LS1 bogs when shifts into 2nd gear at WOT - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-27-2010, 06:54 AM   #1 (permalink)
Member # 62903
Send a message via AIM to prostock3
Ok i have a ls1 factory computer and such. My issue is when im at WOT it runs strong in first gear all the way to redline, and when it shifts into second its bogs really bad and feels like its missing. Its not a traction controll issue since this motor is in a buggy and all that stuff has been removed. The motor now if i come off the gas and floor it after its doing this will run fine. It has k&n airfilter, and block hugger heads, it does run o2 sensor and mass air flow. Fuel pressure is correct and it does have new spark plugs. Any ideas?
trans is 4l60e
2009 Twisted Customs buggy (sold :C) -----2001 Donzi 38zx -----2004 Duramax 2500 CC
prostock3 is offline   Reply With Quote
Old 04-27-2010, 12:00 PM   #2 (permalink)
Beaver Pleaser
florida4x4's Avatar
Member # 13645
Do you have any way to log the fuel, timing and O2? kinda hard to make any judgements without it.
1972 GMC Submarine
383 / TH350 / 203D-NP205 / D60 / 14FF / 42's on Stazworks / heavy foote / four eyez
Inclined to brute force attack a 70* incline with a Quadrajet
1997 GMC K3500 Suburban
454 / 4L80E / HP60 SAS / PROJECT TOWHOE
florida4x4 is offline   Reply With Quote
Old 04-27-2010, 02:40 PM   #3 (permalink)
Vortec Scout II
Bo185's Avatar
Member # 48545
Plus, what RPM is redline?
Any SES lights?
'73 Scout II Vortec 6.0L 4L65e np241
'73 1210 Travelette SV392, T-34, 60/14bff 4.56's 35's
'01 VW Beetle TDI-50mpg or better!
GM Gen III/IV V8 swap info
TECH: Gen III/IV "LS motor" to Early GM Auto Trans
Bo185 is offline   Reply With Quote
Old 04-27-2010, 09:30 PM   #4 (permalink)
Member # 14187
My K5 does that when it's low on fuel. I have a huge 31 gallon tank and if I take a corner fast or accel fast and it's low on fuel that always happens to me. Gen III's love lots of fuel and lots of fuel pressure. I have a Walbro 255 that helps things along.
Blackdog76 is offline   Reply With Quote
Old 04-27-2010, 10:07 PM   #5 (permalink)
Member # 88919
For diagnostic purposes, could you turn off DFCO if it isn't already?
How are the spark tables between shifts?
Is all TQ management disabled?
Falling on it's face between shifts is usually spark related, however the statement you said about fuel pressure being correct made me wonder how you know that? How was this pressure tested? (I ask because I had plenty of pressure at idle but at WOT only 36psi = bad pump and too small injectors)
[COLOR="Lime"][I]At 1300rpm's would you rather have 10 extra hp or 10 extra lb-ft of torque?[/I][/COLOR]
Rinkrat456 is offline   Reply With Quote
Old 04-28-2010, 06:53 AM   #6 (permalink)
Member # 62903
Ill get a fuel gauge on it again, shouldnt it be around 50-60psi? what is DFCO? the computer was done by jims performance
Old 04-28-2010, 09:03 AM   #7 (permalink)
Member # 88919
DFCO is fuel management between shifts. Fuel pressure in the upper 50's at WOT is best. My factory pump is rated at 62.4PSI at 34.5GPM. At WOT it doesn't drop below 58psi.
