pic-will this pto fit a SM465? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-17-2010, 12:42 PM   #1 (permalink)
Member # 49108
Guy that has it doesnt know what it came off of, anyone know?
Please, Thanks
suprdave737 is offline   Reply With Quote
Old 05-17-2010, 12:45 PM   #2 (permalink)
Member # 137644
Send a message via MSN to HEAVY METAL
id geuss.. yes. match it up too the cover on ur tranny if possible.
WHEELIN A P40 WARHAWK
HEAVY METAL is offline   Reply With Quote
Old 05-17-2010, 12:51 PM   #3 (permalink)
GMCTruxrule's Avatar
Member # 51243
I don't know...that straight cut gear isn't going to mesh with any of the counter shaft gears in the trans. The only straight cut gears are for reverse, and if I remember correctly, they aren't accessible from the PTO port.
maybe someone else here is a PTO expert. Worst case, drain the trans, pull a cover and check the fit. It might work.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 05-17-2010, 04:10 PM   #4 (permalink)
Member # 29210
Send a message via AIM to Davethorik
JUST BECAUSE IT HAS 6 BOLTS DOESNT MEAN IT WILL JUST MATCH UP TO YOUR APPLICATION
:laughing:
Davethorik is offline   Reply With Quote
Old 05-17-2010, 04:11 PM   #5 (permalink)
Member # 130928
Judging by the hydraulic pump on it, it's off a heavy truck, an eaton fuller trans. Find out what they fit on.
86 Silvy - 355/TH350/208/60F/12bolt(14FF Soon)/4.56s/37x13 Boggers
ryan_thompson87 is offline   Reply With Quote
Old 05-17-2010, 04:43 PM   #6 (permalink)
Member # 83920
Here's a bit of advice.
If you don't know what the fuck you are talking about, don't offer advice.
I can virtually guarantee that it will "match up to the cover"
I'm also about 99 percent certain that it will not fit a 465.
The bolt pattern is standard, so quite obviously, it will match up, but the gears have to mesh as well, and every tranny is different.
Hopefully, you learned 2 things today. One about giving advice, and one about PTO's.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self.
dahoyle is offline   Reply With Quote
Old 05-17-2010, 05:40 PM   #7 (permalink)
Member # 49108
So maybe to fit a sm465 it would need to just have one angle cut gear centered in the unit, and this double gear unit is probably for something else huh?
Old 05-17-2010, 08:12 PM   #8 (permalink)
Member # 51243
its what I am thinking...and don't mind Dahoyle, he is actually a really friendly guy
Old 05-18-2010, 04:40 AM   #9 (permalink)
Member # 83920
Damnit, don't blow my cover.
Old 05-18-2010, 06:36 AM   #10 (permalink)
Member # 137644
maybe i worded it wrong... tryin too say drain, pull and see too confirm...have a nice day..you need it!
Old 05-18-2010, 04:18 PM   #11 (permalink)
Member # 83920
Maybe I read your response wrong.
Nope, you said that it would probably work, if the bolt pattern was the same.
I'm pretty good at the whole reading and comprehension thing, and there is a world of difference between
"id geuss.. yes. match it up too the cover on ur tranny if possible"
and
"drain, pull and see too confirm"
Old 05-18-2010, 04:20 PM   #12 (permalink)
Member # 138801
looks like its off an eaton fuller big rig trans..... i doubt the gears will meash with the sm465....
geo in a K5 is offline   Reply With Quote
Old 05-18-2010, 04:39 PM   #13 (permalink)
Member # 140636
It looks like it's an old parker or dana pto. Is ther a tag #?
If not there will be a number on the gear. You may be able to change just the gear to make it mesh and gear. Now if the pump will work that's another different story.
If you find some nunbers let me know I've got a bunch of books at work on these.
thedog is offline   Reply With Quote
Old 05-18-2010, 07:42 PM   #14 (permalink)
Member # 83976
cant tell you if it will work or not put I can tell you this if the gears mesh and you decide to run it make sure you set the back lash on the gears this is accomplished buy stacking the gaskets it you just jam it on there with some sealant bad things can and will happen
the1208 is offline   Reply With Quote
Old 05-18-2010, 10:24 PM   #15 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
Chelsea made the PTO for Dana/Spicer. they have a website that you can look up the numbers on. you can also find out what gear you need and if it will fit on your trans application.
thats your best bet. I did a bunch of research a few years ago on their site, and they had good info then.
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 05-18-2010, 10:33 PM   #16 (permalink)
Member # 21453
Just look up some numbers. like everyone else said, the ports are fairly standardized, but that doesnt mean it is all the same. IIRC the 465 or even alot of light tcase driven pto's arent a straight cut input, but I have done too many to remember.
Kilborg is offline   Reply With Quote
Old 05-21-2010, 12:43 AM   #17 (permalink)
Member # 49108
Thanks
