Member # 163990
suspennsion lifts?
4" in particular, who makes a good one? kinda get mixed reviews about rough country. ill be running blocks in the rear to keep my towing capacity with the "stick springs so i guess it boils down to who makes a good 4" front spring?
#2 (permalink) | |
Member # 80727
Contact a spring company not a lift company and have the proper springs made to retain the overloads
1994 Isuzu Trooper: OM617/W56/toybox 4.56 Dana 44 w/ lockright/6 lug Ford 8.8 4.56 Ox locker |
#3 (permalink) | |
Sticks and Stones
Member # 115122
Are you feelin' cheery today?
Piss on everything I'm going four wheelin! |
Member # 128431
X2 on NO BLOCKS, if anything do 4in spring in the front and a shackle flip in the rear. Blocks will give you some bad axel wrap.
Learning it all the hard way, But i love my Big Ass Chevy |
Member # 163990
Alright so on break did some googling and shackle flip it is. It will actually save me money vs. Blocks and keep my towing capacity like I want. So any advice on front springs? There's a pair of 4" in Craigslist for 100 bucks no idea on brand. Just says they have a higher spring rate for big block application.
#8 (permalink) | |
Member # 80727
Member # 51243
Lots of budget suspension kits use blocks, they can contribute to axle wrap, and while I don't recommend them for offroad use, I did wheel my truck for a while with blocks before I got my shackle flip built.
As for the front springs, 100 bucks isn't bad, verify spring length and width prior to buying them. You will find that most lift springs have about 46" between spring eyes, and it screws up the shackle angle for the front springs. But yeah, check um out. Look for any cracked leaves before you give him the money.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR] |
Member # 163990
I wasn't to worried about axle wrap going to run a anti wrap bar. What length are stock front springs and width? Id say from what I remember last time I looked is estimate 3 inch wide My truck is a 75' 3/4 ton. What should I be looking for as far as eye to eye length. Shorter or longer than 46"? I'll be going to look at them in about 3 hours
#12 (permalink) |
Member # 163990
So I got the springs. They're in really nice shape. Definitely a high spring rate. But they're 2.5 inches wide and my stockers are 3. Will this be a problem? I did notice I difference in the brushing between the 2 and it seems the bushing will take up the extra 1/4 inch per side when mounted? Any ideas
#13 (permalink) |
skullfuckery
Member # 29016
shove them up your ass and see if they are the same width......
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#15 (permalink) |
skullfuckery
Member # 29016
of course you wouldnt.
#17 (permalink) |
skullfuckery
Member # 29016
did you shove them up your ass to see if they were the same width or not?
#19 (permalink) |
Member # 15257
he is right you know..... maybe you should not have a 4x4 if you cant figure this out.
1984 CUCV K30 "it went bang" means "its fucked". [url]http://www.pirate4x4.com/forum/showthread.php?t=900026[/url] My Build Thread. |
#20 (permalink) |
skullfuckery
Member # 29016
the best part is that they have been doing it this way since at least 1960.
#21 (permalink) |
Member # 163990
Not saying he isn't right. Just don't say it like that. Every lift kit I've seen says 2.5 inch wide springs for my application. So It confused me. Nowhere have I found a lift spring 3 inches wide.
#22 (permalink) |
Member # 80727
Yes 2.5 inch springs with a shouldered bushing will fill the hangers. I cant really comment on the 3" stock vs 2.5 think cause I've never bought a truck stock TBH.
And dude to run 4in blocks and an anti wrap bar is like 2 steps back and 1 step forward. Do it right the first time.
#23 (permalink) |
skullfuckery
Member # 29016
awe, is the non butt stuffing newb butthurt?
#24 (permalink) | |
Member # 163990
Im not running blocks. Ordered the shackle flip. What I meant to say is I'm running a anti wrap bar anyway. The stock springs had some wrap to begin with. I think going to get the ord greasable bushings |
#25 (permalink) |
Devout Newbie Hater
jesus... you would think someone has a no limit budget these days..
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! |
