Trimming Down 4.3 V6 Wiring Harness To Its Basics... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-09-2010, 09:18 PM   #1 (permalink)
Member # 154419
Red face Trimming Down 4.3 V6 Wiring Harness To Its Basics...
Hey everyone, I am transplanting a 1991 4.3 TBI Chevy V6 in to my 1986 Sami Buggy.
I got the engine from a 1991 Astro Van and when I took the engine out I took the whole wiring harness and the computer.
Is there any information out there on how to chop this harness down to just the basic crap needed to run the engine without all the other crap that is on the harness?
I could litterally spend DAYS figuring this out but if someone knows of a guide or something that someone has already done online that would be helpful. Any searching I have done has not turned up anything worthwhile for me.
Howell Engine Development makes a basic harness exactly what I need but it is $350.00 !!!
Thanks, C
4wheeling is offline   Reply With Quote Quick reply to this message
Old 05-10-2010, 08:26 AM   #2 (permalink)
Member # 80727
Thanks, C
For the time your gonna spend peeling that harness apart $350 isnt much IMO. Plus it will look cleaner and you can route it however you like.
If your still gonna do it yourself the place to start is with a wiring diagram. First throw out all the wiring you have that doesnt go to the ecm. Then pick through the ecm harness for unnecessary option you wont be running like AC idle up signal etc.
Tube frame S10 Truggy
4.56 Dana 44 w/ lockright/6 lug Ford 8.8 4.56 Ox locker
r0nin89 is offline   Reply With Quote Quick reply to this message
Old 05-10-2010, 08:27 AM   #3 (permalink)
KyleQ's Avatar
Member # 83837
Doing the same exact thing - looking for the same exact info. Hopefully there is a good guide out there for ignition, crank and fuel wires.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60, Powr-Lok 70U - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 43" TSL SX on H1 Beadlocks
KyleQ is offline   Reply With Quote Quick reply to this message
Old 05-10-2010, 08:38 AM   #4 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Lil' John's TBI harness thread:
http://www.pirate4x4.com/forum/showt...ht=tbi+harness
Bill USN-1:
http://www.binderplanet.com/forums/s...ad.php?t=45293
TBI FAQ:
http://www.binderplanet.com/forums/s...ad.php?t=47254
guidolyons is offline   Reply With Quote Quick reply to this message
Old 05-10-2010, 01:02 PM   #5 (permalink)
Member # 154419
Those links are going to be a huge help! Thanks!
Old 05-10-2010, 01:27 PM   #6 (permalink)
Member # 278
Actually, most aftermarket harnesses force you into putting things where THEY want. They put things like the distributor timing plug where they want. You get a fixed trunk length. You are also forced to use all the accessories and ECM that the aftermarket made the harness was made for. MOST aftermarket harnesses do not have provisions for smog related equipment. This is based upon my experience with a painless harness.
There are many pinouts for the ECM plug. And that depends upon the ECM type.
The clean issue depends upon who is doing the modification on the harness. If the OP is patient, he can clean the harness up and loom it to look just as good as if not better than an aftermarket harness.
One benefit of using the stock harness that came with the engine is one knows the engine ran with the harness.
Playing with a TBI harness is about as easy as it comes. There are a few systems as shown in the linked article. The hardest part is the fact that some of the systems are tied together.
-1971 FJ55(aka Trail55): 6.0L-NV4500-LC split case, SOA, D60s, ARB'd... and cupholders
-1972 FJ55(aka Trail50): Turbo 5.3L-4L80-Blackbox-split case, D60s, ARB'd *stalled*
-1968 Mustang Fastback: not a restore but a refresh
Lil'John is offline   Reply With Quote Quick reply to this message
Old 05-10-2010, 01:31 PM   #7 (permalink)
Member # 103621
See if you can get your hands on the COMPLETE wiring harness manual from a dealer or EBAY or friend, ect. My book is around 200 pages. Hopefully you labeled which connector went where, and just start removing the wires from the labeled accessories you wont need. I left the engine harness alone for the most part. I grabbed the specific wires I need to run my Summit Gauges, and that was about it. When I installed my '93 CPI, i did this and ran every accessory that I needed on switched relays and fuses. I run an E2000 external fuel pump and swapped out the 4l60e to a th350. The only thing I have switched from the original harness is ECM, headlights and a push button start. Everything else was removed. I think a TBI only needs like 4 or 5 wires to start and run. Search for Crash, as he has done several 4.3l swaps and does very very clean installations.
1982 Toyota - Dirt Squirrel - LQ4/Atlas 4.3, D60/14b w/ Reids & RCVs, 3-link/4-link, 43" stickies
the_white_shadow is offline   Reply With Quote Quick reply to this message
Old 05-10-2010, 01:51 PM   #8 (permalink)
Member # 13731
Originally Posted by the_white_shadow View Post
. I think a TBI only needs like 4 or 5 wires to start and run. .
Run yes. Run correctly NO. You need a lot more wires to make it work correctly. BUT using the directions linked above it will take you about 1-2 hours to clean up the harness and another 2 hours to wire it up to the vehicle. It is SO EASY - don't waste your money on an after market harness that doesn't have all the options you may need.
My TBI system in my Scout had a knock sensor, speed sensor and full OBD1 diagnostic plug capability - it was like it was still in a Suburban... Try that with an aftermarket setup...
uglyscout is offline   Reply With Quote Quick reply to this message
