Help with propane adjustments - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-16-2010, 12:32 PM   #1 (permalink)
flatblack83's Avatar
Member # 121277
Ok guys, i have a 350 .040 over, domed pistons, 515 solid cam, 1.6 roller rockers....etc. I just mounted a 450x and an x-1 propane kit with a large forklift tank. I have it so when warmed up it idles at 900. But when cold its not so steady, im new at this propane stuff, is that how it is..? When i first put it on i primed it and it started right up but stalled, i adjusted the adjustment on the baseplate so it idled but there are other adjustments that i didnt touch....help on this is greatly appreciated....thanks guys.
83 chevy stepside, 358, propane, d60,14b 456s, 465/205, 53 inch alcans, diy4x shackle flip with 52s. On 39-15-15s
03 chevy 2500hd 6.0, 4l80e, 241, d60, 14b 4:10s, sas bloodyknuckle garage coil spring/radius arm kit, 8 inch lift on 37 bfg km2's
flatblack83 is offline   Reply With Quote
Old 06-17-2010, 09:33 AM   #2 (permalink)
Member # 121277
Also noticed on the carb, if you look inside the top the washer and the spring shakes and makes a lil noise, Im imagining its supposed to shake. But if you touch it it stops shaking and the idle calms down a little. I have the idle at 900 now, when warmed up it runs and idles perfect. From what i found the screw in the front is the mixture screw, i just today got it to barely smell like pane when warmed up. Still to idles rough when cold until it gets to 100 on my guage. The truck runs alot cooler also, i have a 160 in it and it barely gets to 150.
