Fuel Pump help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-18-2010, 01:53 PM   #1 (permalink)
ZBO
Member # 109359
Fuel Pump help
I have what I was told to be a 350 fuel injected, only numbers I am able to find
are 14102182... I believe this to be a 1987 or 88 350 from a camaro or truck, but cannot be sure. All this may be irrelavant as what I'm trying to figure out is what psi does my external fuel pump need to be. I think 15psi should be right, but was hoping one of you guys could help me out.
Thanks
In advance
Marc
ZBO is offline   Reply With Quote
Old 08-18-2010, 03:41 PM   #2 (permalink)
Member # 20423
NO.
The system operates at 11-13psi but the pump must put out more.
Use the Masters E8248 inline pump with a Fram G3 filter before the pump.
Bill USN-1
EFI Moderator at http://www.binderplanet.com
Bill usn-1 is offline   Reply With Quote
Old 08-18-2010, 05:07 PM   #3 (permalink)
ZBO
Member # 109359
Thanks Bill...
I helped my buddy pick up this Scout that has a 350 in it and it has been nothing but a nightmare... ran great while idle, died when you put it in gear, gas tanks rusted etc etc.... and oh yeah , On the way home the front right wheel fell off while I was towing it. Luckily I had pulled off the highway to get gas, otherwise I probably wouldnt be looking for a fuel pump. If I could figure out how to post pics, I would show you some of the carnage...
Once again, thanks for the info..
marc
Old 08-18-2010, 09:11 PM   #4 (permalink)
Member # 20423
Good luck Marc.
I'm one of the old members of the North Texas Binders club.
I used to live in Highland village in Denton.
Tell your buddy to go to the binderplanet for IH tech.
Bill USN-1
Old 08-20-2010, 02:25 PM   #5 (permalink)
ZBO
Member # 109359
If you're a member, then you have probably seen this scout that I picked up for my buddy.. It has a NT Binder sticker on it.....Red 62 w/35's and a 350 (or not, it probably hasnt seen the road in a while) I will pass on the info
Thanks
Marc
