Dana 44 Polisher
Member # 13731
School me on 1985 454 tech.
I've never owned a Chevy, but now have a 1985 454 out of a 1 ton.
I'm planning to put it into my Scout and put fuel injection on it. I've done TBI swaps before so I know how that works -- but my question is what should I really do? Do I swap to TBI? Is there a better injection option? I generally hate engine work - so I'd rather not tear the whole thing apart. I figure even in stock form it will make my current IH304 look like silly. I've done some searching but I know so little about chevy stuff I get turned aound and sent down the wrong path and waste a ton of time. Are there intakes for my motor that are setup for TBI? I can bust out an adapter plate but I'm sure the aftermarket has it covered and probably claims to improve performance...
Buy my stuff!!! High Pinion Dana 44 for an Early Bronco Almost brand new 39.5x13.5x15 IROKS |
Member # 15257
edelbrock makes a tbi intake and they make a aftermarket tbi set up. i know holley does also.
1984 CUCV K30 "it went bang" means "its fucked". [url]http://www.pirate4x4.com/forum/showthread.php?t=900026[/url] My Build Thread. |
Devout Newbie Hater
GM made tbi's for 454s. its a factory setup.
I have a couple of the throttle bodies sitting on a shelf if you cant find one.
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! |
skullfuckery
Member # 29016
a factory setup has a piss poor hp output.
a cam, headers and a better fuel system and you will have a great runner.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
Member # 9467
The GM 454 TBI's have an adapter between the manifold and the TBI. This adapter allows you to use a stock quadrajet carb manifold and literally bolt the TBI on.
I also have two complete Vortec setups with harness and computers. These will bolt on to your setup also. There isn't anything special about a 454 over a small block, just displacement. Any of the reputable aftermarket companies make a product that will work well on your rig. The biggest issue you'll have is troubleshooting when there is a problem on the trail. With the TBI setup you can swap a carb on and run it. Not possible with the Vortec setups. Not sure on the aftermarket kits. |
Member # 154067
im thinking that 85 454 has the peanut port heads that are worthless as can be if it where me id find a set of large oval ports off an older bbc and use them peanut ports for a boat anchor but id pull the casting # and make sure first. but then again idk what your plans for the rig are
88 long bed 4x4 79 c10 shortbed stepside hotrod..rip |
#7 (permalink) | |
Dana 44 Polisher
Member # 13731
So you'd guess that my '85 has the same intake as the '87 TBI units? That would make things easy. No point in changing the intake if the factory didn't do it.... I'm sure an aftermarket intake would make more HP - but that would be something I'd do down the road.
Bad Doctor
Member # 86878
What are your plans for this engine?
As stated the peanut port heads are less than impressive for horsepower production. But that engine stock IIRC puts out about 400 lb ft of torque.
-Vinny -from Elizabeth Nobody cares about your rigs specs... "Me too" short Crew build /forum/chevy/994394-odins-me-too-short-crew-build.html |
Member # 51243
with the right cam, peanut port heads can work great for building low end torque.
My 454 is at the machine shop right now, I decided to dump the PP heads and use my 702 casting heads. Its gonna be a little more mid range power driven than my original set up.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
Member # 9467
The vortec heads are a good swap for good low end torque and good midrange power. They don't flow well enough for high RPM use but are much better than the peanut port heads. I believe there is a conversion gasket available so they can be used on the MarkIV's.
#11 (permalink) | |
Member # 9467
#12 (permalink) | |
skullfuckery
Member # 29016
my 454 in my 4x4 has peanuts that were smoothed out and cleaned up, it does pretty good.
#13 (permalink) | |
Dana 44 Polisher
Member # 13731
It rides around on a trailer most of the time, maybe a trip to the mini mart down the street but not much farther.The truck weighs about 5200 pounds as is. The IH 304 and 454 weigh about the same - but the 400/205/D60 out weigh the T19/D300/D44 so I'm shooting for 5500 pounds ready to roll.
#14 (permalink) |
Member # 17680
Put a stock BB TBI on it and be done then...You will be happy with it for a crawler.....the closer to stock it is, the better the driveability.....when dealing with TBI. Try to use the '87 harness and computer chip too if you can, I dont remember for sure what years were the same as '87, but the first couple of BB TBI years did not have a knock sensor or module....just makes the wiring cleaner when retrofitting into another rig.
'50 m38, 60, 14bolt, 4.3, 420, dana 300, 35" krawlers on trailready's/ '80 Blazer 60,14 bolt, tpi 350, th400, 205, 35" swampers Link to my M38 build: [url]http://www.pirate4x4.com/forum/showthread.php?t=703554&highlight=willys+m38[/url] |
#15 (permalink) | |
Member # 52376
#16 (permalink) | |
Dana 44 Polisher
Member # 13731
![]() Please.... I'd have a better chance of buying it myself then waiting on you guys.
#17 (permalink) | |
Member # 52376
Perfect, you buy it and i'll borrow it, that was our plan the whole time!
