Front diff went out What's good ratio to put back in? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-17-2010, 08:56 PM   #1 (permalink)
Member # 154374
I have a 1995 chevy tahoe running 3.42s and was wondering if 3.73s would be better put back in it or the original back. I'm looking to do a little offroading and i am running 35 inch tires on 20 inch rims. Any suggestions?
skeeternash is offline   Reply With Quote
Old 08-17-2010, 09:04 PM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
you need to match your rear ratio so if you arent going to do the rear you had better put the same back in
most people are running excessivly higher gears any more because you o/d will make up for the lost top end speed.
4.10/4.56
trkklr77 is online now   Reply With Quote
Old 08-17-2010, 09:07 PM   #3 (permalink)
Member # 154374
I plan on doing both for sure just don't want to turn into a gas sucking machine would 3.73s make that big of a difference mpg wise?
Old 08-17-2010, 09:37 PM   #4 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
as always, its a balance of power exerted v rpm spun
you can run 3.00 and only spin 1600 @65 but be 3/4 pedal to keep it going.
or
you can run 4.56 and spin 3000 @65 but only be @1/2 pedal.
ie less effort to push the same brick of shit.
Old 08-17-2010, 09:44 PM   #5 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
3.73 came stock in alot of 1/2 and some 3/4 ton trucks so if your going economy you may be able to pickup a set of gears super cheap or find a whole new front or rear axle the wrecking yard fairly cheap. 4.10's usually came in 3/4 ton and larger axles. also different differentials have different carrier breaks, such as 12 bolt carriers had two different carriers and the break point in those diffs is 3.73 and lower/ 3.96(?) and higher numerically, so you may have to buy a different diff carrier in one or both diffs to do some serious re-gearing. might be time to upgrade your diffs anyway as you probably have 10 bolts front and rear in that tahoe.
isn't a tahoe IFS anyway? might be time for a straight axle swap.....
sjracer is offline   Reply With Quote
Old 08-17-2010, 10:02 PM   #6 (permalink)
1GMC4x4's Avatar
Member # 33716
I have a 94" GMC and when I had my IFS I had 3.73s with 35" Tires. It worked. 65mph was around 1800RPM with my Auto(4L60E) but it had no balls! And towing sucked.
I am now running 4.10 with 35s until I install my 37s and it has WAY more power. Its like a new truck. I have never been able to roast my tires and now I can almost go through first gear shredding them up.
65 is more around 2100 but like said above, the engine works way less to get there.
94' GMC SAS Cummins 12valve, Veg-Powered
WANTED: Looking for a 1978-79 Ford Dana 60 SRW, 4.10s
1GMC4x4 is offline   Reply With Quote
Old 08-18-2010, 05:00 AM   #7 (permalink)
Suburbiangiant's Avatar
Member # 136410
I'm running 4.56's and 35's right now and I gained mpg by switching. The stock 3.73's just weren't enough to turn 35's in a heavy suburban.
With your vehicle being geared high I would swap to 4.10's and you would basically have the bone stock vehicle characteristics again. Your MPG would more then likely be better then it is now. 3.42s and 35's is just horrid.
Suburbiangiant is offline   Reply With Quote
Old 08-18-2010, 06:25 AM   #8 (permalink)
Member # 154374
Don't you all mean 4.11's I'm not sure there is a 4.10 is there for my truck?
Old 08-18-2010, 07:05 AM   #9 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
does 1 hundredth of a gear rotation realy matter?
and depending on eaxctly what axles you have you can have 4.09 in the front and 4.11 in the rear
Old 08-18-2010, 07:30 AM   #10 (permalink)
Member # 154374
Ok just wondering I'm not entirely knowledgeable on the whole gear changing this will be my first. Thanks for the great info from everyone. I was originally planning on putting 4.11's in it, but some people I know told me it would kill my gas mileage. Just wondered what everyone else thought
Old 08-18-2010, 08:00 AM   #11 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
When I had my 2500HD with a 6.0 it had 3.73 and 35's. I hated it it couldn't choose a gear to stay in, especially while towing. I put a set of 4.88's it was the best thing I ever did. Even though everbody told me I was wrong . Towed awesome, felt like it had more umph. I did not notice a change in mpg. Also it was a crew cab but I was on 16's. If I were to do it again I would.
DD:09' V8 Colorado For Sale
Toy:The BlazerRebuild Ultra4 #818
Old tow:92' Dodge Build Sold
New tow:05' Dodge Crew 4x4 CTD (stock for now)
Looking for sponsors, we're going racing!
K5runner@hotmail.com is offline   Reply With Quote
Old 08-18-2010, 11:02 AM   #12 (permalink)
Member # 34987
Those people are ignorant. MPG is function of engine load and RPM. Engine Load has a greater effect however.
Lower gears provide more mechanical advantage which is needed in a heavy vehicle with big tires. That said, you have less engine load at any given RPM with the lower gears, but your RPMs will be higher.
1 TON SAS'ed C1500 ECSB on 37s
axisT6 is offline   Reply With Quote
Old 08-18-2010, 11:45 AM   #13 (permalink)
Member # 163759
Send a message via AIM to gee whizz
kill your mileage? how about those 35's what did your friend say about those? yes if you had a completely stock truck and you lowered the ratios it would do something to the mileage.
the whole point is to match your powerband back to stock. so take a gear calculator and plug in your stock #'s and tires and try to match that with 35's with your new gear ratio.
I AM A CAMARO-GENIUS STOKED!!!!!!!
gee whizz is offline   Reply With Quote
Old 08-20-2010, 07:33 PM   #14 (permalink)
Member # 154374
Thanks guys I think i'm g2g with 3.73s for now but will definitely upgrade to 4.11's if need be
Old 08-20-2010, 09:44 PM   #15 (permalink)
Member # 136410
3.73's and 35's is useless! If you want good gas mileage again then you need to be at a 4.11 minimum. Don't waste your money on 3.73's that's a lot of dough to throw away and not be happy with the outcome.
Maybe you'll follow a chart rather then opinions.
Yellow = Good Gas mileage
Green = Closest to stock ratio
Red = More torque
Old 08-20-2010, 10:13 PM   #16 (permalink)
Member # 96153
Wow good job. You definitely learned a hole shit load from this didn't you?
Old 08-20-2010, 10:20 PM   #17 (permalink)
just4cuz's Avatar
Member # 98655
I don't think Suburbangiants chart takes OD transmissions into account. If you have a 700R4 or 4l60E multiply your rpms by .70. A 4l80E requires you to multiply by .75 in each of the categories.
just4cuz is offline   Reply With Quote
Old 08-20-2010, 10:33 PM   #18 (permalink)
1GMC4x4's Avatar
Member # 33716
seriously
X2 3.73s are useless for you truck. take it from someone who has had both 3.73 and 4.10 on the same truck with the same size tire.
Old 08-20-2010, 10:38 PM   #19 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
no it doesnt, it is set to be 1:1.
it also follows the theory of less rpm = less consumption not real world load v consumption.
Old 08-20-2010, 10:42 PM   #20 (permalink)
Member # 136410
Correct... If you drive an automatic your RPMs will be higher, and the opposite is true if you have overdrive. your RPMs will be lower.
