need some true dual exhaust pics - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-02-2010, 10:55 PM   #1 (permalink)
Member # 142230
post up your underside dual exhaust setups, i need to see some ideas to work around my tcase an crossmember. im trying to do my exhaust myself and i cant find any good pics showing what you guys have done. my mufflers are going to be dynomax straight thru resonators and i am debating turning them down or running them all the way back.
1976 K5, 90 Burb, 89 S10
nerotxc is offline   Reply With Quote Quick reply to this message
Old 05-02-2010, 11:17 PM   #2 (permalink)
Member # 62107
I can probably go out and get some pics if you want. It's a 95 k1500 with turndowns on the pass side in front of the rear axle. What are they going into?
flip124 is offline   Reply With Quote Quick reply to this message
Old 05-02-2010, 11:17 PM   #3 (permalink)
trkklr77's Avatar
Member # 29016
dont just turn them down, give them some tail to dirrect it out from unde rthe truck. your head will explode from the resinance that turn downs tend to create.
trkklr77 is offline   Reply With Quote Quick reply to this message
Old 05-02-2010, 11:20 PM   #4 (permalink)
Member # 62107
Yeah. Something else to think of. I'm putting pipes out the back sometime soon. I bought it that way and it's LOUD, enough to set off car alarms. Sounds good with my semi built 350 though.
Some shitty cell phone pics I just took. The exhaust is exposed on the underside for wheeling but I don't care. This is my DD/work truck/tow rig.
The driver's side exhaust runs under the tranny and the two pipes run side by side on the inside of the passenger frame rail.
Old 05-02-2010, 11:46 PM   #5 (permalink)
Member # 142230
YouTube - 03 cobra, straight piped
im no stranger to loud exhaust, i just need to have a direction to start mocking things up. i dont want to get it caught 4wheeling and i dont want to place it where i will have issues.
thanks for the pics!
Old 05-03-2010, 12:03 AM   #6 (permalink)
trkklr77's Avatar
Member # 29016
it is easier to do if you have 3/4 length headers not fulls.
every brand and set are different, the collets will vary in height and distance that the end and you will have to figure it out on your own.
just get 3-4 U and 2 sticks of straight pipe and you will have to peice it from there to get a true high and tight fit.
fwiw i fucking hate exhaust shops, they dont give a fuck. they will run pipe and hangers every goddamn dirrection. i had to chop a guys exhaust out a few weeks ago because the cocksucken exhaust shop put a H pipe in it 3" behind the tcase and the entire syystem from manifold to tips was one fucking peice!!!!
Old 05-03-2010, 06:21 AM   #7 (permalink)
Member # 146945
I got mine run around the passenger side to avoid having to route the drivers side around the T-case and gas tank. If your careful and locate them right theres plenty of room down the passenger side frame rail to run two 2 1/2" pipes. After mine pass the gas tank, they just split off to their respective sides.
tlrbucnasty is offline   Reply With Quote Quick reply to this message
Old 05-03-2010, 07:15 AM   #8 (permalink)
flatblack83's Avatar
Member # 121277
On my 83 i have full length headers with ball flange 3inch collectors. I bought a pair of older camaro (94) front pipes that is 3inch and bends on a 90 and bolted that to my collector,(runs perfect asside the trans over the xmember) then ran 3inch pipe from that into flowmaster super 44s also 3inch in and out. Then right to the bumper and bent it to 35 degrees so you can barely see it. All the pipe was ran even with the frame rail so you cannot see it. I do have a really worked up 350(358)and need the 3inch tho.
1st pic if you look behind the shackle you will see how the pipe come out of the header and goes up on a 90.( a little hard to see)
2nd how it comes at the rear behind the roll pan. (cut off now so its only 2inches past the roll pan)
...1983 chevy stepside
358, propane, d60,14b 456s, 465/205,
53 inch alcans, diy4x shackle flip 52s.
39-15-15 boggers
...2003 chevy 2500hd
6.0/4l80e/np241/d60/14b/513s
4link, king coilovers, radflo bumps, bds leafs
37/12.50/16.5 mtr's
flatblack83 is offline   Reply With Quote Quick reply to this message
Old 05-03-2010, 08:27 AM   #9 (permalink)
Member # 113084
Here's my old setup with the 350, I just used that cheap, flexible exhaust tube for a while cause I didn't want to spend anytime bending exhaust tubing when i was going to have to re-do it more than likely with a doubler. I'm glad I did that cause now I've swapped in a completely different motor and I'm just going to run it all into one muffler when I'm "done".
'75 Chevy Truggy...5.3/350/203/205/d60/14b
87 4runner 14b/44, dual cases, 39.5's, exo
leeman1790 is offline   Reply With Quote Quick reply to this message
Old 05-03-2010, 08:47 AM   #10 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
i hope yer having better luck with that flex pipe then i did, i ran it for a while on a old ford i had just like you did and it would rot out every year
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote Quick reply to this message
Old 05-03-2010, 08:48 AM   #11 (permalink)
Member # 113084
It sucks ass, but I wasn't planning to use it long enough for it to rot.
Old 05-03-2010, 11:09 AM   #12 (permalink)
Member # 142230
thanks guys. i am gonna get under the truck today and figure it out.
Old 05-03-2010, 11:19 AM   #13 (permalink)
Member # 14187
My old magnaflow setup. Mac F-body midlengths, 2.25 pipe, and Magnaflows. Then I clocked the case up and had to take them off.
But I did go to F-body long tubes that actually fit better than the Macs.
Blackdog76 is offline   Reply With Quote Quick reply to this message
Old 05-03-2010, 12:50 PM   #14 (permalink)
Member # 142230
exhaust shop wanted 200 just for the pipe and i weld it myself. lol.
Old 05-03-2010, 02:55 PM   #15 (permalink)
Member # 14187
If your going to build your own check ebay for a small lot of rejected mandrel bends and buy a straight length of pipe from summit racing. That's what I did when I built mine. I ran into the same thing. My exhaust shop wanted $90 for one mandrel bend. I ordered 9 of them off ebay for 50 shipped.
Old 05-03-2010, 04:24 PM   #16 (permalink)
Member # 142230
good call! i wasnt gonna pay that. it wouldnt be much more for them welded at that price
