94 4.3 Vortec Info needed - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-02-2010, 09:24 AM   #1 (permalink)
Member # 132437
I'm looking to do an engine swap and I found a 94 4.3 "vortec" engine with 100,000 for $100. I've heard these are the shitty flowing heads and in '96 they redsigned the heads and flow much better. So my question, should I hold off and wait till i come acorss a '96 or newer engine or is the 94 still decent?
ech0sh4y is offline   Reply With Quote
Old 11-02-2010, 09:32 AM   #2 (permalink)
Member # 14696
the 96 and newer are 205 hp and obd2 the 93 to 95 are 180 or 195 hp so i would hold out for the 96 and newer
rebalracer is online now   Reply With Quote
Old 11-02-2010, 09:41 AM   #3 (permalink)
Member # 132437
Can you just swap out heads? or is the intake and internals different?
Old 11-02-2010, 09:48 AM   #4 (permalink)
Member # 14696
are you going efi or carb?
Old 11-02-2010, 09:54 AM   #5 (permalink)
Member # 132437
looking for efi - swapping into a 84 cj7
Old 11-02-2010, 10:36 AM   #6 (permalink)
Member # 14696
you can't use the 96 or newer efi on the older short block the cps tone ring will not fit on the old crank
Old 11-02-2010, 10:53 AM   #7 (permalink)
Member # 132437
alright thanks! i appreciate the info. I'll keep looking
Old 11-10-2010, 04:47 PM   #8 (permalink)
knaffie's Avatar
Member # 48084
As long as you have the 1994 Vortec version, it will run strong. I've had them all. The 1996 isn't that much better than the 1994.
2011 TTF buggy
knaffie is online now   Reply With Quote
Old 11-11-2010, 09:15 AM   #9 (permalink)
Member # 41809
Sorry to hijack but I have a similar question. I've got a 94 tbi that needs replaced. Can I swap in a 96 or newer4.3? Will the tbi intake bolt to the newer heads?
BowtieBoy is offline   Reply With Quote
Old 11-11-2010, 09:23 AM   #10 (permalink)
knaffie's Avatar
Member # 48084
No, it will not. I tried it years ago. Vortec and non-vortec heads are completely different. The non-Vortec heads have the intake bolts angle, while the Vortec heads have them straight up and down. The Typhoon / Cyclone guys use to go through extensive machine work to get the Vortec heads on their non-Vortec motors, since its like a 50 HP upgrade on those turbo trucks.
2011 TTF buggy
Old 11-12-2010, 07:40 AM   #11 (permalink)
Member # 41809
But if the 94 is a vortec, will the tbi intake bolt to 96 and up heads? My valve covers say vortec and the intake bolts go straight into the head not angled
Old 11-12-2010, 07:14 PM   #12 (permalink)
Member # 96330
94's are not actually vortecs even tho they say it all over them. tbi's 93 and previous and cpi's 93-95 are non vortec motors.
true vortecs have the plastic upper Pentium aswell.
whatcha lookin at my gut fer?
shatnr is offline   Reply With Quote
Old 11-13-2010, 04:53 AM   #13 (permalink)
knaffie's Avatar
Member # 48084
They've been using the Vortec name since something like 85, although it wasn't widely publicized until the CPI engine with Vortec on top of the engine. I got into an argument with a guy one time about it and got my ass handed to me. He had an old magazine ad from when they first put the 4.3 into the S10s that referred to it as a "Vortec" engine.
I don't know when you can "officially" start calling the 4.3 a Vortec. I suppose 96 would probably be it.
2011 TTF buggy
Old 11-13-2010, 10:34 AM   #14 (permalink)
Member # 96330
Ill throw in some pics to add to the confusion.
These are true vortec heads. Look at the relationship between the intake Pentium bolts and the intake plane.
This is a non-vortec head. The bolts are at 90 degrees to the intake plane.
My motor, even says vortec on the top....is not a real vortec imo. Because it does not have the true vortec heads on it.
Old 11-14-2010, 01:05 PM   #15 (permalink)
Member # 41809
What Heads do the 94 cpi's have then? Same as the tbi heads?
