With Quote
Old 11-10-2009, 12:01 PM   #4 (permalink)
Member # 43563
Ok so those kits are based on new available products on Dodge trucks (that is why there pricey) and the old school way is the ford Dana 60
I see GMCXT is making fun of the 95 axle I guess it has ball jionts instead of king pins? (which I believe aren't as good) (the chevy ones I have are old style)
Anybody know the cut off date for king pin axles
also would it be worth taking a chevy Dana 60 and reversing the axle tubes to make a drivers side drop (I assume parts would be cheeper in the long run)
Old 11-10-2009, 12:13 PM   #5 (permalink)
Sticks and Stones
gmcxt's Avatar
Member # 115122
Im not makeing fun...I said buy it. But in true pirate fashion wouldnt you rather have an extra 2".....
on your ring gear, from a hybrid AAM?
post pics
Old 11-10-2009, 12:15 PM   #6 (permalink)
GMCTruxrule's Avatar
Member # 51243
The advantage to kingpin axles is that they wont blow apart if an axle shaft or u joint lets go, a balljoint axle could have the ball joints forced out.
Now, if this is more DD/towrig like you say, a balljoint axle will work fine.
Ford used kingpins 60s from 78 all the way thru 92.
92 and after got switched over to balljoint. I wouldn't waste my time trying to retube a GM 60 for what you are trying to get. I would just search for a Ford drivers side drop 60.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 11-10-2009, 01:07 PM   #7 (permalink)
Member # 43563
Ok I think you guys set me straight There is another guy selling a 85 ford dana 60 local for $1000 all ready set up SRW seems like it's worth the extra few bucks.
Now for educational purposes how come you can by chevy/dodge hubs brand new and I think even aftermarket but nowhere on the internet can I find Ford hubs unless there used (sounds like limited supply)
Old 11-10-2009, 01:16 PM   #8 (permalink)
Member # 21408
The reason for the newer Dodge AAM front axles is because of the front wheel speed sensors, i.e. keep ABS and whatever electrical nannies the truck has. It would likely require a decent amount of fabrication to come up with wheel speed sensors on any other axle.
Besides ABS, I'm not sure what, if any, issues losing the wheel speed sensors would cause (besides the ABS lights and such being on).
6.2Blazer is offline   Reply With Quote
Old 11-11-2009, 07:20 PM   #9 (permalink)
Member # 144592
When using the dodge aam 9.25 front for SAS duties, remember the cost to convert to manual locking hubs. Its thousands. Otherwise everything is always spinning on this axle.
Is it right to own and drive two 1996 GM L29 454 vehicles?
AndyL29 is offline   Reply With Quote
Old 11-12-2009, 07:54 AM   #10 (permalink)
Member # 83407
I would try my best to find a '78-'79 Ford Dana 60 because the 32" or so spacing between the spring perches works out much better than 36" spacing of the late 80's thru 90's Dana 60's. With the 78-79 axle you can inboard the shackle allowing you to keep the overall suspension lower and almost seems like it should have been a factory option. You would have to run the shackle under the frame if you use the newer axle and that would add about 7-8 inches of lift with flat springs and some huge drop hangers on the front of the frame.
I've done this conversion on my 2002 GMC 2500HD and I did all the fab work myself. No kit was used.
Check out my build thread http://www.gmfullsize.com/forum/showthread.php?t=92822 to see what I'm talking about. Feel free to ask any questions or let me know if you need some more detailed pics.
By-Tor is offline   Reply With Quote
Old 11-12-2009, 08:03 AM   #11 (permalink)
Member # 40312
I've not seen or heard of this happening on D60s. Got pics? On D44s, YES. Also, king pin knuckles NEVER break do they?
As opposed to drive flanges on a D60?
Old 11-12-2009, 10:52 AM   #12 (permalink)
Member # 51243
Seen a Dana 44 blow apart, never seen a Dana 60, heard of it from various members on here. Just passing on what I know....
Old 11-12-2009, 01:32 PM   #13 (permalink)
Member # 43563
Nice Job!!
It looks like you use old style rear GM shackles, great pic's that helps see how it lines up before I get into the project. I wasn't crazy about tucking the shackles in frame like that although it seems to work well. I was thinking about putting the shackles up front to eliminate the height problem and the back spring perch under frame.
Old 11-12-2009, 05:15 PM   #14 (permalink)
Member # 83407
Yeah, the shackles look like stock chevy rear shackles but I built those myself. They're a bunch stronger than factory shackles. No problem with running the shackles inside the frame. It's no different than running the rear shackles on the outside of the frame. Mounting the shackles up front will alright work since that is how the F-350's from the late 80's thru mid 90's were set up from the factory. The only downfall is that those trucks ate up shackle and track/panhard bar bushings and didn't ride as smooth as trucks with the shackles at the rear of the spring.
Old 11-12-2009, 05:30 PM   #15 (permalink)
Member # 7011
Send a message via AIM to Ten_Bucks Send a message via MSN to Ten_Bucks Send a message via Yahoo to Ten_Bucks
By-Tor, how is the body roll on you rig if there's any at all since you're not running a sway bar? If there isn't any body roll, is it because of those springs you built?
Scott
[URL="http://facebook.com/tenbucks76"]http://facebook.com/tenbucks76[/URL]
Ten_Bucks is offline   Reply With Quote
Old 11-12-2009, 07:12 PM   #16 (permalink)
Member # 83407
There is actually no more body roll than when I had the ProComp 6" kit cranked to 8" and factory sway bar. The truck corners really well for it's size. I've put 20,000 miles on the SFA and pull trailers frequently. The truck is my daily driver and I really couldn't be happier with the results.
Old 11-12-2009, 09:01 PM   #17 (permalink)
Member # 7011
Thanks for the info.
Scott
Old 11-13-2009, 09:19 AM   #18 (permalink)
mackthehack's Avatar
Member # 138346
I did my swap with an 89 ford d60. My shackles and hangers are inboard of the frame rail. I had someone machine the hubs so I could run a speed sensors and tone rings. With this axle it has the wider spring mounts, which limits the turning radius... unless you run spacers, different offset wheels.
Like stated before... stay away from the ball joint axles, due to the weakness of the ball joints. The aam is a decent axle but still ball joint, and not a lot of aftermarket support. And they do not have locking hubs, but you can buy them for about 2k.
sas'd lbz with stuff
embrace the hate with a fistful of steel
mackthehack is offline   Reply With Quote
Old 11-13-2009, 10:12 AM   #19 (permalink)
JohnnyU's Avatar
Member # 74068
Originally Posted by mackthehack View Post
...I had someone machine the hubs so I could run a speed sensors and tone rings.
Do you have pictures of the machined hubs and sensors? This is the biggest hang-up with swapping an older axle into my 2004 Dodge... I don't much care for the $2K price tag on the dynatrac free-spin kits, so I'm searching for alternative methods.
Tow Rig - 2004.5 Dodge 2500 CTD
Trail Rig - 1991 Chevy K1500 - D60/14FF
JohnnyU is offline   Reply With Quote
Old 11-13-2009, 11:37 AM   #20 (permalink)
Member # 40312
Would you care to show me a pic of broken D60 ball joint and/or knuckle?
I can show you plenty of broken king-pin stuff if you wanna make it fair.
Old 11-13-2009, 03:43 PM   #21 (permalink)
Member # 138346
I do not... Trevor at WFO did this for me. He might have some pics.
Old 11-13-2009, 03:53 PM   #22 (permalink)
Member # 138346
I guess its not fair then... I don't have pics. Just word of mouth from everyone that I have talked to about front axles. Before I did the swap on my truck.
Old 11-13-2009, 05:31 PM   #23 (permalink)
Member # 40312
"Word of mouth" is sometimes wrong.
In this case, its a steaming pile of BULL SHIT.
Competitors and F550s use ball joints. Dynatrac 60s come with ball joints. Them being "weaker" is just false. If anything, they're stronger when you add high steer to a stock king pin knuckle, however, as more D44 style (mill/drill) high steer options become available for BJ 60s, they may prove to have the same flaws as the king pin knuckles.
Old 11-13-2009, 06:15 PM   #24 (permalink)
Member # 138346
I wondered why the Dynatrac axles were ball joint. Even though being told they were weak by some reputable shops.
Learn something new everyday...
Old 11-14-2009, 06:11 AM   #25 (permalink)
Member # 83407
Mackthehack, do you have any pics of your conversion or a build thread?
