Speedometer calibration on 88 suburban 700r4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-10-2010, 03:06 PM   #1 (permalink)
Member # 161572
Got an 88 suburban, 350TBI/700r4/Np208. Is there a way to recalibrate the speedometer like on a Turbo 350. The manual says something about a VSS but my transfer case has only one wire going to it and that is the 4wd indicator wire. The speedometer cable screws into the transfer case and the housing is held into the transfer case with one bolt, just like on a turbo 350.Does the older 700r4 have a gear in the TC like the turbo 350 or is there a differrent method for recalibration. Any help would be appreciated.Thanks in advance.
svminole is offline   Reply With Quote
Old 08-10-2010, 03:44 PM   #2 (permalink)
Mr Clickerson's Avatar
Member # 141777
You just replace the gear in there to one with the proper number of teeth based on your gearing and tire size. And the gear is in the transfer case, not the transmission.
Some useful websites:
http://www.tciauto.com/Products/Tech...eedo_gears.asp
http://www.transmissioncenter.net/sp...n_______va.htm
Mr Clickerson is offline   Reply With Quote
Old 08-11-2010, 09:05 AM   #3 (permalink)
Member # 161572
Thanks Mr Clickerson for the info. worked great
