6.2 diesel fuel return line question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-06-2010, 10:21 PM   #1 (permalink)
BadAssEddie's Avatar
Member # 147534
Send a message via Skype™ to BadAssEddie
Ive been slowly replacing my fuel lines on my 1989 Jimmy with a 6.2. I am in the middle of replacing the return lines that loop in between the injectors. These lines are a dealer part and cost way too much money for what they are in my opinion, so I am trying to find a suitable soft line. I cant find a size hose that fits on the nipple on the injector that is fuel injection rated, but I have some vacuum line in my garage that is the perfect size. So my question is, what is the pressure on the return line? Is it super high like it is from the IP to the injectors? I have spent the last couple hours looking around here and CK5 but have not found an answer. If it is low pressure I think I am going to give it a whirl but if not Ill just have to keep searching around to find what I need. Thanks for any help...
BadAssEddie is offline   Reply With Quote Quick reply to this message
Old 07-06-2010, 11:13 PM   #2 (permalink)
Member # 52752
ask that here
http://www.thetruckstop.us/forum/forumdisplay.php?f=8
they are very very good with that engine at this site
bowtied_micky is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 01:15 AM   #3 (permalink)
Banned
Member # 91791
Send a message via AIM to g-wizz
im pretty sure its a low pressure return line, lmc truck sells them but they are chinese and they dont cost alot.
take one of your original lines and cut it. see if there is any sort of fiber brading in it, if not then i would think vacuum line would work.
hell just unplug one and turn the truck on, if a massive jet of fuel comes out then its prob a pressurized line, if not then ya low pressure.
g-wizz is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 05:29 AM   #4 (permalink)
Member # 613
check with the local auto parts or online dorman makes a kit for these engines with new lines and caps comes with caps also. You may check with kennedy diesel or advant salvage. I've used the dorman parts with good success.
odee is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 08:05 AM   #5 (permalink)
Member # 147534
Thanks for the replies everyone.
Old 07-07-2010, 08:48 AM   #6 (permalink)
Member # 147534
Picking up the kit from Napa later. Damn those parts monkeys are ignorant, Ive called three times to each store looking for this and they couldnt figure it out. I had to call and give them the part number and tell them what it was
Old 07-07-2010, 12:06 PM   #7 (permalink)
Member # 50360
Send a message via AIM to NetBSD Send a message via Yahoo to NetBSD
http://www.dieselplace.com/forum/forumdisplay.php?f=20
check that place out for all yer 6.2/6.5 questions. great site and great people with loads of info.
this topic was coverd a few times so a search should show up some cheap lines that will work
89 Ranger, 2.9, 6" lift, 35" baja claws
92 Silverado, 6.2L, GM-3 Turbo at 10PSI
NetBSD is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 12:29 PM   #8 (permalink)
Banned
Member # 91791
dude ill put it this way, this is the first time that guy has ever heard what your asking about. i wouldn't say that he's ignorant in a bad way (cause yes by definition he really is ignorant.) but honestly its your mistake for not finding the part number in the first place. your the one asking a nonspecialist with a specialized question. what did you expect?
Old 07-07-2010, 02:43 PM   #9 (permalink)
Member # 147534
Good point, I was just a little flustered earlier as the guy wasnt the most friendly and I was in a hurry. I shouldnt have lashed out or put the blame on someone else.
Got the part, in case anyone ever needs this:
6.2 Diesel Fuel Return Line Kit Part #: 904-101
http://www.dormanproducts.com/p-28146-904-101.aspx
Old 07-07-2010, 07:34 PM   #10 (permalink)
Banned
Member # 163759
Send a message via AIM to gee whizz
it happens, especially when the said part is integral for any further progress in the completion of your rig.
napa always has the books.
gee whizz is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 07:36 PM   #11 (permalink)
Member # 145015
Presure is not going to be your problem with the hose ... Your going to need a diesel fuel rated ... not all lines are created equal even if it does say gasoline / diesel rated .
The r7 rated hose dose not hold up very well over time ... Your going to want to look for a r9 rated hose .
Try Vulcan diesel products ... they sell a big selection of the proper rated hose for your application .
Just my 2 cents .
http://www.vulcanperformance.com/category-s/81.htm
Greguw is offline   Reply With Quote Quick reply to this message
Old 07-22-2010, 01:57 AM   #12 (permalink)
Banned
Member # 163759
these things are slowly blowing up on my truck... fuck they leak alot when they go.
anyways to the OP. ha thanks for asking this.
what did you end up doing about yours, where did you go, and how much did it cost. what did you do about the short "plugged" lines.
Old 07-22-2010, 12:16 PM   #13 (permalink)
Member # 164688
call any chevy dealership there usally pretty good.....the power steering pump bracket got some cracks and was sitting uneven destroying the belt ..i just called and the got the part number it was easy but they wont order it for u
4by4hobby is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 03:57 AM   #14 (permalink)
Member # 84454
Just my 2 cents .
What he said ^^^ The reason those little hoses are expensive is because they are made of Viton or something similar. They will even survive biodiesel, whereas regular cheap hose will eventually rot away even with plain ol diesel.
MaxPF is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 06:19 PM   #15 (permalink)
Banned
Member # 163759
so are the doorman ones any good?
Old 07-25-2010, 12:11 AM   #16 (permalink)
Member # 84454
No idea - never used 'em.
Old 07-25-2010, 02:20 AM   #17 (permalink)
Banned
Member # 163759
well i guess im going to find out.
Old 08-01-2010, 08:56 PM   #18 (permalink)
Member # 147534
I got the dorman ones and they seem to be good so far ( ive only got about 300 miles on them). No leaks and they really helped my hard start issue (along with replacing all the soft line). Sorry about the late response, I havent signed on in a while.
Old 08-02-2010, 02:53 AM   #19 (permalink)
MUDTOY's Avatar
Member # 13242
Heres a kit from Pensacola Fuel Injection. All they do is disel.
6.2L-6.5L INJECTOR INST KIT
CODE: WD65120
List price: $29.00
Our price : $19.50 Price: $0.00
You save: $9.50 (33%)
NAPA wanted 74.00 for the same kit
DAV LIFE TIME MEMBER Served Proud U.S. ARMY
MUDTOY is offline   Reply With Quote Quick reply to this message
Old 08-02-2010, 12:18 PM   #20 (permalink)
Banned
Member # 163759
CODE: WD65120
List price: $29.00
i spent 20$ at napa for the doorman kit. 74$ are we talking about the same kit?
Old 08-02-2010, 06:07 PM   #21 (permalink)
MUDTOY's Avatar
Member # 13242
Qty Fuel Injector Seal Kit
Product Line: Echlin Fuel System
Part Number: CRB 218446
Price: Price
Unit
87.49
Each
Warranty Limited 12 Months
Warranty PDF
Material Safety Data Sheet There is no MSDS for this item
Application Information: 1994 Chevrolet Truck C2500 3/4 Ton - Pickup
Engines : 6.5 L 395 CID V8 Diesel
Comments: Installation Kit.
Per Car Qty: 8
my buddy runs a disel shop my cost was 74.00
