5 speed fuller transmission - GMC 366ci engine - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-14-2010, 08:43 AM   #1 (permalink)
Leyland's Avatar
Member # 133568
Curious if anyone has ever used one of these transmissions in a build? I had never heard of this transmission until found one locally for sale and did a little research... I believe they were only used in larger trucks and everything I can find claims a 1:1 final drive so it wouldn't get you any overdrive benefits but I wonder what bellhousings, clutches and adapters could be used for a build if desired.
Leyland is offline   Reply With Quote
Old 10-14-2010, 09:10 AM   #2 (permalink)
ruffyj's Avatar
Member # 120712
Wow! That fuller trans brinds back memories. I cant help with bellhousing/clutch fitment,but I think it is standard sbc/bbc pattern on engine. 4th&5th gear ratios are quite close to each other as I recall. I drove a truck/a 366/fuller/2speed rear axle. The shift pattern was 1stlo/1sthi-2ndlo/2ndhi/3rdlo-3rd-hi/4thlo-5thlo/4thHi-5thHi.
94 YJ. 2.5L, AX5, DD. Other vehicles, 03 F250 6.0L, Wifes vehicle 06 Tahoe/5.3L:laughing: Your drivetrain sure looks good honey:smokin:
ruffyj is offline   Reply With Quote
Old 10-14-2010, 09:35 AM   #3 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
I've seen the motor/trans combo on the ground, I didn't know if it was a 366 or 427 though. But it looked like a SAE bell housing (I don't know what #) also it had a adapter bell housing for a bigger flywheel. It was the BBC that caught my eye, its cool that there are bigger/better trans out there for our one tons. It would take a lot to make them fit though, there huge!
DD:09' V8 Colorado For Sale
Toy:The BlazerRebuild Ultra4 #818
Old tow:92' Dodge Build Sold
New tow:05' Dodge Crew 4x4 CTD (stock for now)
Looking for sponsors, we're going racing!
K5runner@hotmail.com is offline   Reply With Quote
Old 10-14-2010, 01:18 PM   #4 (permalink)
Member # 135002
I've seen bellhousings go both ways on the tall deck Chevies. Some have a normal looking Chevy bellhousing, just a little larger inside to clear a larger clutch, but bolt up like a normal pickup bellhousing. Others have had an SAE bellhousing. I think the SAE bellhousings were for an even larger clutch. The determining factor between the two was probably the GVW of the truck.
87 Toyota, 4.3, TH350, Dana 300(4 to 1), 60/70 welded, linked and coiled, 6.17's, 44" TSL's.
okiebindernut is offline   Reply With Quote
Old 10-14-2010, 06:41 PM   #5 (permalink)
Member # 29210
Send a message via AIM to Davethorik
I have a NP542 GL with the 7.33 first gear out of a C60, it has the larger bellhousing with the adapter plate. The clutch is 13". It was behind a td427 originally.
I believe it was Jp magazine that did the Spicer 3053A swap...yep.
http://www.jpmagazine.com/techarticl...ion/index.html
The bellhousing from my NP542 appears to be the same one in the article. Now if I could just find a cheap 3053A. Might be an option to the OP.
:laughing:
Davethorik is offline   Reply With Quote
Old 10-14-2010, 08:31 PM   #6 (permalink)
GMCTruxrule's Avatar
Member # 51243
For ease of adaptability and size restrictions, I would stay with a NV4500 or an SM465. And if you want a super duper uber low first gear, (as if the top two trans aren't deep enough) go with a Sm420.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
Old 10-15-2010, 10:53 AM   #7 (permalink)
Leyland's Avatar
Member # 133568
I was mostly turned off the idea when I found out that 5th was a 1:1 instead of an overdrive, would be no benefit over my current 465 set up. nontheless... would have cool factor and tough as nails for a tow rig if could work behind regular SBC/BBC.
thanks
Old 10-16-2010, 06:12 AM   #8 (permalink)
b454rat's Avatar
Member # 16536
They did make OD versions of these, but I gave up looking cuase I could never find one.
b454rat is offline   Reply With Quote
Old 10-16-2010, 09:52 PM   #9 (permalink)
Member # 51243
lol at the above post.
The ONLY benefit I could see running this trans is the closer gear ratios.
Old 10-16-2010, 10:30 PM   #10 (permalink)
Member # 80674
Yeah, that and the fact that clutches are dirt cheap and the fullers are WAY stronger than any NV/SM EVER thought of being. Not to mention parts availibility. Though i have no idea what it takes to get parts for the old ass SMxxx trannys.
JuniorHeep is offline   Reply With Quote
Old 10-17-2010, 12:25 PM   #11 (permalink)
just4cuz's Avatar
Member # 98655
Junkyards are full of em (SM420's) if you find one that has older stuff. They were in practically everything pre-1969.
just4cuz is offline   Reply With Quote
Old 10-18-2010, 01:15 AM   #12 (permalink)
Member # 51243
You can find replacement parts for any SM trans on the internet all day long.
And considering that the 420/465 trans were used in medium duty applications as well as light duty, I don't think lack of strength is enough to make me want to swap to a fuller 5 speed.
Old 10-18-2010, 08:18 PM   #13 (permalink)
Right Wing Radical
Jimbo*'s Avatar
Member # 36486
I have a clark 282V66 five speed out of a C700 dump truck, adapted to a 205.
Works great, but shifts like a two ton truck should
Can give more details and pics tomorrow if needed.
Here's the listing where I got it from. I put it in a K30 which rarely sees highway use, but it works great offroad.
Those who would eat, but not work, are thieves.
If God had wanted us to be vegetarians, he would have made broccoli more fun to shoot!
Jimbo* is offline   Reply With Quote
