e brake cables axle swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-23-2010, 07:39 PM   #1 (permalink)
haulin or crawlin
tufluv82toy's Avatar
Member # 34807
Send a message via AIM to tufluv82toy
workin on a 67 chevy 3/4 ton. Was a 2x4 now is a 4x4 with a 60 up front and a 14bolt ff out back with 05 2500 hd springs. I am looking for the best way to hook up the e brake cables. The 14 bolt cables are still there out of the drums but appear to be too short. I converted the 67 from the hand pull e brake to the foot e brake pedal out of a 71 pickup. Basically i need all the cables to get from the foot pedal to the 14 bolt ff. Anyone have any ideas on what truck I can rob to get something that will work or what company that may sell a universal kit I can make work? Any pics of your set ups? Any help will be appreciated. Thank you, TTL
tufluv82toy is offline   Reply With Quote
Old 03-23-2010, 08:08 PM   #2 (permalink)
yblow's Avatar
Member # 155086
Ill take some pics tomorrow of what i did. I dont remember what parts i used but once i look at it it should come back to me. But i did buy some parts/cables from lmctruck parts and classicparts.com If you also post a pic of yours i could probably help you better also.
yblow is offline   Reply With Quote
Old 04-02-2010, 01:36 PM   #3 (permalink)
haulin or crawlin
Member # 34807
cables
anyone have a chance to take pics of their e brake set ups? Lookin for best option still would think i could use a 71 or 72 long bed cable set up but not sure if will work with the 14 bolt rear....
Old 04-02-2010, 06:24 PM   #4 (permalink)
Member # 22551
www.tsmmfg.com/
idk if this will help, but somewhere on this site i saw a link for custom e brake cables
welcome to the valley!*front drivelines not required*
derail is offline   Reply With Quote
Old 04-02-2010, 06:41 PM   #5 (permalink)
REDDMANIAC's Avatar
Member # 5733
lokar, see summit racing. I have the universal kit that you basically cut to fit after youve measure it all out of course. simple. My only thing is I have acable on each side that goes to a backet/cable casing holder snd then its supposed to be joined by a couple on each side end then a single cable running from the center of the trans xmember where the pull is even on both sides, well Id like to get a ballend on the cable end.
REDDMANIAC is online now   Reply With Quote
Old 04-02-2010, 07:33 PM   #6 (permalink)
Member # 143694
I have some pics of one I did at www.twistdmetal.com then click TM projects on the left then click the Sub. the brakes are in there. I tried to post just the pic but would not let me.
Twistd Metal is offline   Reply With Quote
Old 04-03-2010, 02:44 PM   #7 (permalink)
REDDMANIAC's Avatar
Member # 5733
Do you think the brass block with the tension screws are trustworthy? Just asking since youve used it already and I have the same basic cables, but Im running the cables up each individual side.
