What part of a tripled transfer case gets the most torque? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-30-2010, 06:03 PM   #1 (permalink)
Member # 168113
Is it the front planetary box or the rear transfer case that will have the most load on it when its in its lowest gear? I have a pile of 241c transfer cases 2 are the 32 spine input the other 7 are 27 spine! I have all the machine tools to make all the parts for doubling / tripling so it only cost the time to make the pieces! So should the 27 spline be in the front or back, or should I just get another 32 spine so there all the same?
Thanks for any input!
longtrackrmk is offline   Reply With Quote
Old 10-30-2010, 06:06 PM   #2 (permalink)
Bad Doctor
Odin K30's Avatar
Member # 86878
Why not just run all 9 cases so they can all spread the load?
-Vinny
-from Elizabeth
Nobody cares about your rigs specs...
"Me too" short Crew build
/forum/chevy/994394-odins-me-too-short-crew-build.html
Odin K30 is offline   Reply With Quote
Old 10-30-2010, 06:09 PM   #3 (permalink)
Member # 44659
That'd never work, what are you thinking??? Unless of course #7 is run in reverse to counteract the torque load, then all would be well. That and the rear planetaries would need shaved down to a 15* angle to make it handle the load. Of course the rear shafts need to be made from unobtanium, but you all already knew that.
88K5 14b/d60 Self destruct mode switched to on! 97 Xcab Dodge crawler in the works. 77fj40/94fzj80
lumpdog is offline   Reply With Quote
Old 10-30-2010, 06:33 PM   #4 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
No, the way you make it work is; you have the 8th case's front output go to a divorced (9th) case under the 3-4 case (depending on wheel base of course), then you can have good driveshaft angles. and don't even think about bolting them you HAVE to tig them together so they don't come apart. Then you can just run a 250cc 2 cycle motor to save weight and rev up. Don't cheep out with a Yamaha go balls out and get a Honda.
DD:09' V8 Colorado For Sale
Toy:The BlazerRebuild Ultra4 #818
Old tow:92' Dodge Build Sold
New tow:05' Dodge Crew 4x4 CTD (stock for now)
Looking for sponsors, we're going racing!
K5runner@hotmail.com is offline   Reply With Quote
Old 10-30-2010, 07:15 PM   #5 (permalink)
Devout Newbie Hater
Grumpy_old_fart's Avatar
Member # 20147
i keep saying... 11 hp briggs and stratton is all you need...
Bolt those cases together!
sympathy, empathy and apathy... i dont know which one is which....
But i know you can find sympathy between shit and syphilis in the dictionary.
Win this car for a whole BUCK!
Grumpy_old_fart is offline   Reply With Quote
Old 10-30-2010, 09:38 PM   #6 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
back in wubya wubya two them germains tried that. they actually hooked them up in a "U". it went from the rear engine to the rear bumper and back. they called a "cobbledawagen". it had a rubber driveshaft to the rear diff that was completely hinged on solid gold bushings! the crawl ratio was 22,421:1. because of this it could be powered by minature giraffes. opulence, they had it!
really why would you need more than a properly geared transfer and a doubler, with properly geared diffs. keeping whatever powerplant you are using in its powerband is more important than a sub 1 mph crawl speed.and as far as what gets the most torque it is definately the ouput shaft and the pinion on the diff. if they cant handle your multiplied torque then its not going to work anyway.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is offline   Reply With Quote
Old 10-30-2010, 10:32 PM   #7 (permalink)
cr480r's Avatar
Member # 157418
Put the stronger parts in the rear.
cr480r is offline   Reply With Quote
Old 10-30-2010, 10:36 PM   #8 (permalink)
Karnage
spidr's Avatar
Member # 55444
Anything less than 32 forward gears is a waste of time. The 33rd forward gear is bragging rights.
Go ahead and triple it up, put the strongest parts in the back, and prepare to break a lot of shit. As in EVERYTHING.
Thanks to BAILEIGH INDUSTRIAL
Krush RT IFS/IRS
Thanks to Epic Polymer Fox Kustoms Inc Pathmaker Productions[/color]
https://www.facebook.com/KrushRacing
spidr is offline   Reply With Quote
Old 10-30-2010, 10:55 PM   #9 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
you know what dick, just because you have 2 more gears than me doesnt give you the right to...............
ok, it does
Old 10-30-2010, 11:19 PM   #10 (permalink)
"All Whee Drive!"
MochaMike's Avatar
Member # 6450
And here I thought the IH DANs were bad.
50yo IH Scout Parts
WeBilt 4x4
Originally Posted by RustoleumWhite View Post
Binder Planet is the Church, or Community Center, Pirate is the Bar. You'll get good tech at both places, but here you have to take the shit with the good stuff.
MochaMike is offline   Reply With Quote
Old 10-30-2010, 11:44 PM   #11 (permalink)
Member # 42846
Whenever you gear down the shaft, you increase the torque.
For example, a 2:1 gear ratio would give you 1/2 the rotational speed, but double the torque.
So if you had three cases attached together with a 2:1 gear ratio,
that would give you 8 (NOT 6!) times the amount of torque leaving the three cases, but 1/8 of the speed.
So, as was said already, put your strongest parts at the end.
TGomes1987 is offline   Reply With Quote
Old 10-31-2010, 12:23 AM   #12 (permalink)
Karnage
spidr's Avatar
Member # 55444
that would give you 6 times the amount of torque leaving the three cases, but 1/6 of the speed.
Before you give advice, that is obviously wrong, try to learn a little bit about the way it all works.
Krush RT IFS/IRS
Old 10-31-2010, 05:13 AM   #13 (permalink)
enigma2y0u's Avatar
Member # 36955
There is a subtle, but important difference between adding and multiplying.
enigma2y0u is offline   Reply With Quote
Old 10-31-2010, 10:14 AM   #14 (permalink)
Member # 122868
But spidr, you put two 4spds together, that's 8 speeds in total...
May I ask what super-light rig you are putting this triple-x-case in? The 241 in one of my Suburban's lasted 4 weekends in the bush with nothing more than 33's and a stock 350. The 241 HD's internals were turned into shrapnel in one of my old D250's (12v/getrag 5spd).
Have you considered a 203/205? Sell some 241's and you would cover the whole doubler build.
JOKER
I left the 4x4 world a while ago...
Thinking of going back.
JOKER4X4 is offline   Reply With Quote
Old 10-31-2010, 10:24 AM   #15 (permalink)
Devout Newbie Hater
Member # 20147
JOKER
2 four speeds would give you 16 different speeds, not counting double reverse, and that would give you 17...
Old 10-31-2010, 11:42 AM   #16 (permalink)
"All Whee Drive!"
MochaMike's Avatar
Member # 6450
Not counting Reverse, you have 16 with two 4 speeds & one tcase.
Ironically you also have 16 with two (different speed) transfercases (like in my sig).
(Note: this is all Sunday morning math, so I may be wrong).
50yo IH Scout Parts
WeBilt 4x4
Old 10-31-2010, 03:03 PM   #17 (permalink)
Member # 42846
Explain to me how that is wrong.
I was giving him the example that if three cases were in low range with a 2:1 low range ratio of each case (which they are most likely not), the final torque on the outgoing shaft would be 8 (not 6 as I said before) times that of the incoming shaft torque.
Maybe I did not explain myself correctly.
I was not saying that having more gears would automatically increase the torque, because if everything was in high range (1:1 ratio), the torque throughout would be the same.
Old 10-31-2010, 03:48 PM   #18 (permalink)
Member # 106663
The part that breaks first. Really though, PM GeeWhiz, he'll be stoked.
Filthy McChevy is offline   Reply With Quote
Old 10-31-2010, 04:13 PM   #19 (permalink)
Member # 83920
I was giving him the example that if three cases were in low range with a 2:1 low range ratio of each case (which they are most likely not), the final torque on the outgoing shaft would be 6 times that of the incoming shaft torque.
For fucks sake. New to math?
2X2X2 does not equal 6. Maybe you explained yourself perfectly, but you just didn't know what the fuck you were talking about.
This isn't meant to be a flame job, but Jesus, do you guys ever read or search? Do you suppose your question has already been answered somewhere? Look it up for your fuckin self.
dahoyle is offline   Reply With Quote
Old 10-31-2010, 04:42 PM   #20 (permalink)
Karnage
spidr's Avatar
Member # 55444
4 x 4 x 2(1 t-case) = 32. Hi and low double reverse gives you 34 total. With 2 identical transmissions, you have a lot of duplicates though. It's allright, you apparently have the same issues as the next post.....
Go grab a calculator please and enter 2 x 2 x 2 and press the = key, and report back.
Krush RT IFS/IRS
Old 10-31-2010, 04:46 PM   #21 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
for the record, fuck your 34 gears including reverse's.
i have 30 forward and 6 reverse x 3 x 2
Old 10-31-2010, 04:49 PM   #22 (permalink)
Member # 151427
divorce the third one and use the front output to run to the rear axle. best of all you can you use a front axle without having to do all those crazing mods to get the direction right.
instant free rear steer!
77 fj40 tube buggy
[url]http://www.pirate4x4.com/forum/showthread.php?t=955735&highlight=[/url]
postaldave is offline   Reply With Quote
Old 10-31-2010, 04:55 PM   #23 (permalink)
Member # 42846
Ah yes I added them instead of multiplying.
My explanation was correct, just not my terrible math skills.
I edited it on my earlier post so it is 8, not 6.
Carry on.
Old 10-31-2010, 05:53 PM   #24 (permalink)
AllUpInYourFace
mudskipper4x4's Avatar
Member # 72951
Classic pirate awesomeness!!!
76 CJ-7... mostly chevy parts
www.centexoffroad.com
mudskipper4x4 is offline   Reply With Quote
Old 10-31-2010, 05:59 PM   #25 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
2x2=4+3.1415972/8x6+ two (2) 2x4's= 842 forward speeds and 132 reverse speeds. no matter how many forward gears you have you still wont be opulent. now with mini giraff shifters hmmmm...................
http://www.pirate4x4.com/forum/showthread.php?t=933618
