Member # 5129
305 converson in s10 blazer
I am going to put a 95 tbi 305 in an 88 tbi 4.3 s10 blazer. has any one done this? what am I looking at as far as wiring and stuff? any help would be sweet. Thanx.
When Approaching a 4-way stop… The Vehicle with the LARGEST TIRES … Has the right of way!!! 82 toy, exo-cage, crawl box, beadlocks, 38.5's .......you know ALL the good stuff |
Member # 9610
S104x4.com will have a ton of info for you, if it is still up, been a while since I had my S-10. Also, a book by Jags-That-Run has all the info needed for you to. Try a search with that name and it should bring up their website. Have Fun!
Duct Tape is like the force, it has a light side, a dark side, and it holds the universe together. |
S10-4x4.com is dead... Has been for years. Most of the people from that site have gone to another...the link in my sig. s10-4x4.org That will take you to an EZBoard site we are using until we get some server issues worked out. S10-Extremists.com
A book you should not be without is the conversion manual from www.jagsthatrun.com Parts lists and step by step details of what you will need. There are tons of people that have done the swap. People just as crazy as we are. If you have any real technical questions, post them over at that S10 site and someone will know something.
[COLOR="Red"]Central Washington Muff Dive and Rescue Team[/COLOR] |
I think it was Fourwheeler that did an article on a 350 swap a couple of years back. I know they ended replacing the transmission, transfer case, and rear axle. however I think this might have been a fairly built 350, but I can't remember. anyhow I'll have the rear axle out of my ZR2 for sale in a couple of months. It's got 3.73 gears, disc brakes (99') model, and a gov-loc, but that can be eliminated. you can have it for $100 when I take it out.
99' ZR2 Blazer, SFA 79' F250 Dana 44 with chevy outers, 4.88's detroit, 14 bolt FF, 4.88's, detroit, 3.5" YJ springs in front, customs in rear, 36" TSL's |
#5 (permalink) | |
Member # 7665
Re: 305 converson in s10 blazer
If you are wanting to swap in a v8 that is already set up for TBI then just unplug your current wiring harness, but do not remove it. Put the new motor in and make sure you have all the correct sensors for a standard 1988-1991 TBI motor. Plug in your factory harness to the required sensors. Get a v8 EPROM chip from the local auto parts store ($65) for a 1988-1991 TBI 305. Pull the 4.3L chip out of your computer and plug in the new chip (unplug the computer before doing this, just in case). Make sure there is power (battery juice). Crank her up.
I don't have a 4x4 anymore...get over it. |
Member # 9610
Not on the subject of wiring, but you are gonna need a different oil pan to clear the front differential.
Or just use a BFH like I did. Ugly but it worked.
Member # 5129
thanks for the info everyboady it does not sound as hard as i thought it was going to be. oxblood what is the bolt patern on that rear end? is it the same a an 88 blazer? and what is a gov-loc? Thanks
#10 (permalink) | |
Member # 7665
