4.3 vs. 5.3 weight comparisons - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2010, 08:20 PM   #1 (permalink)
Member # 83110
Well anybody got any?
[COLOR="DarkOrange"][QUOTE=threadkiller;12444189]I have no problem fishing a man made lake. And man made tittays are fine by me.[/QUOTE][/COLOR]
Fleetwood is offline   Reply With Quote Quick reply to this message
Old 04-25-2010, 10:58 PM   #2 (permalink)
Member # 154067
i looked and came up with this 4.3 comes in at 425 and all i could find was ls1 weight witch is 460 but its aluminum and the 5.3 has an iron block so idk
info came from here
http://www.bacomatic.org/~dw/library/txt/engfyi.htm
88 long bed 4x4
79 c10 shortbed stepside hotrod..rip
nastys10 is offline   Reply With Quote Quick reply to this message
Old 04-26-2010, 04:18 AM   #3 (permalink)
Member # 158688
y not just split the difference and get the 4.8?? but i really dont now how much lighter it is than the 5.3
trail11591 is offline   Reply With Quote Quick reply to this message
Old 04-26-2010, 08:16 AM   #4 (permalink)
Member # 88919
Maybe 2-3lbs, at most. Drop Obama's kids off at the pool before hopping in your rig and you'll have negated any real weight difference.
The only real difference is the shorter throw crank, longer rods and flat top pistons. All else is the same between the 4.8 and 5.3 unless the 4.8 was a manual (early years).
[COLOR="Lime"][I]At 1300rpm's would you rather have 10 extra hp or 10 extra lb-ft of torque?[/I][/COLOR]
Rinkrat456 is offline   Reply With Quote Quick reply to this message
Old 04-26-2010, 10:08 AM   #5 (permalink)
Member # 83110
4.3 v6 verse 5.3 v8
Old 04-26-2010, 12:50 PM   #6 (permalink)
Bo185's Avatar
Member # 48545
425 for the 4.3L vs the 5.3L iron block will weight 500 or so fully dressed. The iron block adds 70-100#'s over an LS1 which is 430#'s or so.
The 5.3L Long block will weigh 450#'s.
The L33 AL block 5.3L will weigh about the same as the LS1.
Good weight thread!
http://forums.hybridz.org/index.php?showtopic=59086
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
Bo185 is offline   Reply With Quote Quick reply to this message
Old 04-26-2010, 02:06 PM   #7 (permalink)
Member # 88919
Originally Posted by Fleetwood View Post
4.3 v6 verse 5.3 v8
I was referring to trail11591's post.
Old 04-26-2010, 06:17 PM   #8 (permalink)
Member # 158688
yeah sorry bout that i just threw it out there then kinda realized they are basicaly the same motor
