Gm Dana 60 brake question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-14-2009, 11:58 AM   #1 (permalink)
Member # 119208
Hey this is a random question, but what isn't on this site.
I'm in the process of rebuilding my GM Dana 60. Got new loaded calipers and cleaned up the mounting bracket. What size bolt /threads through the caliper to secure it to the bracket? Or if no one knows, what has worked for folks in the past w/ the hardware missing?
Just curious, because this will be helping stop my rig.
Thanks
Your face
JM1914Tn is offline   Reply With Quote
Old 12-14-2009, 12:18 PM   #2 (permalink)
Member # 109276
Is the bracket threaded? If its the type that I'm thinking of a pin goes through the piston side of the caliper and then through the bracket and then through the "non-piston" side of the caliper. I might be off track but the caliper has to float to allow movement.
'73 Scout II on 14" jackstands.
StuartTX is offline   Reply With Quote
Old 12-14-2009, 12:38 PM   #3 (permalink)
Member # 119208
un- threaded, to the best of my recollection.
Your face
Old 12-14-2009, 01:20 PM   #4 (permalink)
Bazinga!
nvrenuf's Avatar
Member # 10903
GM calipers do not have a bolt going through the caliper itself, only a small allen head bolt that goes through a hole in a slide under the caliper.
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
Build Pics & Build Thread
happy..happy..happy....
nvrenuf is online now   Reply With Quote
Old 12-14-2009, 02:13 PM   #5 (permalink)
GMCTruxrule's Avatar
Member # 51243
What nvrenuf is referring to is the Bendix style brakes found on the GM Dana 60s.
And correct in that it doesn't use bolt/pins like the Dana 44 and the 10 bolt does.
The caliper interlocks with the bracket by design, utilizing a keeper bracket and anti-rattle clip to hold the caliper in place. A 5/16th"x20 Allen head bolt locks the keeper bracket in place.
You can find the new Allen head bolts online, made specifically for the Dana 60. But I have used a regular 5/16ths hex head bolt as a replacement.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 12-14-2009, 03:39 PM   #6 (permalink)
Member # 119208
thank you kindly sir!
Your face
