cummins into chevy - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-24-2009, 06:17 PM   #1 (permalink)
Member # 136354
cummins into chevy
I bought a 1984 chevy crew cab 3+3 4x4. It has a 454 turbo 400 and a
np205. I want to swap a 12 valve cummins into it. The truck has 4:10's so I would like to have a 5 speed it in for an extra gear for milage. The th400 would be great but the adapter's are expensive and it is not overdrive.
What Is the best way to get what i want on somewhat of a budget?
spongebob2 is offline   Reply With Quote Quick reply to this message
Old 11-24-2009, 06:28 PM   #2 (permalink)
bf
Member # 131367
take your time gathering parts, deadlines are expensive. do lots of research on cummins websites where it has been done, like 4btswaps.com. own a lot of tools already so you can do it all the fab work yourself. cheap cheap would be an 89-93 cummins beater with the getrag 5 speed. having the whole truck to swap from will eliminate a lot of scrounging for little parts. good luck from a guy on a similar journey
bf is offline   Reply With Quote Quick reply to this message
Old 11-24-2009, 06:34 PM   #3 (permalink)
Member # 123514
Bargon shop
Oh and do it yourself.
I don't build it pretty I build it to function.
frikenwoodro is offline   Reply With Quote Quick reply to this message
Old 11-24-2009, 07:07 PM   #4 (permalink)
Member # 140610
Look in the JY for a 89-93 rolled w250. Has just about everything you need.
chevalade is offline   Reply With Quote Quick reply to this message
Old 11-24-2009, 11:20 PM   #5 (permalink)
Member # 95754
89-93 12v 5speed (Getrag and passenger drop NP205) for sure. Tight budget and engine swaps don't exist but the drive train in these years is going to be your best bet for saving money. Buy a donor truck and you'll be set...
-79 Hilux
-98 UZJ100
Rot Box is offline   Reply With Quote Quick reply to this message
Old 11-25-2009, 10:21 AM   #6 (permalink)
Member # 136354
That is what I wanted to hear!! Thanks
Not really tight budget just don't want to have a mint wraped up in it
Old 11-25-2009, 11:52 AM   #7 (permalink)
Ten_Bucks's Avatar
Member # 7011
Send a message via AIM to Ten_Bucks Send a message via MSN to Ten_Bucks Send a message via Yahoo to Ten_Bucks
Check out Tennessee Diesel Conversions, Destroked, and the diesel section of coloradok5.com. Also check out cumminsforum.com.
Scott
Ten_Bucks is offline   Reply With Quote Quick reply to this message
Old 11-25-2009, 02:32 PM   #8 (permalink)
pvkj454's Avatar
Member # 73302
I should have started with a crew dually like you. I soon will be cutting my Cummins powered M1008 up and building a crew dually.
There are several ways to do it but I used a Freightliner engine, Dodge NV4500 with a Chevy tail housing and output shaft to work with my round bolt pattern Chevy transfer. I used a Duramax radiator and modified Duramax intercooler.
The 89-93 Dodge engine mounts can be modified and slots cut in your Chevy frame pads for the Dodge rubber mount studs.
more photos:
http://s244.photobucket.com/albums/g...mmins%20M1008/
pvkj454 is online now   Reply With Quote Quick reply to this message
Old 11-25-2009, 03:10 PM   #9 (permalink)
mikevyota's Avatar
Member # 91662
Yeah, good luck!!
Find a good used truck that's running, but has a nasty interior and body. There out there, but most are still working everyday. Take your time and find the right truck, as all the little things will be there. Cummins swap's are the way to go!!
04.5 Dodge 2500 Cummins, 79 Bronco, 06 Raptor 700R
---DesertRunner Fabrication---
mikevyota is offline   Reply With Quote Quick reply to this message
Old 11-25-2009, 09:26 PM   #10 (permalink)
Member # 136354
I plan on doing this build next winter.. I have to finish my scout/buggy this winter. Going to keep my eye's open at the local farm sale's
Old 11-25-2009, 10:33 PM   #11 (permalink)
mikevyota's Avatar
Member # 91662
Found you a couple donors. I might have to keep the second one for my self!!
They're both in St. George, UT. You get the Cummins plus some 1-ton axles you can sell or swap.
http://stgeorge.craigslist.org/cto/1462714806.html
http://lasvegas.craigslist.org/cto/1470991604.html
Old 11-26-2009, 06:07 AM   #12 (permalink)
Member # 136354
Thank's but I am in IOWA
Old 11-26-2009, 08:57 AM   #13 (permalink)
mikevyota's Avatar
Member # 91662
Guarantee they'd make it there.
Old 11-26-2009, 08:59 AM   #14 (permalink)
Member # 136354
Very true
Old 11-26-2009, 08:25 PM   #15 (permalink)
Member # 136354
I have seen it may need a body lift and maybe lift springs.
I also seen a thread on here (i think) that did it with no lift and the guy was selling the cross member for 500.00. Anybody seen such a thing?
Old 11-27-2009, 05:46 AM   #16 (permalink)
b454rat's Avatar
Member # 16536
Yep right here. Thinking of going this route myself.
http://coloradok5.com/forums/showthread.php?t=249756
1999 GMC CCSB plans for 8.1 and SAS
b454rat is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 07:07 AM   #17 (permalink)
mikevyota's Avatar
Member # 91662
Lift springs depend on how much tire you want to run. I've seen swaps without a body lift, but some of the motor is pretty tight under the cowl.
Avalanche Engineering sells this crossmember to bolt the Cummins into your Chevy. $399.
http://www.avalancheengineering.com/xmember73-91.html
Old 11-27-2009, 09:38 AM   #18 (permalink)
Member # 136354
What does this crossmember do? Move the motor up down front back???
Also that truck has 5 spring's in the pack the one I bought has 3. Will the motor be to heavy for 3 leaf's? I have a set of 4 inch lift spring's but if I can help it I don't want a lift at all.
Old 11-27-2009, 10:16 AM   #19 (permalink)
Member # 27166
What tire size do you plan on using with the 4.10's I have a 94 12v in my crewcab with 4.10's and 35's. used to have 31's and wasn't enough at highway speeds so I swapped to 35's I also have a US Gear splitter behind my nv4500. If you can fab I wouldn't waste your money on the pre-fabbed mounts and crossmembers they aren't that hard to make yourself. But I try to strech every dollar. I am in my truck $5500.00 and that includes the price of a 2wd crewcab, motor, trans, overdrive, d60, 205, southbend clutch, guages, exhaust, gov springs, and rims and tires.
twistedjack is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 10:31 AM   #20 (permalink)
Member # 136354
I realy don't want much more than stock high tire. Stock tire wind the motor to tight? I kinda thought a 5 speed would fix that problem but I have alot to learn.
I gave 1700.00 for the truck and have the 454 turbo 400 and np 205 sold for 1000.00
Old 11-27-2009, 10:35 AM   #21 (permalink)
b454rat's Avatar
Member # 16536
That link is for 0 lift. Also the one that Avalanch is selling is a copy of the this one.
Old 11-27-2009, 10:59 AM   #22 (permalink)
Member # 136354
OK but why does it allow you to use 0 lift?
Old 11-27-2009, 11:01 AM   #23 (permalink)
Member # 102123
I'm assuming for people that don't want to lift their truck
[QUOTE=monkeyevil;10413721]Tranny's are the gateway drug to gay.[/QUOTE]
72 Chevy 454/465/205 33's
89 Chevy Suburban 454TBI/400/205 6" Procomp lift on 37's
94 Chevy ext. cab 350/4L60e/241 6"BDS lift,35" MTZ's
randy92782 is offline   Reply With Quote Quick reply to this message
Old 11-27-2009, 11:46 AM   #24 (permalink)
Member # 27166
with a stock tire you will be wound up tight at 65 and say goodbye to any mileage if you want a stock tire you need around a 3.55 gear ratio IMO I had 31's with the 5speed and the us gear in overdrive and 65 was 1800 with out the usgear in overdrive it was 2200-2300 and I lost about 7mpg with 35's and driving in my top gear (double overdrive) 67 mph is arond 1600 and I get 28mpg
Old 11-27-2009, 01:05 PM   #25 (permalink)
Member # 136354
How much lift does it take to fit 35's under a 1 ton?
Where can a guy buy this over drive?
