skullfuckery
Member # 29016
Got an axle question? Check here first!
while these are not the end all be all final word and nothing should ever need to be asked again articals they are damn close and if you are still unsure read it again, the info is in there.
d60 beef up and rebuild pn##http://pirate4x4.com/forum/showthread.php?t=39510 d60 biblehttp://pirate4x4.com/tech/billavista/60_front/ this is the dana 60 front axle bible. it contains just about everyhting you will ever need or want to know about chevy ford and dodge kingpin front d60s, including interchangable components, part numbers, exploded diagrams, bom numbers, vehicular aplications, assembly/disassembly instructions and identification. d60 king pin rebuild http://pirate4x4.com/tech/billavista...pin/index.html this is how to rebuild your d60 kingpins. dana axle spec's and identification/verification '67 - '78 http://www2.dana.com/pdf/X510-8DSD.pdf '78 - '98 http://www2.dana.com/pdf/X510-9.pdf these are dana's specs and breakdowns of all dana axles used from 67-98 for all makes and model of vehicles. d44 and d60 identificationhttp://77cj.littlekeylime.com/web_rs44.html one the best d44 and d60 interchange and identification sites out there. 14bff biblehttp://pirate4x4.com/tech/billavista...ble/index.html this is the 14bff bible, it contains everything you could possably want to know about the 14bff from 73 98ish. part numbers, identifications, widths, assemebly/disassembly instructions. gear install http://pirate4x4.com/tech/billavista...4b_Gear_Setup/ while this is directly for the 14bff the concepts and instructions will apply to nearly every axle in existance save for a few parts that do and dont exist in particular axles gear install http://pirate4x4.com/tech/billavista/Gear_Setup/ this artical is based on other axles without drop out pinions and adjuster collars d70 http://pirate4x4.com/tech/billavista/D70/D70.htm this artical covers the basic components to a d70 rear with some comparisions to d60. d70 http://pirate4x4.com/forum/showthrea...ght=d70+thread this is for all intents the chevy/d70 bible, while it is not an artical it is about the single most comprehensive colection of information on the axle and its many uses and setups. now because it is an active thread it will change, grow and evolve as the times and styles of modification do. disc brake conversion http://pirate4x4.com/tech/billavista/14b_disc_brakes/ this artical is all the fullfloating disc brake info you will need, it can also help you understand what you will need to do, use and modify on other axles that you might want to disc swap. however it will not have much on particular applications and parts to swap your particular axles, unless its a d70/14bff. bare in mind that since this was writen dozens upon dozens of mfg's have began to make bolt on brackets for just about every possible combonation of hub and axle housing you can think of. more info on brakes and system design. http://pirate4x4.com/tech/billavista/Brakes/ eaton ho52/72 axles http://pirate4x4.com/forum/showthread.php?t=771317 the best damn gear calculator you will ever find http://api.viglink.com/api/click?for...13170661268893
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP Last edited by trkklr77; 09-26-2011 at 12:43 PM. |
Sticks and Stones
Member # 115122
Good idea
![]() Steering Dana 70HD build with 60 outers by bowmans_army http://www.pirate4x4.com/forum/showt...xle+ebay+build D70HD front build hybrid-theorys pics of his http://www.pirate4x4.com/forum/showt...=522333&page=2
Piss on everything I'm going four wheelin! Last edited by gmcxt; 05-21-2011 at 09:22 AM. |
Devout Newbie Hater
just a thought...
help the BLIND. BIG LETTERS with COLOR above each type of Axle design... that way even the idjits get it.
sympathy, empathy and apathy... i dont know which one is which.... But i know you can find sympathy between shit and syphilis in the dictionary. Win this car for a whole BUCK! |
#7 (permalink) | |
Member # 147891
you must be off your ball today i took your advice so that i can help you. |
Member # 103814
what do I need to flip the hubs, install lockers, wheel disc brakes, pinion brakes spring rates, wheel/tire sizes, install boots, differences in types, strengths etc on 2.5t rockwell axles?
that's the only question I have. K. Thx. ![]() Good idea btw for putting them all in one thread. Easy to find info is the way to go. |
#11 (permalink) | |
Addicted to Gear Oil
Member # 56050
If your front diff looks like this:
![]() It's NOT a D60. It's a 10bolt.
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
#12 (permalink) | |
Member # 140746
#14 (permalink) |
Member # 77571
Sent with smoke signal. Last edited by jsawduste; 09-17-2010 at 06:16 AM. Reason: Fixed the link |
#15 (permalink) |
skullfuckery
Member # 29016
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
#16 (permalink) | |
skullfuckery
Member # 29016
#17 (permalink) |
Member # 147891
hear is some chevy related 8.8 stuff
http://www.v8s10.org/forum/viewtopic...=24816&start=0 http://www.v8s10.org/forum/viewtopic...tart=0#p206138 |
#19 (permalink) |
Member # 157332
A friend of mine just bought a truck and he called me asking. . . What chevy axle would only have 8 bolts on the cover? front axle?
88' Blaze Lifted Locked and on 35's 55' Willys CJ-5 Small Block Chevy Lifted on 38's |
#20 (permalink) |
skullfuckery
Member # 29016
what type of truck?
none that i can think of.
#22 (permalink) |
skullfuckery
Member # 29016
go count them again.
theres 10 and its a d44.
#24 (permalink) |
Member # 157332
HaHa Yeah I went to his place the day after I posted and looked for myself and seen the same, Than I learned him on how to count
#25 (permalink) |
Member # 172410
need help
Hey im hoping someone can help me. Im building a street rod truck and I have a gm 14 bolt rear end that was built for it. Im trying to find a disc brake conversion kit but heres the problem....Its a gm 14 bolt, 9.5, 5 lug which is rare enough but the axle housing end pattern for the disc brake kits dont match anything ive seen online. The 14 bolt is only listed at 3 3/8 by 2 5/8 and the chevy 10 and 12 bolt are completely diff measurements. Is this just some abortion rear end they made and im screwed on a disc brake kit??
