Backwards Intake? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-04-2009, 10:13 PM   #1 (permalink)
Member # 146361
Backwards Intake?
I've searched and searched, tired of reading. I've found plenty of people running their 6 liter intakes backwards. Is it just as simple as turning it around or does the gaskets and/or fuel rails need to be turned with the intake? Just wanna do it right the 1st time round... THANX
PooSlanger is offline   Reply With Quote
Old 12-05-2009, 05:10 PM   #2 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
lol.... yer funnay.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 12-05-2009, 06:30 PM   #3 (permalink)
Bad Doctor
Odin K30's Avatar
Member # 86878
Ive heard upside down is the hot ticket.
-Vinny
-from Elizabeth
Nobody cares about your rigs specs...
"Me too" short Crew build
/forum/chevy/994394-odins-me-too-short-crew-build.html
Odin K30 is offline   Reply With Quote
Old 12-05-2009, 07:00 PM   #4 (permalink)
Flatline's Up!'s Avatar
Member # 103814
it only works if you use a heat gun and a dremel w/the 80grit sanding drum for a little forming and have to drill 4 extra holes, and use super copper gasket material sprayed on the intake seat as well as the rest of the mounting surfaces, but you have to let it pre dry for 9 days prior to trying to set it, then once it's on you may have to give it a tap or two with a 5lb sledge and then when you put the bolts on, you have to stake them or use Stage8 Super lock washers to keep all that coolness from coming apart at the seams.
good luck and take plenty of pics for us to look at
Flatline's Up! is offline   Reply With Quote
Old 12-06-2009, 05:48 PM   #5 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
Just turn it around you can even reuse the gaskets.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
GM Gen III/IV V8 swap info
TECH: Gen III/IV "LS motor" to Early GM Auto Trans
Bo185 is offline   Reply With Quote
Old 12-08-2009, 04:20 PM   #6 (permalink)
just4cuz's Avatar
Member # 98655
If you found so many folks doing it then why don't you ask them how they did it?
In my experience unless you got a Nailhead Buick you won't be flipping any intakes around on a V8 engine.
just4cuz is offline   Reply With Quote
Old 12-08-2009, 05:31 PM   #7 (permalink)
fuck off
randy92782's Avatar
Member # 102123
You'll have to swap heads. The drivers side to the passenger and vice versa. Of course this puts your exhaust manifolds backwards also so swap those. Seeing as you've already turned everything around change the spark plugs as well. Oh and be sure to put the wires on right. You don't want it firing on the wrong cylinders at the right time
It's really easier since you're already backwards to change up a few things like your speech practices.
say this 5 times fast and i think you'll get it down
King illegal forest to pig wild kill in it a is!
Originally Posted by monkeyevil View Post
Tranny's are the gateway drug to gay.
72 Chevy 454/465/205 33's
89 Chevy Suburban 454TBI/400/205 6" Procomp lift on 37's
94 Chevy ext. cab 350/4L60e/241 6"BDS lift,35" MTZ's
randy92782 is offline   Reply With Quote
Old 12-08-2009, 08:04 PM   #8 (permalink)
Member # 98511
what a bucket full of dicks. those smart ass answers might have been funnay if any of you assholes actualy knew that YES YOU CAN SIMPLY TURN AROUND THE INTAKE & bolt it back down w/throttle body in rear. bo185 was right
mmk5blazr is offline   Reply With Quote
Old 12-08-2009, 09:01 PM   #9 (permalink)
Member # 123514
Send a message via AIM to frikenwoodro Send a message via Yahoo to frikenwoodro
Sorry we don't like to spoon feed people here. Ask a dumb question get a dumb answer.
I don't build it pretty I build it to function.
frikenwoodro is offline   Reply With Quote
Old 12-08-2009, 09:16 PM   #10 (permalink)
Member # 103610
Send a message via AIM to jeep937
Find the thread titled, Slinky Blue Balls, Read entire thread. Report back.
jeep937 is offline   Reply With Quote
