205 front output seal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-16-2010, 09:56 PM   #1 (permalink)
Member # 68938
Can someone tell me the part number for the front output yoke on my 205? It is in my 72 blazer with a th350. I went into napa and they told me I need a number, there books only go back to 91' and the computer isnt showing anything
Napa is the best in town for knowing what the hell your talking about. i would pull mine out to check, but I am driving it every day and cant risk them needing to order it in.
While I am on it, is it as easy as unbolting the yoke and slapping the new seal in and running the nut back on? Are there torque specs or anything else I need to know before jumping in?
72 k5 400/350/205 8" lift 4.56s 38" Toyo M/Ts
87 k5 383/400/203/205, 52s 5.13 60/14bff 39.5 rockers
bigbadchev84 is offline   Reply With Quote Quick reply to this message
Old 06-16-2010, 10:40 PM   #2 (permalink)
trkklr77's Avatar
Member # 29016
i will get the ### for you tommorrow but there is no torque or anything you can screw up, just run it down hard and that is it.
trkklr77 is offline   Reply With Quote Quick reply to this message
Old 06-16-2010, 10:54 PM   #3 (permalink)
Member # 68938
That would be awesome, thank you. Im suppossed to slather the nut and inside the yoke with rtv right? Or is there a part number for the rubber washer as well?
Old 06-16-2010, 11:18 PM   #4 (permalink)
Grumpy_old_fart's Avatar
Member # 20147
stop by your local tranny shop, they probably wont charge you more than 10 bucks for both parts, and smile while you walk out... with the right parts in hand.
Empathy, apathy, sympathy.
Sympathy is between shit and syphilis in the dictionary.
Grumpy_old_fart is offline   Reply With Quote Quick reply to this message
Old 06-17-2010, 02:20 PM   #5 (permalink)
RusseII's Avatar
Member # 142417
NATIONAL Part # 710005 {Oil Seal; Nitrile / Shaft Size=1.75" Housing Bore=3.062" Outer Diameter=3.066" Width=0.485"}
Front; New Process 205 2 Spd. Part Time Transfer Case
OR
TIMKEN Part # 710005
Front
96 Burb 2500 SAS DRW D-60 front, Divorced 205, H1s, Cummins 6BT, "Mostly stock"
RusseII is offline   Reply With Quote Quick reply to this message
Old 06-17-2010, 04:33 PM   #6 (permalink)
63GMCKid's Avatar
Member # 121634
Send a message via AIM to 63GMCKid Send a message via MSN to 63GMCKid Send a message via Yahoo to 63GMCKid
I'm going to be replacing the front output shaft seal on my NP205 pretty soon as well, I've never done it before so I am curious about this as well, is it as simple as dropping the driveshaft, unbolting and removing the yoke, removing the old seal and putting the new one on and then putting it all back together? I'm going to do a search for an exploded parts diagram of the 205, as they say, a picture is worth 1000 words, but any extra info or tips on this repair would be great.
'63 GMC Project
My other ride - built Yamaha Raptor 660
63GMCKid is offline   Reply With Quote Quick reply to this message
Old 06-17-2010, 09:33 PM   #7 (permalink)
trkklr77's Avatar
Member # 29016
OR
Front
same number in my book.
Old 06-17-2010, 10:05 PM   #8 (permalink)
Member # 68938
Thanks again guys.......Got to thinking though. the last time I went to check the t-case level a ton of atf poured out So I might as well replace the seal between the transmission and t-case while I got the t-case emptied out. Anyone got the number for that seal? Its gonna be the same story going in on that one too
Old 06-17-2010, 10:13 PM   #9 (permalink)
trkklr77's Avatar
Member # 29016
http://www.showmetheparts.com/timken/
Old 06-18-2010, 07:19 AM   #10 (permalink)
RusseII's Avatar
Member # 142417
NATIONAL Part # 471869 {Oil Seal; Nitrile / Shaft Size=1.937" Housing Bore=2.686" Outer Diameter=2.69" Width=0.375"}
TIMKEN Part # 471869
N.P. 205
Old 06-18-2010, 07:24 AM   #11 (permalink)
RusseII's Avatar
Member # 142417
Its that simple, just make sure you got the gasket or make your own.
