Member # 146945
Need A Little Help With SAS
Im in the middle of an SAS on my '89 GMC K1500 and need a little help from some of the guys that have done it with the Sky kit already. A few specs are:
Sky Mfc. hanger kit, basterdized Rough Country spring packs good for 2-3" of lift, late 70's 3/4 ton D44. My question regards the driver's side shackle hanger, there's a relief cut out in the hanger for the transmisson shift linkage, but in my case its not cut out enough. Iv searched through here quite a bit and all the pictures I can find have the shift linkage removed and the hanger moved partially over the hole it came out of, but I couldnt find any information that helped. Now I was planning on notching the hanger (it needs to move about 1/2"-1" forward) so that I can slide it forward around the shift linkage, but I figured I would ask the people that have done it already first. So my question is how did those of yall that encountered this problem handle it? The whole reason I am moving the hanger is to improve my shackle angle (which only needs to swing back about 1/2"). Iv got my axle centerline pretty much where I want it so I dont want to move the front crossmember back any. So any opinions ? Notch the shackle hanger or other suggestions? Here are a few pics just for comparison: ![]() ![]()
Member # 85758
I used the sky kit a few years ago on mine, and if memory serves. I think the "v" cut out on the rear hanger should line up with the "V" on the frame, where the box section ends. Then adjust the front mount back and forth to get the right shackle angle. Mines a '90 3/4 ton frame so it might be different. Also mine is a manual tranny. But still goes on in the same way. If you can't move them, then start grinding, those things are beefy as hell IMO. I ground some of the shackle out to get more angle out of mine and have had no problems. Hope this helps a little.
#4 (permalink) | |
Member # 146945
Member # 20053
get some pics of from under the truck looking at the hanger
98 K2500 SAS dynatrac pro rock 60, ORD high steer, RCV CV's, arb's front and rear, 4.56 gears 06 D Max Express |
Member # 146945
I will when I get to work on it again (hopefully tomorrow afternoon). Iv pretty much decided to go ahead and notch a hole out for the transmission shift linkage in the hanger. I had tossed arounf the idea of moving it (linkage) or trying to make a way to mount it to the hanger, but I figure it would be easier to just notch the hanger.
Here is a picture of the problem Im having; it is not mine but almost exaclty the same, I borrowed it from a post by a guy on here: http://i1012.photobucket.com/albums/...E/IMG_0671.jpg If you will notice the hole in the extreme top of the picture (center approx. 1" diameter) that is half covered up by the shackle hanger; that is the hole the transmission shift linkage goes into and apparently that guy had the same problem I do, but I dont know how he resolved it. |
