Has gas but wont start after 8 hours??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-04-2010, 07:05 PM   #1 (permalink)
Member # 93256
Send a message via Yahoo to 25tkempker
My 03 gmc yukon won't start when low on gas and sits for over 8 hours. If it sits for a few hours it fires right up. When it doesn't start dump a few gallons in and it fires right up. Is this the fuel pump?
25tkempker is offline   Reply With Quote
Old 01-04-2010, 07:16 PM   #2 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
Could be fuel pump on the way out. But change the fuel first filter.
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
GM Gen III/IV V8 swap info
TECH: Gen III/IV "LS motor" to Early GM Auto Trans
Bo185 is offline   Reply With Quote
Old 01-04-2010, 08:25 PM   #3 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Is your gauge accurate? could be the sending unit isn't dropping
all the way down, and the fuel leakdown leaves the sump dry.
"Safety and security mean nothing without liberty." JamToy.
History teaches that all conquerors who have allowed their subject races to carry arms have prepared their own downfall by doing so.
-- Hitler, April 11 1942
Originally Posted by Roxywheels View Post
...... Shove a tissue in her nose, don't kiss her and hump on. ......
HAPPYJOHN is offline   Reply With Quote
Old 01-04-2010, 11:07 PM   #4 (permalink)
Member # 74407
Dont know how much searching you've done here or on Google but the answer is out there.
This is a common problem. There is a check ball in the sending unit that holds the fuel pressure after the engine is shut off. Over time these crack and the fuel pressure bleeds off.
Couple of steps to verify:
1. If after sitting for a long period of time (overnight), cycle the key about 3 times, 3-5 seconds on, then off, then on 3-5 seconds, etc. See if it it'll fire off.
2. Verify fuel pressure at fuel rail. After sitting for a long period of time, you should still have good pressure, and when the key is turned on, there should be approx. 55psi
Do this, report back.
TireFryerSS is online now   Reply With Quote
Old 01-05-2010, 12:51 PM   #5 (permalink)
Member # 93256
It just had a tune up, all filters and sensors replaced. I have checked the rail and the pressure is good. I'll have to try cycling the key(should it fire up?).
I have looked alittle but havent found much other then maybe a bad gas cap.
Does anyone know of a CHEAP fix?
