napco eaton front end re build, cut n turn, beef up - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-28-2010, 10:10 PM   #1 (permalink)
Member # 112787
started teardown yesterday and went from there. the axle seals i pulled out of it were leather seals from the old days which have been leaking and letting water pour in since the first trip. ill let the pics do the talking
WHEELING: THE MOST FUN YOU CAN HAVE WITH YOUR CLOTHES ON........1985 blazer 1980/82 trazer 02 LB7 2500HD 85 3500 crew cab
blazerboy85 is offline   Reply With Quote Quick reply to this message
Old 03-28-2010, 10:14 PM   #2 (permalink)
Member # 112787
manual locking warn hubs
axle shafts
housing
super old leather seals
Old 03-28-2010, 10:17 PM   #3 (permalink)
Member # 112787
grinded out plug welds since i dont have a one inch drill bit
drivers side knuckle and ball off
axle tube
size comparison
PS knuckle
Old 03-28-2010, 10:21 PM   #4 (permalink)
Member # 112787
passenger side 2 piece knuckle
closed ball inner knuckle, kingpins?
upper kingpin brass bushing and race.
Old 03-29-2010, 01:54 AM   #5 (permalink)
Member # 112787
i think im going to turn the pinion up from zero degrees to 25 degrees but ill have to do a little bit of figuring once i get new spring perches
Old 03-29-2010, 06:30 AM   #6 (permalink)
Member # 86878
Are you reusing the front axle shafts?
What are the dimensions?
Too bad they look to be neck down.
-Vinny
[COLOR="Black"]-[/COLOR]from Elizabeth
[COLOR="Black"]Nobody cares about your rigs specs...
[/COLOR][COLOR="Lime"]"Me too" short Crew build[/COLOR]
^^ Parting Out ^^
Odin K30 is offline   Reply With Quote Quick reply to this message
Old 03-29-2010, 06:22 PM   #7 (permalink)
Member # 147836
how do these front axle compare to dana 60s or d44s? i know where one is for cheap
blown xj is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 04:28 AM   #8 (permalink)
Member # 112787
chopped off the old spring plate (PITA) and stopped by ruff stuff today to pick up some new ones and got the angles to where i wanted and burned em in a little pit
Old 03-30-2010, 04:30 AM   #9 (permalink)
Member # 112787
yea im reusing the front shafts. but i may get new inner shafts made by sombody, maybe some 300m's
Old 03-30-2010, 04:33 AM   #10 (permalink)
Member # 112787
IMHO they are what i would consider a true 3/4 ton front axle. so that would make it inbetween a 44 and 60. it has so far never given me a problem besides having wayyyyy too leaky axle seals. and i have harped on it quite a bit. but id like to lock it sometime soon,
Old 03-31-2010, 04:55 AM   #11 (permalink)
Member # 112787
started hacking off the cast in spring perch on the passenger side today. lots of steel to chop off, but i think im going to plate all around the spring perch on the housing and shit just to be sure im not weakening it. also took my old seals to napa today and they were able to cross reference them for me and get them delivered in an hour. good shit. will have pics of shit tomorrow
Old 03-31-2010, 10:54 PM   #12 (permalink)
Member # 112787
got the perch on passenger side welded on. cut the welds on the passenger side knuckle and turned it then tacked it. tomorrow ill weld it all up for good. then its just reassembly and fab.
Old 03-31-2010, 11:40 PM   #13 (permalink)
just4cuz's Avatar
Member # 98655
Looking good. Those Rzeppa joints in the ball are stronger than u-joints IMO.
just4cuz is offline   Reply With Quote Quick reply to this message
Old 04-01-2010, 12:13 AM   #14 (permalink)
77k5's Avatar
Member # 35786
All depends on how the joint is designed
Care to take measurements of the shafts (say, largest and smallest diameter, diameter at splines, number of splines, etc.)?
We specialize in full size Chevy parts but if you need steering, transfer case gearing, suspension etc. for just about anything give us a call!
970-945-7777
77k5 is offline   Reply With Quote Quick reply to this message
Old 04-01-2010, 02:23 AM   #15 (permalink)
Member # 112787
yep no problem, ill do it tomorrow. you are 38377k5 over at ck5, no?
Old 04-01-2010, 10:28 AM   #16 (permalink)
77k5's Avatar
Member # 35786
Yep
970-945-7777
Old 04-01-2010, 01:54 PM   #17 (permalink)
just4cuz's Avatar
Member # 98655
A Rzeppa is designed just like a CV joint.
Old 04-01-2010, 03:20 PM   #18 (permalink)
77k5's Avatar
Member # 35786
Yep
But stock Toyota Birfield joints are pretty weak while some of the others that use that design don't suck so much. CV's (Rzeppa, whatever) aren't inherently bad, depends on how they're sized/designed.
970-945-7777
Old 04-01-2010, 08:28 PM   #19 (permalink)
just4cuz's Avatar
Member # 98655
I've never seen one break. Who is selling these as Dana 60 u joint replacements, Longfield? I'll stand by my original statement stronger than u-joints, especially ones of comparable size. The Rzeppa/CV design has more articulation and strength size being equal than a u-joint.
Old 04-02-2010, 01:09 AM   #20 (permalink)
Member # 112787
Yep
nice to see you fartin around over here, the measurements are......
inner shaft: spline that goes into the third is 17 and 1.5 inches diam, at the neck down it is 1 1/8 inches in diameter, the spline that goes into the birf is 12 splines and 1 3/8 in diameter.
birf and stub shaft: birf is 4 inches in diameter the stub diameter not at the splines is 1 1/8, and the diameter at the splines is 1 1/4 and is has 16 splines
and i see where you are coming from just4cus on the joints being stronger than a conventional u joint because there is more points of engagement
Old 04-02-2010, 01:24 AM   #21 (permalink)
77k5's Avatar
Member # 35786
I have no clue how stout these cv's are but this is a typical birfield failure:
970-945-7777
Old 04-02-2010, 01:32 AM   #22 (permalink)
Member # 112787
cleaned up the housing and third and painted it all. threw it under the truck and as you can see my pinion angle issues are solved....
Old 04-02-2010, 01:33 AM   #23 (permalink)
Member # 112787
whats the diam on toyota birfs?
Old 04-02-2010, 01:36 AM   #24 (permalink)
sas'd96TAHOE's Avatar
Member # 138362
Looks like shit, i'll trade you my 44 for it.
Sas'd 96 Chevy Tahoe. 44 front/Eaton rear, 4.56's, open, 37" hummer tires.
sas'd96TAHOE is offline   Reply With Quote Quick reply to this message
Old 04-02-2010, 01:56 AM   #25 (permalink)
Member # 112787
not a chance
