Member # 74066
700r4 & th350 first gear swap
Can you swap the first gear (or first through third gear) out of a 700r4 and put it/them into a th350 so you can have the 3.06 first gear instead of the 2.52 first gear in the th350? I only thought of this because I thought I saw someone mentioned they had a special 700r4 first gear in their th350 somewhere on this site, but can't find it now. I already have a th350, so please don't tell me to just go get a 700r4 instead, I don't wanna buy one and the new adapter for it to my dana 300. So, if anyone has any idea, or has any links to further info from anywhere, It'd be awsome. Thanks.
'92 YJ, 4.6 stroker, dana 300 w/4:1, 60's, 5.38's, detroits, 101", 40" MT/R's, KMC Beadlocks |
Member # 25927
subscribed
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here Dana 60 front 3/4 ton kits $350--> click here |
Member # 105334
not that i know of, simply because the low/rev clutchpack rides on the rear planetary gear and the planet in a 700 is different than one in a 350. the 350 just rides on the output shaft with a bushing while the 700 has the hub of the input ring gear splined into it
unless someone out there makes a custom one, or you can switch the actual gears from one to the other and the rear ring gear i dont see how you would be able to swap it. nevertheless i am curious so i will be watching to see what people say (if there is something out there)
88 ChevyK1500 SAS with D60's,35spl,spool rear,ARB front,5.86 gears,350ci,700r4,NP203/205,42TSL, H1's |
Sticks and Stones
Member # 115122
Search "project blue bitch" user katesoffspring says he had one machined to fit.
edit: http://www1.pirate4x4.com/forum/show...ect+blue+bitch
Piss on everything I'm going four wheelin! Last edited by gmcxt; 04-15-2010 at 10:39 AM. |
