Member # 43687
What would you run?
I have a 1981 1 ton chey with all the goodies dana 60 ,dana 70hd ,sm465 and np 205. I have diy4x b52 kit with 3.5 lift springs. Crossover steering will be going in. I also have a 1980 jimmy with i know big gay truck with a 12 inch super lift and the dana60 and 14 bolt brackets cut and tilted up for proper drive line angle. Would it be better swaping in the jimmys diffs or shim up the drive line it has in the 1 ton. The jimmys diffs have 5.13's and are all fresh . I picked up 4.88's for the one tons diffs with 14-10's . Im planning to run 40 or 42's. Also anyone know where in canada i can find some stock H1 hummer rims.8 bolt or 12 bolts ?
STOP YOUR BITCHIN! Last edited by 1980Jimmy; 05-23-2010 at 05:07 PM. Reason: photos |
be cool, baby
Member # 17896
If I were you? I'd run a razor right down the inside of each arm, deep.
Which one do you like better for what you do with it? Pretty simple question, to me.
Utah 4-Wheel Drive Association---Blue Ribbon Coalition---USA-ALL---Tread Lightly |
