14 bolt - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-02-2010, 04:03 PM   #1 (permalink)
Member # 145385
14 bolt
hi guys..i am using a 14b ff in my build...the axle i purchased,when i tore it down, it appears to have a crack on the spindle where the inner bearing rides..is this common? it looks like the PO ran it with a bad bearing for a while...anyone run into this? thanks
Rich
SoupCan is offline   Reply With Quote
Old 02-02-2010, 08:26 PM   #2 (permalink)
Banned
trkklr77's Avatar
Member # 29016
no its not common.
Old 02-02-2010, 09:14 PM   #3 (permalink)
Member # 94248
cracked or grooved?
Dick Hangin' Balls Dragin' Racing
craigbassett44 is offline   Reply With Quote
Old 02-03-2010, 04:26 PM   #4 (permalink)
Member # 135241
if its cracked start stripping that axle then trash it. get another and use the other parts as spares. if its badley grooved i would still do the same. no since in wasting your time with a halfass axle, know what i mean
who said it couldnt be done?
chvyracing08 is offline   Reply With Quote
Old 02-03-2010, 05:25 PM   #5 (permalink)
GMCTruxrule's Avatar
Member # 51243
Man, with your sig line, I would have figure you would have told him to booger weld it up, angle grind it smooth and run it.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 02-03-2010, 07:53 PM   #6 (permalink)
Banned
trkklr77's Avatar
Member # 29016
that sounds like a plan, fuckin do it. its not like its a fiction surface or the wheel will wobble.
