Help with Turbo-Hydra-matic Transmissions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-12-2010, 08:35 PM   #1 (permalink)
Member # 33918
Hi guys. I have 3 transmissions that I'm trying to determine exactly what they are so I can accurately describe them to sell. One is on a '78 Suburban so after getting some previous help from some Mud members I assume it's a TH 400. The tag says Either "G" or "C" on the left and "H" on the right. In the middle it has a "78" and then on the same line it's stamped "369". On the bottom of the tag it is stamped "79-CH 18986" It is stamped "Hydra-matic Div. of GMC" on the bottom of the pan.
Transmission #2 has a tag that also says Hydra-Matic on the top and then a "C" on the left of the tag, a "P" on the right of the tag and in-between it has "78" and then it's stamped "374". The bottom of the tag says "78 -CP- 18555.
Transmission #3 has a square pan. I couldn't find any tags but there are large "K"'s stamped into the housing and "MD 8" and I also found a "1" stamped into the housing.
Thanks, appreciate your help!
77 FJ40 94 Celica 95 Toyota 4X4 01 4Runner 06 Tacoma Sport
Dianna is offline   Reply With Quote
Old 04-12-2010, 09:09 PM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
th400 pan looks like texas
th350 pan is square with one corner knocked off
700r4 pan is square.
k is the "stronger" castings usualy found in 4wd stuff.
trkklr77 is online now   Reply With Quote
