what should I do with a 1970 blazer? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-03-2010, 03:38 AM   #1 (permalink)
Member # 147721
I just picked up a 1970 blazer, it is not in great shape the front has been hit and the grill, hood and fenders (which were replaced by the p.o. and rust free) all need to be straightened or replaced. the floor needs patching and the cross sills need to be replaced.
It has a 307, TH350, NP205. I don't know if it is better to leave it stock, or take the parts I have from my other project (1993 2wd 3/4 ton) 454, 4L80E, NP205, D60, 14bff and get rid of the '93. I am not looking for a restoration, just a trail rig the I can put the kids in and drive down the road.
uswheeler is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 03:51 AM   #2 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Send a message via AIM to jhama78
Id say that the 70 k5 would be a cooler rig for sure depending on how much body work you want to do...
-j-rOd
wear life like a loose garment
84 Toy Farm Beater
85 Toy SR5 xcab DD
86 GMC K1500 SWB
88 4Runner Fambly Beach Ride
11 Tundra Double Cab Rock Warrior
jhama78 is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 03:54 AM   #3 (permalink)
Member # 112787
id have to agree with switching to the blazer
WHEELING: THE MOST FUN YOU CAN HAVE WITH YOUR CLOTHES ON........1985 blazer 1980/82 trazer 02 LB7 2500HD 85 3500 crew cab
blazerboy85 is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 04:59 AM   #4 (permalink)
Member # 147721
I agree 100% that the blazer is cooler, and I am going to fix it and use it, I am just undecided whether to leave it stock and build both trucks or just build the blazer and use the parts I have from the truck. is the 307 from the blazer worth anything?
Old 06-03-2010, 05:11 AM   #5 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
307s are even more of a gutless bastard child than the 305... i mean if it runs then by all means mob it around but i wouldnt put any serious $$ into it with how easy it is to find a 350.
-j-rOd
84 Toy Farm Beater
85 Toy SR5 xcab DD
86 GMC K1500 SWB
Old 06-03-2010, 07:49 AM   #6 (permalink)
NorCal_Chris's Avatar
Member # 140551
+1 for tossing all those parts off the 93 into the blazer.
I wish i would have found a resonably priced first gen
adfasd
NorCal_Chris is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 05:07 PM   #7 (permalink)
Member # 89558
my vote is kind of a given but..... blazers kick ass i'd go with it
Montana_BLZIN is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 07:16 PM   #8 (permalink)
Member # 146906
another vote for swapping the parts into the blazer. I just picked up a 71 k5, hoping to start on it this winter.
Big Bad Wolf Racing is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 07:39 PM   #9 (permalink)
Member # 154549
Go with the K5, '93 pickups are a dime a dozen....
mudinmyblood is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 08:19 PM   #10 (permalink)
bigbadchev84's Avatar
Member # 68938
I vote the k5 too, though I may be partial.
In case you didnt know, the 454 is not a bolt in and go deal.
The 4wd 67-72 bodys were never offered with a bigblock. There are firewall clearance issues with valve covers, and distributor. I think there may be some issues with the crossmember as well.
All that being said, I have a 454 sitting in the garage for mine to go in this winter
72 k5 400/350/205 8" lift 4.56s 38" Toyo M/Ts
87 k5 383/400/203/205, 52s 5.13 60/14bff 39.5 rockers
bigbadchev84 is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 08:42 PM   #11 (permalink)
Member # 139150
my votes for the k5, an easy efi swap since you have all the parts, a win win with power and not having to deal with a carb anymore.
sjracer is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 09:30 PM   #12 (permalink)
Member # 82152
i have a 454 in mine and i love it ... i did have to move the cross member forward 3inch and i think i use a 73 blazer crossmember ...lost of room.. to keep the cost down
fra66le25 is offline   Reply With Quote Quick reply to this message
Old 06-03-2010, 09:34 PM   #13 (permalink)
Member # 39818
K5
Id go with the ole girl & new parts. Im in the process of re-doing this thing droppin it down 4" 52"/64" swap and some fender trimin It will surely fit the whole fam damly, kinda what I had in mind with this instead of hackin it up.
ssean is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 06:34 AM   #14 (permalink)
Member # 147721
I decided if I can get the blazer going the way it is I will leave it for now, but it is missing the plug wires, and the wiring is all screwed up. I picked up a battery and wires, but I could really use a wiring diagram to figure out what is supposed to be there and if I am missing any other parts (relays, fuses, etc.). I am not going to spend too much time or money before I switch to the 454 but if it runs I'll fix the body and run it then I can swap the other parts in steps instead of one big project. heres the plan - fix the body, swap in the one ton axles and 6" lift, then swap in the 454 and 4L80E, does this make sense? bigbadchev84's is inspiring, but I have got a long way to go.
Old 06-05-2010, 08:35 AM   #15 (permalink)
87srunner's Avatar
Member # 118629
heres one that i used
http://farm4.static.flickr.com/3645/...c2a8064d_o.jpg
87srunner is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 08:53 AM   #16 (permalink)
Member # 68938
The only ones that will matter to see if you can get it running are gonna be power to your distributor/or coil, and the sterter wire on the starter
Old 06-05-2010, 10:05 PM   #17 (permalink)
Grumpy_old_fart's Avatar
Member # 20147
by the way, those stock wires will be yellow to the distributor (*also a wire runs back up from the starter to the coil on the older ones because the starter energizes the coil during cranking, then it runs off ignition power) and should be red to the starter.
Empathy, apathy, sympathy.
Sympathy is between shit and syphilis in the dictionary.
Grumpy_old_fart is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 10:06 PM   #18 (permalink)
Member # 113084
Get a cage or atleast a rollbar!
'75 Chevy Truggy...5.3/350/203/205/d60/14b
87 4runner 14b/44, dual cases, 39.5's, exo
leeman1790 is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 11:45 PM   #19 (permalink)
Member # 68938
Full cage is in the works for this winter, along with the bbc and new paint. That was a very mild trail ride, Nothing too serious until I get the full cage in.
Old 06-06-2010, 06:11 AM   #20 (permalink)
Member # 147721
Thanks guys, that should get me going, I'll let you know what happens. by the way, I do plan on putting a cage in while fixing the body.
